Old 14th May 2023, 00:49   #641  |  Link
CheezyFriez12
Shitty DRM on John Wick 2
Can someone help me figure out why I keep seeing this message, even after ensuring the keys are ripped?
Dear customer,
The disc you've inserted cannot be played due to copyright restrictions. Please visit http://www.lionsgateshop.com, a local retail, or online store of choice to purchase a genuine copy.
If you try to play back an original disc on your computer and experience a "copy detected" message, please ensure that no ripping or copying tool is actively running while performing the playback.
This is after watching 10 minutes of somewhat interesting previews and using the BD-J menu.
CheezyFriez12 is offline   Reply With Quote
Old 14th May 2023, 09:16   #642  |  Link
Grimsdyke
Use MPC-BE or MPC-HC to watch movies on a HTPC.
MPC-BE feature wishlist: 1) DiscID
2) Two independent volume control sliders in the UI when using dual-audio-out.
Grimsdyke is offline   Reply With Quote
Old 14th May 2023, 21:02   #643  |  Link
CheezyFriez12
May I ask what makes MPC different to VLC, and can these extra features be added to VLC?
Old 19th May 2023, 10:52   #644  |  Link
metalsonic88
I'm trying to use FindVUK with the Yu-Yu-Hakusho 30th Anniversary blu-ray collection but have hit a bit of a wall. Newer versions of DVDFab don't seem to work with FindVUK as they just hang after dumping memory allegedly succeeds. DVDFab v12.0.8.9 is the last version that seems to work with FindVUK, but when I try to use it with Season 2 Disc 4 it tells me that I have to use a newer version of DVDFab with this disc. Any advice on what to do here?
metalsonic88 is offline   Reply With Quote
Old 19th May 2023, 13:14   #645  |  Link
Captain Dunsel
DVDFab 12.1.0.1
Since DVDFab 12.1.0.1 FindVUK can't find anything in the dumpfile. I tried some older versions of DVDFab 12.0.9.9, but some of my Blu-Ray's require a newer version.
14:04:05 -  ----------- FindVUK 1.63 -----------
 To close FindVUK simply press the ESC key
14:04:05 - SettingsFile: >\FindFUK\config\FindVUK.ini<
14:04:05 - Logfile:\FindFUK\log\2023-05-19_FindVUK.txt
14:04:05 - Update enabled - check for update
14:04:06 - No update required
14:04:06 - Open Main-KEYDB file: >C:\Users\AppData\Roaming\aacs\KEYDB.cfg<
14:04:09 - Open Backup-KEYDB file: >FindFUK\VUKbackup\KEYDB.cfg<
14:04:09 - ERROR! Starting with Passkey 9.2.1.2 the VUK is not available im memory any longer!
14:04:09 - Please downgrade to an older Passkey version.
14:04:09 - DVDfab Version >12.1.0.1< found
14:04:09 -  >>> everything should work as expected!
14:04:09 - Preferred application >PassKey< is not available
14:04:09 - DVDfab is available!
14:04:09 - DVDfab-MainFile:      >C:\Program Files\DVDFab\DVDFab 12\DVDFab64.exe<
14:04:09 - DVDfab-LogFile:       >\DVDFab\DVDFab12\Log\dvdfab_internal.log<
14:04:09 - KEYDB-Path:           >C:\Users\AppData\Roaming\aacs\<
14:04:09 - KEYDB-Backup-Path:    >FindFUK\VUKbackup\<
14:04:09 - ProcDumpFile:         >\FindFUK\tool\procdump64.exe<
14:04:09 -  --- PART 1 --- GET DUMP ---
14:04:09 - No running application process discovered
14:04:09 -  >> Start it now >C:\Program Files\DVDFab\DVDFab 12\DVDFab64.exe<
14:04:35 - Drive opened
14:04:35 - Volume Label detected >STAR_TREK_TMP_DIRECTOR_EDITION<
14:04:37 - DriveLetter detected >E<
14:04:38 - Detected CopyProtections AACS >1< BD+ >0<
14:04:38 - DiscID found >E93F475033BCA69E56C676382E6D6CE4C6968845<
14:04:43 - MainPlaylist found >00001.mpls<
14:04:57 - DVDFab64 got Unit Keys - create memdump now!
14:04:59 - Dump successful! >1<
14:04:59 - MemDump successfully finished!
14:04:59 - Cancel DVDfab decryption now!
