Old 16th March 2018, 15:51   #22621  |  Link
clsid
Windows has native support for .m4a playback through Media Foundation.
Old 16th March 2018, 16:31   #22622  |  Link
manolito
manolito's Avatar
Not WinXP...
Old 17th March 2018, 13:22   #22623  |  Link
pikaczu
Posts: n/a
I am using the mpc hc 1.7.15 program, I have given the aac file for the rehearsal, and there is such a thing, it's about time:
Old 17th March 2018, 14:35   #22624  |  Link
Klaus1189
better use google drive or similar for posting pics, I cannot view your jpg right now, for example. It is still pending ...
Old 17th March 2018, 14:44   #22625  |  Link
LigH
LigH's Avatar
https://frupic.frubar.net (sorry for suggesting this over and over, groundhog day again)
New German Gleitz board
Old 17th March 2018, 19:46   #22626  |  Link
pikaczu
Posts: n/a
good, please
Old 17th March 2018, 19:56   #22627  |  Link
LigH
LigH's Avatar
It displays a playing time of 28:32:59; which other value would you have expected instead?
And BTW, this is a play time of an MKV, according to the window title, what do you mean with AAC? Did you try to load an external audio file in parallel? Missing details.
Old 17th March 2018, 20:18   #22628  |  Link
pikaczu
Posts: n/a
this is the time, after loading aac file.
Old 17th March 2018, 20:34   #22629  |  Link
nevcairiel
I have no plans to work on that. You should wrap your audio into an actual container if you are about its duration being accurate.
Old 17th March 2018, 20:38   #22630  |  Link
LigH
LigH's Avatar
AAC has a variable bitrate. To estimate the playing time accurately, an application would have to collect statistics about the whole audio; a DirectShow decoder will not be able to do that until you have played the whole media already.
Old 17th March 2018, 20:40   #22631  |  Link
pikaczu
Posts: n/a
It is a pity that there will be no amendment.
how?
Old 19th March 2018, 12:25   #22632  |  Link
pkirill
It can not render it using FilterGraph.
Originally Posted by LigH View Post
But you don't want to install them as DirectShow filters system-wide?
I do not have an option to register it system wide.
MPC-HC uses LAV Filters as "internal splitter/decoder", and the AviSynth plugin DSS2Mod (to be found e.g. in the Xvid4PSP project, or in the AviSynth Wiki) can do that as well. If you have developers who are able to read their C/C++ sources, you will most probably find how they do that directly, bypassing DirectShow automatic graph building.
Thanks, will look at this.
pkirill is offline   Reply With Quote
Old 19th March 2018, 12:35   #22633  |  Link
LigH
LigH's Avatar
No, Media Foundation is not DirectShow.
Old 20th March 2018, 16:44   #22634  |  Link
pkirill
Right, i support what i need, looking at this now.
It seems that it is something I need.
Thanks
Old 20th March 2018, 18:37   #22635  |  Link
nevcairiel
You can do what you ask with LAV Filters, several other projects load it without registration, and bundling with apps is allowed within what the license allows.
Old 20th March 2018, 22:13   #22636  |  Link
tyrindor
Is there anyway to have advanced splitter mode ignore all subtitles labelled as "Signs"?
Right now I have it set to: "jpn:*|d;jpn:eng;*|f" but many releases flag "signs" as the default subtitle track for anime, and put english subtitles on track 2.
tyrindor is offline   Reply With Quote
Old 20th March 2018, 22:23   #22637  |  Link
LigH
LigH's Avatar
With "signs", they possibly mean "scene subtitles" (translations of readable signs only) in contrast to complete translations of the whole audible speech?
Old 20th March 2018, 22:42   #22638  |  Link
tyrindor
Yes, that's correct. I'd like to ignore them and select the next another english subtitle track if possible.
Old 20th March 2018, 22:42   #22639  |  Link
sneaker_ger
Not really. I think the "!" operator doesn't work on track names (@nev: feature request?). Maybe you could do e.g.:
jpn:eng|!d jpn:eng
Then it would select the non-default English track first and only if that doesn't exist the first English track regardless of default/forced flagging.
Old 20th March 2018, 23:09   #22640  |  Link
tyrindor
Originally Posted by sneaker_ger View Post
Not really.
You could do e.g.:
jpn:eng|!d jpn:eng
Well at least I can do that while watching shows that do this. Thanks.
I've been trying forever to get my subtitles to work automatically but there's so many releases with flagged "default" english subtitle tracks on english language content throwing me off. I can't get my anime to play well with them.
For example:
*|d;eng:*|f;jpn:eng
I would read this as "First set default track, if english is found enable english forced subs instead, if Japanese is found enable english subs instead. This doesn't work though, english audio content still has default subs selected. Putting *|d at the end instead has the same effect.
So what's the best way to achieve this in one command?
- If japanese audio is found enable english subs, if no english subs enable default subs.
- If english is found enable forced subs.
- If unknown language (or simply not english) enable default subs. <-this seems impossible without overwriting everything else.
Greatly appreciated...
