28th February 2017, 17:34 | #4881 | Link |
--aq 1:
General Format : HEVC Format/Info : High Efficiency Video Coding File size : 2.43 MiB Writing library : x265 2.3+9-820f4327ddac:[Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=600 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=6 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=32 / tu-inter-depth=3 / tu-intra-depth=3 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=5 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-1:-1 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@Main Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Writing library : x265 2.3+9-820f4327ddac:[Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=600 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=6 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=32 / tu-inter-depth=3 / tu-intra-depth=3 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=5 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-1:-1 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt --aq 2: General Format : HEVC Format/Info : High Efficiency Video Coding File size : 4.77 MiB Writing library : x265 2.3+9-820f4327ddac:[Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=600 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=6 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=32 / tu-inter-depth=3 / tu-intra-depth=3 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=5 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-1:-1 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@Main Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Writing library : x265 2.3+9-820f4327ddac:[Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=600 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=6 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=32 / tu-inter-depth=3 / tu-intra-depth=3 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=5 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-1:-1 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt TL;DR: --aq 1: 2.43 MiB --aq 2: 4.77 MiB That's an almost 100% file size increase, what the flux? |
28th February 2017, 17:57 | #4882 | Link |
x265 v2.3+17-6e348252e902 (MSYS/MinGW, GCC 6.3.0, 32 & 64bit 8/10/12bit multilib EXEs)
x265 [info]: HEVC encoder version 2.3+17-6e348252e902 x265 [info]: build info [Windows][GCC 6.3.0][32 bit/64 bit] 8bit+10bit+12bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZCNT BMI2 Code:
https://bitbucket.org/multicoreware/x265/commits/branch/default |
1st March 2017, 15:56 | #4883 | Link |
x265 2.3+17-6e348252e902
Now even finer! Code:
--refine-level <1..10> Level of analyis refinement indicates amount of info stored/reused in save/load mode, 1:least....10:most. Default 5 Not available anymore: Code:
--capture-csp <string> Specify color primaries from bt709, p3d65, bt2020 for the capture device. Default bt709 |
1st March 2017, 20:32 | #4884 | Link | |
CRF values aren't going to be particularly consistent across aq-modes, and you can (with a bucket full of caveats) generally raise CRF with more advanced AQ at similar subjective quality. |
3rd March 2017, 02:26 | #4885 | Link | |||
That's at low bitrate though. At high bitrate it probably doesn't use it much so it probably doesn't matter much. Messing with different settings comes into play more with CQs in the mid-20s and higher. When people use CQ of like 18 or less, that has a lot bigger margin of error. Quote:
I haven't tested Placebo on x265 since the other presets didn't seem overly tuned anyway, (as numerous people have criticized in the past). Quote:
I've been doing A LOT of grain tests with psyrdo and things, and AQ1 seems just plain more consistent. (As expected, I guess.) It's harder to get consistent texture/grain/quality on people's faces etc with AQ2. On a face close-up when someone's talking, the mouth and cheeks have a lot of different color and depth and detail going on, and it's easy to make them look all sorts of wrong. |
5th March 2017, 07:02 | #4886 | Link |
Is it possible to correct the color change between the screen shots below? The first is the source from bluray and the second is using x265 v 2.3+6. I've updated to v2.3+17 with no change...