14:04:59 - Get basic AACS data
14:04:59 - AACS folder on disc is reachable - ValidateVUK is possible
14:04:59 - VolumeName         >STAR_TREK_TMP_DIRECTOR_EDITION<
14:04:59 - DiscId             >E93F475033BCA69E56C676382E6D6CE4C6968845< (2022-06-03)
14:04:59 - DiscType           >BD<
14:04:59 - MKB Revision       >77<
14:04:59 - Disc-BusEncEnabled >0<
14:04:59 - Drve-BusEncCapable >1<
14:04:59 - UnitKeyCount       >7<
14:04:59 -  >>> UnitKeyENC (1) >8B767028DBE5515D92A651F612C3AE7D<
14:04:59 -  >>> UnitKeyENC (2) >2C0E7ED9CDEE8099793A1059C1CB70AA<
14:04:59 -  >>> UnitKeyENC (3) >8F5202A19C3D61692164F7BC63C53449<
14:04:59 -  >>> UnitKeyENC (4) >7F9CB20ACABFA08D3AF319BAC2C8B7BC<
14:04:59 -  >>> UnitKeyENC (5) >0547E1B9B85AA3B3C94EA174DFE9C73A<
14:04:59 -  >>> UnitKeyENC (6) >251F24A2659862AA40892705E705BEF5<
14:04:59 -  >>> UnitKeyENC (7) >BEA74C00572B0E12579BB2480121FADB<
14:04:59 - Analyze dump
14:04:59 - Start to analyze '2018' MemDump now!
14:05:01 - ERROR! Finding real UnitKey >0< - 2 !
14:05:01 - ERROR! Couldn't find real unit keys in json from file >\FindFUK\dump\E93F475033BCA69E56C676382E6D6CE4
        4C6968845_STAR_TREK_TMP_DIRECTOR_EDITION.dmp<
14:05:01 - Error analyzing memory dump - please report in the doom9 forum!
14:05:01 - ERROR! Analyze 2018 failed!
14:05:01 - CloseAtTheEnd is active, close DVDfab now
Captain Dunsel is offline   Reply With Quote
Old 3rd June 2023, 02:12   #646  |  Link
binaryflow
What's happening with bluray scene? It seems stalled...
binaryflow is offline   Reply With Quote
Old 4th June 2023, 10:19   #647  |  Link
candela
If DVDFab fails you can do the following:
- Use FindVUK GetMetaInfoFromDisc function. Disc details will get submitted to FindVUK and keys for the disc will appear in keydb.cfg after an undefined amount of time. ALWAYS do this to fill FindVUK db with verfied disc details even if you proceed with the following steps
If you can't wait for the keys to appear:
- Extract VID from MakeMKV using RDKfromMMKV. Then use aacskeys with this VID and the 3 PK from Findvuk keydb.cfg. Manually add keys to keydb.cfg (at minimum DiscID and VUK is needed)
OR
- Use XReveal with FindVUK keydb.cfg (which as 3 PK at the top for all known MKBv) and it will show you the keys in the menu. Manually add keys to keydb.cfg (at minimum DiscID and VUK is needed)
Do NOT synch FindVUK keydb unless you have tested the manually added keys.
candela is offline   Reply With Quote
Old 4th June 2023, 11:32   #648  |  Link
hajj_3
MakeMKV v1.17.4
Added support for AACS v81
Old 8th June 2023, 10:45   #649  |  Link
binaryflow
Any new automated method for FindVUK or similar? Does DVDFab intentionally obfuscated that information?
Old 13th June 2023, 21:36   #650  |  Link
Bahamuth
Just today I got My Hero Academia Season 5 Part 1 in the mail. Disc 1 can be loaded just fine (PassKey gets the disc infos, FindVUK gets the memory dump, closes PassKey and analyzes the dump), but on Disc 2 FindVUK obviously gets the memory dump from PassKey, but it never closes it. Manually closing PassKey does nothing, the process stalls.
If I press escape, FindVUK will exit as usual then.
22:34:00 -  ----------- FindVUK 1.63 -----------
22:34:00 - SettingsFile: >C:\apps\backup\FindVUK\config\FindVUK.ini<
22:34:00 - Logfile: C:\apps\backup\FindVUK\log\2023-06-13_FindVUK.txt
22:34:00 - Update enabled - check for update
22:34:00 - No update required
22:34:00 - Open Main-KEYDB file: >C:\Users\Ezatoka\AppData\Roaming\aacs\KEYDB.cfg<
22:34:03 - Open Backup-KEYDB file: >C:\apps\backup\FindVUK\VUKbackup\KEYDB.cfg<
22:34:03 - Passkey Version >9.4.5.2< found
22:34:03 -  >>> everything should work as expected!
22:34:03 - Passkey is preferred and available!
