1st February 2022, 04:37 | #62 | Link | |
Only if you want to of course. |
1st February 2022, 17:28 | #63 | Link | |
https://github.com/jlw4049/HDR-Multi-Tool-Gui |
2nd February 2022, 15:16 | #67 | Link |
All static edits that don't require modifying a specific frame can technically be done, but it's not implemented in dovi_tool currently.
So, you can't edit anything other than doing mode/crop right now.
LG C2 OLED | GitHub Projects |
5th February 2022, 11:29 | #70 | Link | |
QfG Group Germany
@quietvoid
I have seen that in any RPU.bin's CM29 Metadata not Level5 specified. Is that the same if i set Active Area to 0,0,0,0? For example: Quote:
5th February 2022, 15:28 | #72 | Link |
Probably, but Dolby recommends that L5 should always be present to avoid issues.
5th February 2022, 20:45 | #73 | Link | ||
QfG Group Germany
6th February 2022, 16:54 | #75 | Link |
Hi, version 0.37a has a problem, in the demuxer, opening a file with dolby vision profile 7, option 4 (Convert RPU), shows only Profile 8 and it is not possible to change it as in previous versions ( Leave untouched).
6th February 2022, 19:59 | #77 | Link |
If I want to crop a video with source resolution 3840x2160p in dolby vision 8.1, and the letterboxes bars are above 277 px and below 277 px, can I use the -c command of dovi_tool (or the crop RPU option of the -QfG- tool) with avisynth+ and crop like this?
crop(0, 276, 0, -276) to be compatible with the height (divisible by 2) rule (mod 2) of avisynth? Without resizing and with a final resolution of the re-encoded video of 3840x1608p ? Is this correct? Last edited by cool advertise; 6th February 2022 at 20:11. |
7th February 2022, 02:56 | #78 | Link |
QfG Group Germany
Yes. Simply use the Crop RPU Function of the DEMUXER or use the Active Area Editor in INJECTOR and set all entries to 0.
-v0.37b *Minor Bugfixes *Updated mkvtoolnix to v 65.0.0.0
8th February 2022, 14:26 | #80 | Link | |
Undercropping your video (containing 277px black bars) with 276px would leave 2 black lines. As such, shouldn't you better set TOP and BOTTOM crop values both to "1" in -QfC- injector? Using --crop switch would set all offsets to zero. No intention to being pedant here, but I wouldn't know how precise these values need to be and what the chances are of introducing artefacts. On te opposite side, when overcropping video (even slightly), I also wonder whether (cropped) RPU can get corrupted . Imagine your same video, but cropping with 280 instead, leaving 3840x1600, which is widely used. Extract RPU with --crop switch: great, no offsets. But what about this "active area"? I don't know exactly how further this is used in DV's metadata. But I can imagine cropped RPU being left incompatible because of "shrunk active area" as invoked by the overcrop. |
