Old 24th February 2008, 01:33   #41  |  Link
laserfan
Aging Video Hobbyist
OK here are the images again; this first is using VAQ:
The next one is w/AQ unchecked; it looks washed-out. Sorry for getting this wrong the first time!
I will report again later after I've had a chance to look at these on my media player/10' wide screen!
laserfan is offline   Reply With Quote
Old 24th February 2008, 03:42   #42  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
That's because you opened both at once in two separate media players, but since only one could use the overlay renderer, the other didn't get the proper TV->PC brightness level conversions.
It has absolutely nothing to do with Xvid or AQ.
Old 24th February 2008, 04:53   #43  |  Link
laserfan
Oh my; that would never have occurred to me. I haven't looked at the vids outside of Media Player Classic yet, but I have no doubt you are correct about this, because indeed, in order to make certain I selected the same frame for comparison/screenshot, I opened two incidences of MPC!
Sorry for the bandwidth!
:veryembarrassed:
I guess at least I can take some solace re: how my original post was "wrong"--I simply opened in a different sequence each time.
Old 27th February 2008, 11:23   #44  |  Link
20-40
20-40's Avatar
Originally Posted by Dark Shikari View Post
check off the Adaptive Quantization box
I feel stupid, because I cannot see any changes neither in file sizes or quality.
Because I've never grasped concept of some people's ON and OFF, be so kind and tell me what "check off" in your sentence means. Marked box or not? You know... is it yes... or not...
UN-checked or checked as un-marked and - marked.
Have fun!
Later, for sure.
Thanks in advance.
20-40 is offline   Reply With Quote
Old 27th February 2008, 12:19   #45  |  Link
Brother John
(schein)heilig
Brother John's Avatar
For VfW: Enable “Adaptive Quantization”
For Encraw: Add -lumimasking to CLI
Brother John
When lost in BeSweet's options, have a look at the Commandline Reference.
DVD nach MPEG-4 klappt nicht? Verzweifelt? Auf zum Encodingwissen!
Brother John is offline   Reply With Quote
Old 27th February 2008, 13:24   #46  |  Link
20-40
20-40's Avatar
So... in this case OFF means ON - as YES, as "marked", as checked.
Thanks brother, it's nice to see that off means yes.
OK, "radio" box of “Adaptive Quantization” stays enabled, as always.
Encraw will chew later on.
"Saying: Go to this people, and say to them: With the ear you shall hear, and shall not understand; and seeing you shall see, and shall not perceive."
Old 27th February 2008, 22:32   #47  |  Link
Ranguvar
Ranguvar's Avatar
Cool saying
Ranguvar is offline   Reply With Quote
Old 28th February 2008, 01:51   #48  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
already heard that saying... it's religion related...
however, i think VAQ can be more effective with quantization matrices like 6of9 and similar purpouse matrices...
Old 28th February 2008, 10:18   #49  |  Link
20-40
20-40's Avatar
Maybe it is, Sharky, I've added this saying as absolutely relevant to my previous post - namely - and if you can pass personal "connotations" in it - it IS about UNDERSTANDING and PERCEPTION, two most valid things in this matter.
Next time, look without filtering, it was uncalled for, sayings as this one have been part of our civilization log before we were born. So respected man and Doom's forum member, as you are, don't need someone as me to tell you that.
Old 19th March 2008, 07:24   #50  |  Link
Gromozeka
dark Shikari you is hero!
Thank you very much/ i'm testing your VAQ - its perfect
XviD forever! You can continue this proekt?
Gromozeka is offline   Reply With Quote
Old 19th March 2008, 07:50   #51  |  Link
Dark Shikari
x264 developer
Well I don't care much about Xvid, so... perhaps if someone else feels like looking at it, or advising me on a bit more about Xvid's internals with regards to dquant
Old 22nd March 2008, 04:30   #52  |  Link
Ranguvar
Ranguvar's Avatar
The only possible way of improving VAQ, at least IMHO, would be to implement a sort of rough detection of text, so advanced subtitles could look better. Probably some weighting that if the possible text is near the bottom of the video, it is more likely to be text.
To me, especially with stylized anime subtitles, clean subs are very important.
Minor, and will most likely be shot down, but I'll throw it out there just in case.
Old 22nd March 2008, 04:34   #53  |  Link
Dark Shikari
x264 developer
I have an improvement of VAQ in the works... it may improve ringing on edges while keeping most of the benefit now
Of course, if you want clean subs, just use softsubs, seriously
Old 22nd March 2008, 17:00   #54  |  Link
Gromozeka
Dark shikari
Speak that will be new AQ - 2.0?
It's true?
But XviD will be have AQ 2.0?
Old 23rd March 2008, 01:11   #55  |  Link
plugh
A hollow voice says
Xvid has really really nasty restrictions on quantizers. From what I recall:
1. A "DQuant" block is a block that has a different quantizer from the previous block. In the case of VAQ, this would be an edge block, for example.
2. DQuant blocks cannot have a difference of more than +/- QP from the frame QP (I think).
3. DQuant blocks cannot use 4mv. (WTF? Why?)
4. DQuant blocks cannot use GMC. (WTF? Why?)
Over in the HVS plugin thread, similar comments were made about AQ
Disadvantages
needs bitrate (2 bits per block)
limits modes for motion estimation
the quantizers of neighbouring blocks may only differ by two
works not woth B-frames
Is there a definitive reference on the above?
Point three in particular, since 4MV is on by default for basically all the profiles. Which takes precedence? Is a block coded with MODE_INTER4V precluded from dquant? Or does dquant force interv4 off?
I scanned through the code looking for both elements 'together', and find stuff like:
encoder.c/MBSetDquant
			if (next->mode != MODE_INTER4V && next->mode != MODE_NOT_CODED)
				/* mode allows dquant change in the future */
				if (abs(next->quant - prev->quant) <= 2) {
					/* quant change is not out of range */
estimation_pvop.c/ModeDecision_SAD and SearchP
estimation_rd_based.c/xvid_me_ModeDecision_RD
	int inter4v = (VopFlags & XVID_VOP_INTER4V) && (pMB->dquant == 0);
It sort of looks like AQ inhibits 4MV - on sort of a block by block basis? (excluding b-frames of course, which AQ doesn't apply to?)
plugh is offline   Reply With Quote
Old 23rd March 2008, 01:27   #56  |  Link
Dark Shikari
x264 developer
Yes, since a dquant block cannot have 4MV.
Old 24th March 2008, 22:49   #57  |  Link
Ranguvar
Ranguvar's Avatar
Awesome! As for the softsubs comment, pretty much the only reason I use Xvid nowadays is for hardware players... and those tend not to have soft-sub support. When I do make backups of stuff for PC viewing, it's x264 MKV with ASS softsubs
Old 26th March 2008, 13:06   #58  |  Link
plugh
A hollow voice says
a bit of a tangent, but did anything ever come of this?
New lumimasking code from ReferenceDivX
Old 28th March 2008, 09:20   #59  |  Link
ToS_Maverick
x264 Tester
out of interest: are you able in MPEG4 ASP to change the quant. matrix on a frame/gop basis like in MPEG2?
if so, you could lower the matrix in cricital areas with VAQ.
ToS_Maverick is offline   Reply With Quote
Old 28th March 2008, 13:03   #60  |  Link
squid_80
Technically no but it is possible with avi and the xvid decoder (not sure about divx) will handle it ok.
squid_80 is offline   Reply With Quote
xvid aq, xvid vaq