22:34:03 - Passkey-MainFile:     >C:\apps\backup\DVDFab Passkey\DVDFabPasskey.exe<
22:34:03 - Passkey-LogFile:      >C:\Users\Ezatoka\Documents\DVDFab Passkey\Log\passkey_internal.log<
22:34:03 - KEYDB-Path:           >C:\Users\Ezatoka\AppData\Roaming\aacs\<
22:34:03 - KEYDB-Backup-Path:    >C:\apps\backup\FindVUK\VUKbackup\<
22:34:03 - DUMP-Path        :    >C:\Users\Ezatoka\AppData\Local\Temp\<
22:34:03 - ProcDumpFile:         >C:\apps\backup\FindVUK\tool\procdump64.exe<
22:34:03 -  --- PART 1 --- GET DUMP ---
22:34:03 - No running application process discovered
22:34:03 -  >> Start it now >C:\apps\backup\DVDFab Passkey\DVDFabPasskey.exe<
22:34:08 - Drive opened
22:34:08 - Volume Label detected >MyHeroAcademia_S5P1_D2<
22:34:11 - DriveLetter detected >D<
22:34:11 - Detected CopyProtections AACS >1< BD+ >0<
22:34:12 - DiscID found >8D838CB8910FE75C00ADF03270B309A8B2DC6EA2<
22:34:14 - DVDFabPasskey got Unit Keys - create memdump now!
22:34:15 - Dump successful! >1<
22:34:15 - MemDump successfully finished!
22:34:15 - DVDFabPasskey got Unit Keys - create memdump now!
22:34:16 - Dump successful! >1<
22:34:16 - MemDump successfully finished!
Bahamuth is offline   Reply With Quote
Old 13th June 2023, 23:39   #651  |  Link
Bahamuth
and another problem:
00:37:40 -  ----------- FindVUK 1.63 -----------
00:37:40 - SettingsFile: >C:\apps\backup\FindVUK\config\FindVUK.ini<
00:37:40 - Logfile: C:\apps\backup\FindVUK\log\2023-06-14_FindVUK.txt
00:37:40 - Update enabled - check for update
00:37:41 - No update required
00:37:41 - Open Main-KEYDB file: >C:\Users\Ezatoka\AppData\Roaming\aacs\KEYDB.cfg<
00:37:44 - Open Backup-KEYDB file: >C:\apps\backup\FindVUK\VUKbackup\KEYDB.cfg<
00:37:44 - Passkey Version >9.4.5.2< found
00:37:44 -  >>> everything should work as expected!
00:37:44 - Passkey is preferred and available!
00:37:44 - Passkey-MainFile:     >C:\apps\backup\DVDFab Passkey\DVDFabPasskey.exe<
00:37:44 - Passkey-LogFile:      >C:\Users\Ezatoka\Documents\DVDFab Passkey\Log\passkey_internal.log<
00:37:44 - KEYDB-Path:           >C:\Users\Ezatoka\AppData\Roaming\aacs\<
00:37:44 - KEYDB-Backup-Path:    >C:\apps\backup\FindVUK\VUKbackup\<
00:37:44 - DUMP-Path        :    >C:\Users\Ezatoka\AppData\Local\Temp\<
00:37:44 - ProcDumpFile:         >C:\apps\backup\FindVUK\tool\procdump64.exe<
00:37:44 -  --- PART 1 --- GET DUMP ---
00:37:44 - No running application process discovered
00:37:44 -  >> Start it now >C:\apps\backup\DVDFab Passkey\DVDFabPasskey.exe<
00:37:56 - Drive opened
00:37:56 - Volume Label detected >The_Transformers_The_Movie<
00:37:58 - DriveLetter detected >D<
00:37:59 - Detected CopyProtections AACS >1< BD+ >0<
00:38:00 - DiscID found >55535475A45362E81DD533E95E00AD3B3CCCCA9D<
00:38:01 - MainPlaylist found >00000.mpls<
00:38:02 - DVDFabPasskey got Unit Keys - create memdump now!
00:38:03 - Dump successful! >1<
00:38:03 - MemDump successfully finished!
00:38:03 - Close Passkey now!
00:38:10 - Get basic AACS data
00:38:10 - AACS folder on disc is reachable - ValidateVUK is possible
00:38:11 - VolumeName         >The_Transformers_The_Movie<
00:38:11 - DiscId             >55535475A45362E81DD533E95E00AD3B3CCCCA9D< (2021-06-16)
00:38:11 - DiscType           >UHD<
00:38:11 - MKB Revision       >76<
00:38:11 - Disc-BusEncEnabled >1<
00:38:11 - Drve-BusEncCapable >1<
00:38:11 -  ==> Bus Encryption active!