http://screenshotcomparison.com/comparison/202364 My settings are below which I pulled from MediaInfo. cpuid=1173503 / frame-threads=6 / numa-pools=32 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=1470 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=6 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=24 / keyint=240 / bframes=8 / b-adapt=2 / b-pyramid / bframe-bias=5 / rc-lookahead=40 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=32 / tu-inter-depth=4 / tu-intra-depth=4 / limit-tu=3 / rdoq-level=2 / dynamic-rd=0.00 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=5 / limit-refs=2 / limit-modes / me=3 / subme=3 / merange=26 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=5 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=2.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.65 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=16 / no-rc-grain / qpmax=69 / qpmin=0 / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / aq-motion / no-hdr / no-hdr-opt / Capture-colorprim=3 A side from the coloring I've tried to improve pic quality without just throwing more bits at it. I've tried dozens of tweaks rd, max merge, ref, rect, amp, aq mode, limit-tu, et cetera. Even when I increase the CRF from 21 -> 20 or even 19, it doesn't improve much... Thanks in advance! |
5th March 2017, 08:56 | #4887 | Link | |
x265 really needs to massively improve in details retention in that specific area if it wants to be "taken seriously" compared to other HEVC encoders. The loss of details is so ugly, it makes XviD (aka a 15 years old obsolete codec) look better in those regards. |
5th March 2017, 23:03 | #4889 | Link |
Software Developer
Discussion about Ryzen has been split into a separate thread:
https://forum.doom9.org/showthread.php?t=174383
6th March 2017, 22:16 | #4890 | Link | |
https://forum.doom9.org/showpost.php...postcount=4275 The Y, U and V planes all showed very small "errors" (typically "1"). The error varies from frame to frame, too. I did some experiments of my own and also compared with x264. I discovered that these errors are "normal". x264 does the same. You have to use very high quality settings (CRF 16 or better, if I remember right) to eliminate these shifts. I can't remember, but I think B frames also contribute. I decided: "life's too short". |
7th March 2017, 00:08 | #4892 | Link | |
7th March 2017, 00:09 | #4893 | Link | |
Maybe if MulticoreWare renamed "--tune grain" to "--tune quality", and dumbed-down the manual's explanation of its unique (as in, if you don't use it, you don't get it) rate control and frequency biasing algorithms, more people striving for quality would stop second-guessing the developers over preset construction and start building useful command lines around "--tune quality". So far, the only other person I've seen here who "gets it", is Boulder, and kudos to him for that! |
7th March 2017, 00:19 | #4894 | Link | |
Let's see what we have here: x265.exe --crf 21 --aq-mode 1 --ctu 32 --qg-size 32 --deblock -1:-1 --me star --bframes 4 --rc-lookahead 60 --ref 5 --b-adapt 2 --tu-intra-depth 4 --tu-inter-depth 4 --merange 57 --weightp --weightb --scenecut 40 --rd 4 --limit-ref 3 --limit-modes --tskip --rect --amp --max-merge 5 --subme 5 --b-intra --no-rskip --no-sao --no-strong-intra-smoothing General Format : HEVC Format/Info : High Efficiency Video Coding File size : 2.43 MiB Writing library : x265 2.3+9-820f4327ddac:[Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=600 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=6 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=32 / tu-inter-depth=3 / tu-intra-depth=3 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=5 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-1:-1 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@Main Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Writing library : x265 2.3+9-820f4327ddac:[Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=600 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=6 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=32 / tu-inter-depth=3 / tu-intra-depth=3 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=5 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-1:-1 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt File-size: 2.44MB. Now let's try the same command line but let's add the --tune grain switch shall we? x265.exe --crf 21 --aq-mode 1 --ctu 32 --qg-size 32 --deblock -3:-3 --me star --bframes 4 --rc-lookahead 60 --ref 5 --b-adapt 2 --tu-intra-depth 4 --tu-inter-depth 4 --merange 57 --weightp --weightb --scenecut 40 --rd 4 --limit-ref 3 --limit-modes --tskip --rect --amp --max-merge 5 --subme 5 --b-intra --no-rskip --no-sao --no-strong-intra-smoothing --tune grain General Format : HEVC Format/Info : High Efficiency Video Coding File size : 10.7 MiB Writing library : x265 2.3+17-6e348252e902:[Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=600 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=32 / tu-inter-depth=4 / tu-intra-depth=4 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=5 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / rdpenalty=0 / psy-rd=4.