8th November 2006, 20:30 | #421 | Link | |
8th November 2006, 21:21 | #422 | Link | |
I don't use 'Tab' in scripts at all. They are pretty simple so I don't need to indent the lines. I prefer fast focus switch and it's a perfect key for me to do that .
This behavior should be consistent with other apps IMHO...
(!sig) Last edited by krisq; 8th November 2006 at 21:41. |
8th November 2006, 21:42 | #423 | Link | |
Tab is quite useful for me actually in some of my avisynth scripts, or look at Didée's scripts, readability is really improved with proper tabbing (Of course I also use all the time the constant width font option) |
9th November 2006, 16:25 | #424 | Link |
Urgent bug: can't run my avsp anymore.
I ran a script that causes avisynth to crash, and left the preview window on. Now if I load avsp, it instantly exits. The script in virtualdubmod also makes that app exit. This shouldn't be happening in any of those programs. Another bug is that I saved my script and it always came back with the old one. Saving a script should always write the file. I had to paste it to notepad in order to save it. Is there a bug in saving the preview.avs and reusing it? |
9th November 2006, 18:02 | #425 | Link |
Hi, is not "bug" in AvsP, is (most presumable) incompatible or bug plugins in your avisynth plugins folder. Troubleshoot this problem first. Otherwise, kudos to the AvsP author!!! Is one wonderful little piece of software, very very useful. PS: I had many problems with sse3 plugins, try replace to sse2 versions (My cpu is C2C E6600)
9th November 2006, 22:05 | #426 | Link |
Angel of Night
You can delete _last_session.ses in the avsp folder, or modify it to remove/change the offending script, if it really happens to be a script problem. Does sound like a plugin problem though.
9th November 2006, 22:07 | #427 | Link | |||||
Edit: foxyshadis beat me to it Last edited by qwerpoi; 9th November 2006 at 22:12. |
9th November 2006, 22:22 | #428 | Link | ||
9th November 2006, 23:01 | #429 | Link |
I have a suggestion that I think would be really useful. I don't think I see this kind of functionality present in AvsP yet, but let me know if I have just missed it.
It would be really nice if there was an easy way to select frame ranges for trim, applyrange, etc. My suggestion to handle it is like this: Allow users to specify an in-point by pressing something like alt+[, and then an out-point by pressing alt+]. Once both an in and out point are selected, have a little popup for the user to choose from things to do with that selection of frames. One such option would be a regular Trim, to leave only the section between the frames you selected. Another option could be an inverse trim--it would REMOVE the frames you selected, leaving the sections around it (by adding 2 trim commands). There could also be options for applyrange, and other commands that use a range of frames. This would allow to quickly and easily make simple edits to the video. And additionally, one other minor thing: when you create a new script, then go to save it the first time, would it be possible to fill in the default filename to be the same as the first input source in your script, except with an avs extension? Last edited by Zarxrax; 9th November 2006 at 23:20. |
10th November 2006, 00:51 | #430 | Link |
ncatt: thanks for the tip, that cured it. It was logotools.dll, an avisynth 2.0 plugin, loaded with loadpluginex(), the crash is caused by not using yuy2.
You could help by noting a crash and automatically disabling preview on the next session, this would be very easy. All: I second the suggestion, I would find it acceptable to save scripts according to the source name, as that is a frequent use. I would also like a save script icon for quick saving, I tend to debug and save at every working step. |
10th November 2006, 05:22 | #432 | Link | ||||
@krisq I tested using 'Tab' as the shortcut to switch between the windows, and I noticed that hitting 'Tab' in the script window switches to the video window, but adds a tab into the text first. I'll try and find a way around this, but I was just curious if this was happening to you as well. |
10th November 2006, 10:24 | #433 | Link | |
(!sig) |
11th November 2006, 03:59 | #434 | Link |
qwerpoi: ok, ctrl-s is acceptable, though I have to get in the habit of this. Doing something about the crash would be great.
Requests: Select, Region, select rectangular region, Copy, Paste Special, Region as Crop command, as letterbox command. Select, Pixel, primary-click pixel,Copy, Paste Special, Pixel as RGB Hex, as YUV also, change Select to Select Source, and Select destination, then add paste as Tweak(), as Resize(). I recommend these, as they are very visual operations, and certainly no program allows you to visually measure or tweak colors (as YUV at least). Read the colors from the codec output colorspace and convert to the other colorspace, could even be lazy and insert script to do this. Last edited by jmac698; 11th November 2006 at 04:16. |
11th November 2006, 04:20 | #435 | Link |
as far as GUI operation questions, there are two standards for this, gnome user interface, http://developer.gnome.org/projects/gup/hig/
windows interface, http://msdn.microsoft.com/ui/, or just look at how Office reacts. Don't worry, there is room for custom operation, but new users are best served by a set of standard GUI controls. |
11th November 2006, 11:38 | #436 | Link | |
Angel of Night
It'd only work for testing the final operation(s), at least without even more magic, though. There might be a way to do this entirely in script, I'll look into it. |
11th November 2006, 21:39 | #437 | Link | ||||
11th November 2006, 23:36 | #438 | Link |
Single frame preview: avisynth is smart enough to request just enough data to preform it's operations. It may be possible that forcing a single frame is unnecessary.
Crop: oops, got me there. I didn't know there was a built in crop editor. Color picker: yes, that's what I want, to do spot checks of colors. The idea of measuring two pixels is that, I pick a pixel in one source and a pixel in another source, and compute a tweak command to match colors. But what's more important to me is simply to be able to read YUV colors, especially of colorbar patterns and other spot checks. GUI: I've tutored people in basic computer operations, trust me it helps to have something familiar. There is actually good reasoning behind it, and it all started with research at the Palo Alto research centre a long time ago. E.g., if a button doesn't give visual or audio feedback, people will naturally keep pressing it until it "does something". As for shortcuts, they are just there for keyboardists - disabled persons use serial key devices which operate naturally with shortcuts. There are various disabled on this board but you wouldn't know it! Last edited by jmac698; 11th November 2006 at 23:44. |
14th November 2006, 13:42 | #440 | Link | |
As promised, new version 1.3.3, download here or use the mirror on the first post. Here's the changelog:
You may find that when you are resizing the video window like crazy , you get an error like "Failed to retrieve AVI frame". It seems this can occur when the program tries to create/load avs files too quickly. If this error occurs, you'll see a gray video window, simply refresh with F5 to fix the problem. Other than that, there are some various bugfixes in this release. I tried to fix the multi-monitor issues and some unicode decoding problems, but since I'm not able to recreate them on my computer I wouldn't be surprised if some issues lingered. So be sure to report back with any problems as always. Last edited by qwerpoi; 14th November 2006 at 13:45. |