00:38:11 - UnitKeyCount       >1<
00:38:11 -  >>> UnitKeyENC (1) >9628770F2BB8BE2A2820299A2380BC34<
00:38:11 - Analyze dump
00:38:11 - Start to analyze '2018' MemDump now!
00:38:12 - DiscID       >55535475A45362E81DD533E95E00AD3B3CCCCA9D<
00:38:12 - UnitKeyCount >1<
00:38:12 -  >>> UnitKeyDEC (1) >496A2DA2B4D23EA395B0718DF2892BBB<
00:38:12 - BusDecryption is required - try go get ReadDataKey from dump
00:38:12 -  >>> ReadDataKey from dump >E0FD6F915A42ADAE3BB1AE8E2A47A2BA<
00:38:12 -  --- PART 2 --- VALIDATE VUK/UNITKEYS ---
00:38:12 - Drive is detected as 'REAL BLURAY' drive
00:38:12 - M2TS files found >8<
00:38:14 - Potentially invalid UnitKey >496A2DA2B4D23EA395B0718DF2892BBB<
00:38:14 - Unfortunately no candidate to get a correct unit key >496A2DA2B4D23EA395B0718DF2892BBB<
00:38:14 - There are still 8 files that cannot be decoded with the provided unit keys!
00:38:14 - Validation failed - VUK/UnitKeys are INVALID!!!!!!!
00:38:14 - Please report this in the Doom9 forum and attach the logfile!
Please press ENTER or ESC to exit
Old 26th June 2023, 21:31   #652  |  Link
nalor
Hi! Please send me your passkey log:
I see where it's happening - I just don't have an explanation why.
nalor is offline   Reply With Quote
Old 26th June 2023, 21:34   #653  |  Link
nalor
Hmm .. I see that I added limited UHD support back in 2018 .. I'll check if I damaged it somehow .. The validation will never work, so FindVUK should not even try to validate at all ..
Old 26th June 2023, 21:35   #654  |  Link
nalor
Fixed the problem in 1.64, the good news is that DVDfab still allows to read Unitkeys from the dump
Old 26th June 2023, 21:46   #655  |  Link
nalor
Just published 1.64 - no great changes, tested with DVDfab 12.1.0.9 and it's working for me
Old 27th June 2023, 05:01   #656  |  Link
metalsonic88
I'm still having the same issues I was here. I'll post both the output of what FindVUK says and then the log it generated.
Displayed output:
21:47:34 -  ----------- FindVUK 1.64 -----------
21:47:34 - SettingsFile: >C:\Users\Oozer Naym\Downloads\FindVUK_1.59\config\FindVUK.ini<
21:47:34 - Logfile >C:\Users\Oozer Naym\Downloads\FindVUK_1.59\log\2023-06-26_FindVUK.txt< Default Loglevel >2<
21:47:34 - Update enabled - check for update
21:47:35 - No update required
21:47:35 - Open Main-KEYDB file: >C:\ProgramData\aacs\KEYDB.cfg<
21:47:37 - Open Backup-KEYDB file: >C:\Users\Oozer Naym\Downloads\FindVUK_1.59\VUKbackup\KEYDB.cfg<
21:47:37 - DVDfab Version >12.1.0.9< found
21:47:37 -  >>> everything should work as expected!
21:47:37 - Preferred application >PassKey< is not available
21:47:37 - DVDfab is available!
21:47:37 - DVDfab-MainFile:      >C:\Program Files\DVDFab\DVDFab 12\DVDFab64.exe<
21:47:37 - DVDfab-LogFile:       >C:\Users\Oozer Naym\Documents\DVDFab\DVDFab12\Log\dvdfab_internal.log<
21:47:37 - KEYDB-Path:           >C:\ProgramData\aacs\<
21:47:37 - KEYDB-Backup-Path:    >C:\Users\Oozer Naym\Downloads\FindVUK_1.59\VUKbackup\<
21:47:37 - ProcDumpFile:         >C:\Users\Oozer Naym\Downloads\FindVUK_1.59\tool\procdump64.exe<
21:47:37 -  --- PART 1 --- GET DUMP ---
21:47:37 - No running application process discovered
21:47:37 -  >> Start it now >C:\Program Files\DVDFab\DVDFab 12\DVDFab64.exe<
21:47:48 - Drive opened
21:47:48 - Volume Label detected >YU_YU_HAKUSHO_S1_D2<
21:47:49 - DriveLetter detected >F<
21:47:49 - Detected CopyProtections AACS >1< BD+ >0<
21:47:50 - DiscID found >44C863F17120D16C3BBC231D9FF1118AABCD82AB<
21:47:53 - DVDFab64 got Unit Keys - create memdump now!
