3rd August 2009, 07:32 | #21 | Link | ||
x264 developer
It naturally does a whole lot of these sort of things in addition to the obvious effect of locally optimal qcomp. |
3rd August 2009, 07:56 | #23 | Link |
C# Addict
Sorry for my noobness
I use AviDemux so I need to compile libx264 DLL with this patch ... Can somebody point me to the right direction ? Edit : Found It ! Last edited by TheImperial2004; 3rd August 2009 at 08:22. |
3rd August 2009, 07:57 | #24 | Link | |
x264 developer
Or do it right and use softsubs |
3rd August 2009, 08:02 | #25 | Link | |
Suptitle, MediaPlayer.NET
And, it's only for a few seconds of the movie. Is this patch going to be incompatible with vbv-buf max / b-pyramid etc. or is it only temporarily as they get implemented? Last edited by Zachs; 3rd August 2009 at 08:05. |
3rd August 2009, 08:09 | #26 | Link | ||||
Doesn't seem to increase ssim on this test.
source = ep 5 of band of brothers. Blu-ray source. Quote:
http://www.7-zip.org/ Last edited by Audionut; 3rd August 2009 at 10:37. |
3rd August 2009, 08:14 | #27 | Link | |
x264 developer
VBV may be a trickier issue; it technically "works" but the row-based prediction completely falls apart with MB-tree despite the support code I wrote for it, causing serious quality loss, especially in 1-pass VBV. It'll take some investigation to figure out exactly what's wrong and whether it could be fixed or not. |
3rd August 2009, 09:41 | #31 | Link | ||||
Same source as ssim test.
http://www.7-zip.org/ Last edited by Audionut; 3rd August 2009 at 09:46. |
3rd August 2009, 10:23 | #32 | Link | ||
x264_x86_r1195_juGGaKNot
GCC 4.4.0 generic, fprofiled, patched Code:
Source: x264 GIT Applied patches : x264_win_zone_parse_fix_05.diff x264_Macroblock_Tree_Ratecontrol_01.diff Please check Doom9.org patches thread, Doom9.org Macroblock tree Ratecontrol thread and GIT shortlog for more info. Compiled by juGGaKNot on August 03-2009, 11:20:00 GMT with GCC 4.4.0 on Windows XP SP-2 32-bit. Platform: X86 System: MINGW asm: yes avis input: yes mp4 output: no pthread: yes debug: no gprof: no PIC: no shared: no visualize: no --preset juggaknot vs --preset juggaknot --mbtree --lookahead 100. no mbtree : Quote:
Encoding X264 1st Pass : avis [info]: 1184x666 @ 40.00 fps (223 frames) x264 [warning]: width or height not divisible by 16 (1184x666), compression will suffer. x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Slow x264 [info]: profile High, level 4.0 x264 [info]: slice I:2 Avg QP:24.81 size: 12698 x264 [info]: slice P:103 Avg QP:21.88 size: 19737 x264 [info]: slice B:118 Avg QP:23.60 size: 9047 x264 [info]: consecutive B-frames: 14.0% 31.7% 40.7% 9.0% 4.5% x264 [info]: mb I I16..4: 58.0% 37.5% 4.4% x264 [info]: mb P I16..4: 9.7% 21.0% 1.4% P16..4: 43.0% 10.4% 8.1% 0.1% 0 .1% skip: 6.1% x264 [info]: mb B I16..4: 1.3% 2.5% 0.3% B16..8: 40.9% 1.8% 2.3% direct: 6.7% skip:44.4% L0:49.1% L1:46.6% BI: 4.2% x264 [info]: final ratefactor: 21.43 x264 [info]: 8x8 transform intra:63.5% inter:82.5% x264 [info]: direct mvs spatial:98.3% temporal:1.7% x264 [info]: coded y,uvDC,uvAC intra:46.6% 40.1% 9.2% inter:24.7% 14.8% 2.1% x264 [info]: ref P L0 63.9% 12.0% 9.0% 3.8% 2.5% 2.3% 2.5% 1.7% 1.2% 1. 