2nd January 2015, 06:51 | #22094 | Link |
Happy New Year! Jdobbs!
Please forgive me for my poor English! I'm Chinese. I have a confusing tsMuxer problem about ts muxing with "overlapped frame detected at position. Remove frame". "The Amazing Spider-Man 2 2014 BluRay 1080p AVC DTS-HD MA5.1-CHDBits" the disc has several m2ts. If I mux by adding playlist, the overlapped frames can be detected. Code:
Network Optix tsMuxeR. Version 2.6.12. www.networkoptix.com Decoding H264 stream (track 1): Profile: High@4.1 Resolution: 1920:1080p Frame rate: 23.976 H.264 muxing fps is not set. Get fps from stream. Value: 23.976 Decoding DTS-HD stream (track 2): Bitrate: 1536Kbps core + MLP data.Sample Rate: 48KHz Channels: 5.1 (DTS Master Audio) DTS-HD stream (track 2): overlapped frame detected at position 00:00:36,042. Remove frame. DTS-HD stream (track 2): overlapped frame detected at position 01:43:27,210. Remove frame. DTS-HD stream (track 2): overlapped frame detected at position 02:14:19,680. Remove frame. Processed 203670 video frames Flushing write buffer Mux successful complete Muxing time: 9 min 58 sec Code:
Network Optix tsMuxeR. Version 2.6.12. www.networkoptix.com Decoding H264 stream (track 1): Profile: High@4.1 Resolution: 1920:1080p Frame rate: 23.976 H.264 muxing fps is not set. Get fps from stream. Value: 23.976 Decoding DTS-HD stream (track 2): Bitrate: 1536Kbps core + MLP data.Sample Rate: 48KHz Channels: 5.1 (DTS Master Audio) Processed 203670 video frames Flushing write buffer Mux successful complete Muxing time: 8 min 41 sec Thank you for your great work and best wishes to you!!! Last edited by tekkenbest; 2nd January 2015 at 06:55. |
2nd January 2015, 18:51 | #22095 | Link |
When there is more than one part to a stream, the audio is muxed into each part. Since the audio has to match the video -- but doesn't necessarily align exactly -- sometimes a duplicate audio frame is found at the beginning of a part. When TSMUXER does the muxing from an MPLS, it knows that the audio is contiguous, so it can recognize duplicates. That wouldn't necessarily be true when you add M2TS files individually (they may not even be a part of the same playlist). I'm guessing the reason why you don't detect a difference is because the audio frames are very small, and the repeated frame isn't enough to be notice.
3rd January 2015, 23:44 | #22096 | Link |
Movie and menu only problem
Hi guy's I haven't done encoding for quite a while,now started again and I tried a couple of movies Blu-Ray and the first Blu-Ray Itried Movie and menu Blank extra went O.K. But the second wasDawn of the planet of the Apes does not play in my sony BDP S-6200. Ikeep only french audio and subtitle I run windows 7 64 bit and I have the 2a version installed LAVFilters. I rip with any dvd.
5th January 2015, 16:36 | #22097 | Link |
BdRebuilder 3D Problems with Dune303D
Hi, at first sorry for my bad english.
I have a problem with the 3D ISO establishes by the BDRebuilder. If I play the ISO-3D on my media player "Dune303D" the image is incorrectly (see pictures). When I change from 3D to 2D, then the error is gone. When I Burn the 3D-ISO of a BD and play on my Samsung BD3D-Player, then there are no problems. But the Dune303D is NOT defective, because 3D ISO made with Scenarist BD 3D render no problems. Can someone help me? Thanks and greetings from Germany [IMG] [/IMG][IMG][/IMG] [Options] VERSION=0.50.0.1 ENCODER=0 OUTPUT_3D_ISO=1 MODE=3 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=1 AUDIO_TO_KEEP=deu;ita; SUBS_TO_KEEP=ger;ita; SD_CONVERT=0 OPEN_GOP=1 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=1 DEINTERLACE=1 SD_TO_1080=1 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 DECODER=0 AVCHD=1 REMOVE_WORKFILES=1 REMOVE_OUTPUT=1 USE_FILTERS=0 BDMV_CERT_ONLY=1 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=800 MOVIEONLY_TYPE=11 ALTCRF=19 ALT_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=0 TARGET_SIZE=800 [01.05.15] Checking System Settings - BD-Rebuilder v0.50.01 - Windows Version: 6.2 [9200] - Working Path Free Space: 783,88GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [01.05.15] Systems Settings Check complete Last edited by magnexx; 5th January 2015 at 16:45. |
7th January 2015, 01:00 | #22098 | Link |
This was asked over at MyCE and I didn't have an answer for them. Is it possible to make a half SBS 3D MKV file using BD Rebuilder and H264? There is an option for this using HEVC, but he wasn't sure Plex could handle this type of file.
7th January 2015, 04:06 | #22100 | Link |
This is not a bug report but... The HSBS MKV's BD-Rebuilder has made for me play fine using Plex on my Fire TV Stick, and I use the TV's menu to manually select 3D SBS mode.