21:47:53 - Dump successful! >1<
21:47:53 - MemDump successfully finished!
21:47:54 - Dump successful! >1<
21:47:54 - MemDump successfully finished!
21:47:54 - DVDFab64 got Unit Keys - create memdump now!
21:47:55 - Dump successful! >1<
21:47:55 - MemDump successfully finished!
At this point it just hangs indefinitely. It isn't frozen because I can close it, but it just doesn't do anything unless I make it.
Log is available at this pastebin because it's too long:
https://pastebin.com/N35Z7ySA
Old 27th June 2023, 17:00   #657  |  Link
Bahamuth
Transformers worked now somehow:
<?xml version="1.0" encoding="UTF-8"?>
<Bluray>
    <FileType>BlurayMetaXML</FileType>
    <DiscId Date="2021.06.16">55535475A45362E81DD533E95E00AD3B3CCCCA9D</DiscId>
    <DiscType>UHD</DiscType>
    <VolumeId />
    <MediaKey />
    <VolumeUniqueKey />
    <Validated>1</Validated>
    <VolumeLabel>The_Transformers_The_Movie</VolumeLabel>
    <BDplus>0</BDplus>
    <BusEncryptionEnabled>1</BusEncryptionEnabled>
    <MKBrev>76</MKBrev>
    <MainPlaylist>00000.mpls</MainPlaylist>
    <UnitKeys>
        <UnitKey Nr="1" Status="valid">496A2DA2B4D23EA395B0718DF2892BBB</UnitKey>
    </UnitKeys>
    <EncryptedValues>
        <UnitKeysENC>
            <UnitKey Nr="1">9628770F2BB8BE2A2820299A2380BC34</UnitKey>
        </UnitKeysENC>
    </EncryptedValues>
    <MetaTitles>
        <MetaTitle Language="eng">The Transformers: The Movie</MetaTitle>
    </MetaTitles>
    <Hashes>
        <Hash Type="MD5" File="MKB_RO.inf" Size="5242880">454E11CB23DA5E20AC53AB218DB5E99A</Hash>
        <Hash Type="MD5" File="Unit_Key_RO.inf" Size="65536">1C24774826BC1E8723E984222181858F</Hash>
    </Hashes>
    <Application>FindVUK 1.64</Application>
    <VolumeSize>63722618880</VolumeSize>
</Bluray>
Hmm PassKey should basically be a small part of DVDfab. But the current version (9.4.6.1) isn't supported it seems:
17:56:32 - Open Backup-KEYDB file: >C:\apps\backup\FindVUK\VUKbackup\KEYDB.cfg<
17:56:32 - ERROR! Starting with Passkey 9.2.1.2 the VUK is not available im memory any longer!
17:56:32 - Please downgrade to an older Passkey version.
I send you a forum PM with the passkey_log for my other problem.
Old 28th June 2023, 21:52   #658  |  Link
nalor
Please try FindVUK 1.65
I've changed 2 things:
* stop dumping multiple times - although this isn't the real problem in your case it does not make any sense
* do not wait for the main playlist endlessly - now I use a different indicator to detect when we reached the end of the process - and just in case this does not work it should at least reach a timeout after 60 seconds and continue
(this is the real problem in your case)
I did not test myself, so in case it's not working tell me.
I'll test tomorrow
Old 28th June 2023, 21:55   #659  |  Link
nalor
Please also try the 1.65 from the post above - your PM with the log helped a lot! Thanks!
And yes - new Passkey releases do not work any longer
The Unitkeys are not available in the memdump any longer - at least not easily readable.
Old 28th June 2023, 23:43   #660  |  Link
Bahamuth
Then you should at least update the message. 9.4.5.2 is still working as FindVUK states:
00:40:35 - Passkey Version >9.4.5.2< found
00:40:35 -  >>> everything should work as expected!
My Hero Academia Season 5 Part 1 Disc 2: working now, without multiple dumps:
00:41:44 - Drive opened
00:41:44 - Volume Label detected >MyHeroAcademia_S5P1_D2<
00:41:45 - DriveLetter detected >D<
00:41:45 - Detected CopyProtections AACS >1< BD+ >0<
00:41:45 - DiscID found >8D838CB8910FE75C00ADF03270B309A8B2DC6EA2<
00:41:48 - DVDFabPasskey got Unit Keys - create memdump now!
00:41:48 - Dump successful! >1<
00:41:48 - MemDump successfully finished!
00:41:49 - Close Passkey now!