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=1 / stats-write=0 / stats-read=0 / ipratio=1.10 / pbratio=1.00 / aq-mode=0 / aq-strength=1.00 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=32 / rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-optrefine-level=5 Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@Main Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Writing library : x265 2.3+17-6e348252e902:[Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=600 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=32 / tu-inter-depth=4 / tu-intra-depth=4 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=5 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / rdpenalty=0 / psy-rd=4.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=1 / stats-write=0 / stats-read=0 / ipratio=1.10 / pbratio=1.00 / aq-mode=0 / aq-strength=1.00 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=32 / rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-optrefine-level=5 File-size: 10.7MB. So what do we have here? A 2.44MB file for only 300 encoded frames vs. a ~11MB file encode with the --tune grain? I guess I'll stick to not using --tune grain for now and look for optimized cookie-cutter settings until the resulted file size can be shaved off by a good 50% margin with --tune grain. My 2 cents. Edit: For what it's worth, the only differences here are 2.3+9 with -1:-1 deblocking values vs. 2.3+17 with -3:-3 deblocking but if you insist I can run the same encodes again with the same revision and the same deblocking values. Last edited by pingfr; 7th March 2017 at 00:27. |
7th March 2017, 00:55 | #4895 | Link | |
You replace your entire command line with --tune grain (preset/crf/sharpening tweaks aside). That's because --tune grain does NOT operate with the default algorithms (it's in the manual link I posted)! And remember, --tune grain is so good at retaining detail that you can drop both CRF & preset back from whatever your reworked preset parameters required previously. Ultimately, you're going to have to decide what's MOST important to you: speed, size or quality. So far, you're meandering between all of them. You never even mentioned the quality of the output, only size. Besides, none of us can tell what you think "quality" is, anyway. They're your eyes. You want a compromise between all three? Grain can do that too, using nothing more than preset & crf. The very first thing I did when I read "massive improvements to --tune grain" from the press release last year was to encode scenes from 1080p Samsara with: Code:
--preset superfast --crf 28 --profile main10 --tune grain --deblock=-6:-6 --no-strong-intra-smoothing I realised that if --tune grain could help make output that "good" ("not awful" is more accurate) at settings that SHOULD have produced genuinely awful results, then the only way was up. EDIT: A picture (or two) is worth a thousand words. Go here: http://screenshotcomparison.com/comparison/202693 Yes, that's the 4k Yacht Ride sample from http://ultravideo.cs.tut.fi/#testsequences I used my exact "low quality" command line from above. Comparison #1 is the Raw YUV against x265 Superfast CRF28 --tune grain Comparison #2 is the Raw YUV against x265 Superfast CRF28 without --tune grain (the only change) If that doesn't demonstrate not only everything I've been saying, but everything the manual has been saying for the past 9 months, then I don't know what else to say, except... There are effectively TWO x265's: the default one that biases Compression-Over-Quality, and the --tune grain one that biases Quality-Over-Compression. Like it or not, that's the way it is, and the "quality" problem you're complaining about was solved 9 months ago. Last edited by WhatZit; 7th March 2017 at 05:11. Reason: ScreenShot Comparison |
7th March 2017, 04:52 | #4896 | Link |
So is it the case, then, that using --tune grain invokes internal code that is not otherwise accessible by using sane and personalized options based on the specific content?
For example: I have a lot SD discs and sets that are not available in HD, and some of those have film from the 70's. In my experiments I have found that I was looking at options such deblock -3:-3, no-sao, and AQ 3. I have no trouble choosing slow or slower, and a CRF of 18. So would it then be the case that by choosing --tune grain I probably wouldn't need to toy with these options, or any of the other myriad of options that are available, because --tune grain uses different routines, not just a different baseline of settings? |
7th March 2017, 05:09 | #4897 | Link | |
Basically, grain265 (need a shorthand way of saying it) "thinks" differently than the default regime. Whether --rc-grain can actually be used outside of the tuning is something I've never experimented with. The developers "highly recommend" against it. Sure, you can still fiddle with traditional options, but, as a starting point for producing quality encodes, you simply can't go past grain. Last edited by WhatZit; 7th March 2017 at 05:17. Reason: Bloody Copy/Paste URL Error |
7th March 2017, 05:16 | #4898 | Link | |
y4m [info]: 1920x1080 fps 30/1 i420p8 frames 0 - 599 of 600 raw [info]: output file: grainsuperfast.hevc x265 [info]: HEVC encoder version 2.3+17-6e348252e902 x265 [info]: build info [Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZCNT BMI2 x265 [warning]: Rc Grain removes qp fluctuations caused by aq/cutree, Disabling aq,cu-tree x265 [info]: Main profile, Level-4 (Main tier) x265 [info]: Thread pool created using 8 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 3 / wpp(34 rows) x265 [info]: Coding QT: max CU size, min CU size : 32 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 57 / 1 / 2 x265 [info]: Keyframe min / max / scenecut / bias: 25 / 250 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 10 / 3 / 0 x265 [info]: b-pyramid / weightp / weightb : 1 / 0 / 0 x265 [info]: References / ref-limit cu / depth : 1 / off / off x265 [info]: Rate Control / qCompress : CRF-21.0 / 0.60 x265 [info]: tools: rd=2 psy-rd=4.00 early-skip signhide tmvp fast-intra x265 [info]: tools: lslices=6 deblock(tC=-1:B=-1) x265 [info]: frame I: 3, Avg QP:21.33 kb/s: 28086.08 x265 [info]: frame P: 149, Avg QP:23.05 kb/s: 10469.61 x265 [info]: frame B: 448, Avg QP:23.05 kb/s: 3873.64 x265 [info]: consecutive B-frames: 0.7% 1.3% 0.7% 97.4% encoded 600 frames in 26.86s (22.33 fps), 5632.71 kb/s, Avg QP:23.04 General Format : HEVC Format/Info : High Efficiency Video Coding File size : 13.4 MiB Writing library : x265 2.3+17-6e348252e902:[Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=600 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=1 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=3 / b-adapt=0 / b-pyramid / bframe-bias=0 / rc-lookahead=10 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=2 / limit-refs=0 / no-limit-modes / me=1 / subme=1 / merange=57 / temporal-mvp / no-weightp / no-weightb / no-analyze-src-pics / deblock=-1:-1 / no-sao / no-sao-non-deblock / rd=2 / early-skip / no-rskip / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=4.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=1 / stats-write=0 / stats-read=0 / ipratio=1.10 / pbratio=1.00 / aq-mode=0 / aq-strength=0.00 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=32 / rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-optrefine-level=5 Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@Main Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Writing library : x265 2.3+17-6e348252e902:[Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=600 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=1 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=3 / b-adapt=0 / b-pyramid / bframe-bias=0 / rc-lookahead=10 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=2 / limit-refs=0 / no-limit-modes / me=1 / subme=1 / merange=57 / temporal-mvp / no-weightp / no-weightb / no-analyze-src-pics / deblock=-1:-1 / no-sao / no-sao-non-deblock / rd=2 / early-skip / no-rskip / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=4.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=1 / stats-write=0 / stats-read=0 / ipratio=1.10 / pbratio=1.00 / aq-mode=0 / aq-strength=0.00 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=32 / rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-optrefine-level=5 13.4MB... no thanks! |
7th March 2017, 05:26 | #4900 | Link | |
Try CRF28. EDIT: I made a CRF21 version of the YachtRide sample, only changing my "low quality" command line above from --crf 28 to --crf 21: CRF21 = 26.7Mb CRF28 = 10.7Mb The CRF21 version is subjectively 5-10% better quality than the CRF28 version, which is not worth the 250% file size. Or, is it...? So, yes, you need to rethink how presets & CRF work under grain265. Last edited by WhatZit; 7th March 2017 at 06:07. Reason: CRF21 Comparison |