1% x264 [info]: ref B L0 71.9% 10.1% 7.6% 2.3% 2.1% 2.0% 1.4% 1.3% 1.4% x264 [info]: kb/s:4485.6 encoded 223 frames, 0.26 fps, 4488.52 kb/s Encoding X264 2nd Pass : avis [info]: 1184x666 @ 40.00 fps (223 frames) x264 [warning]: width or height not divisible by 16 (1184x666), compression will suffer. x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Slow x264 [info]: profile High, level 4.0 x264 [info]: slice I:2 Avg QP:23.30 size: 13949 x264 [info]: slice P:103 Avg QP:23.50 size: 16439 x264 [info]: slice B:118 Avg QP:25.47 size: 7667 x264 [info]: consecutive B-frames: 14.0% 31.7% 40.7% 9.0% 4.5% x264 [info]: mb I I16..4: 53.0% 42.3% 4.7% x264 [info]: mb P I16..4: 10.7% 19.1% 1.1% P16..4: 44.2% 7.5% 8.3% 0.1% 0 .1% skip: 9.0% x264 [info]: mb B I16..4: 1.3% 2.3% 0.2% B16..8: 38.3% 1.5% 1.8% direct: 6.0% skip:48.6% L0:49.8% L1:46.5% BI: 3.7% x264 [info]: 8x8 transform intra:60.7% inter:86.5% x264 [info]: direct mvs spatial:98.3% temporal:1.7% x264 [info]: coded y,uvDC,uvAC intra:41.5% 34.6% 6.7% inter:21.3% 12.0% 1.5% x264 [info]: ref P L0 63.8% 12.1% 9.1% 3.9% 2.5% 2.2% 2.6% 1.8% 1.1% 1. 0% x264 [info]: ref B L0 70.1% 11.2% 7.7% 2.3% 2.3% 2.1% 1.5% 1.4% 1.3% x264 [info]: kb/s:3768.0 encoded 223 frames, 0.30 fps, 3770.96 kb/s Muxing X264 : AVC-H264 import - frame size 1184 x 666 at 40.000 FPS Import results: 223 samples - Slices: 2 I 103 P 118 B - 1 SEI - 2 IDR IsoMedia import - track ID 1 - Audio (SR 44100 - 2 channels) Saving C:\x264\Movie_2D\Movie_X264_2D.mp4: 0.500 secs Interleaving Encoding started at 11:20 AM and finished at 11:47 AM Code:
Encoding X264 1st Pass : avis [info]: 1184x666 @ 40.00 fps (223 frames) x264 [warning]: width or height not divisible by 16 (1184x666), compression will suffer. x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Slow x264 [info]: profile High, level 4.0 x264 [info]: slice I:2 Avg QP:24.39 size: 13165 x264 [info]: slice P:103 Avg QP:21.71 size: 20739 x264 [info]: slice B:118 Avg QP:24.23 size: 8159 x264 [info]: consecutive B-frames: 14.0% 31.7% 40.7% 9.0% 4.5% x264 [info]: mb I I16..4: 59.7% 35.2% 5.1% x264 [info]: mb P I16..4: 10.6% 20.4% 1.3% P16..4: 42.2% 11.6% 8.2% 0.1% 0 .1% skip: 5.5% x264 [info]: mb B I16..4: 1.3% 2.4% 0.3% B16..8: 39.8% 1.7% 2.0% direct: 6.0% skip:46.4% L0:51.9% L1:43.9% BI: 4.2% x264 [info]: final ratefactor: 17.72 x264 [info]: 8x8 transform intra:61.3% inter:82.0% x264 [info]: direct mvs spatial:98.3% temporal:1.7% x264 [info]: coded y,uvDC,uvAC intra:44.3% 38.5% 9.0% inter:24.0% 14.8% 2.7% x264 [info]: ref P L0 62.1% 12.8% 9.4% 4.0% 2.5% 2.4% 2.7% 1.9% 1.3% 1. 1% x264 [info]: ref B L0 71.4% 9.9% 8.3% 2.2% 2.1% 2.0% 1.4% 1.3% 1.4% x264 [info]: kb/s:4484.7 encoded 223 frames, 0.29 fps, 4487.58 kb/s Encoding X264 2nd Pass : avis [info]: 1184x666 @ 40.00 fps (223 frames) x264 [warning]: width or height not divisible by 16 (1184x666), compression will suffer. x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Slow x264 [info]: profile High, level 4.0 x264 [info]: slice I:2 Avg QP:23.41 size: 14636 x264 [info]: slice P:103 Avg QP:22.56 size: 18846 x264 [info]: slice B:118 Avg QP:25.26 size: 7304 x264 [info]: consecutive B-frames: 14.0% 31.7% 40.7% 9.0% 4.5% x264 [info]: mb I I16..4: 50.4% 44.5% 5.1% x264 [info]: mb P I16..4: 11.3% 19.7% 1.1% P16..4: 43.2% 9.4% 8.3% 0.1% 0 .1% skip: 6.9% x264 [info]: mb B I16..4: 1.3% 2.3% 0.2% B16..8: 37.4% 1.5% 1.8% direct: 5.7% skip:49.7% L0:52.3% L1:43.8% BI: 3.9% x264 [info]: 8x8 transform intra:60.3% inter:85.3% x264 [info]: direct mvs spatial:99.2% temporal:0.8% x264 [info]: coded y,uvDC,uvAC intra:41.6% 35.3% 6.9% inter:22.1% 13.2% 2.3% x264 [info]: ref P L0 61.9% 13.1% 9.3% 4.1% 2.6% 2.2% 2.7% 1.8% 1.2% 1. 0% x264 [info]: ref B L0 70.1% 10.5% 8.5% 2.2% 2.3% 2.2% 1.5% 1.4% 1.3% x264 [info]: kb/s:4064.2 encoded 223 frames, 0.30 fps, 4067.11 kb/s Muxing X264 : AVC-H264 import - frame size 1184 x 666 at 40.000 FPS Import results: 223 samples - Slices: 2 I 103 P 118 B - 1 SEI - 2 IDR IsoMedia import - track ID 1 - Audio (SR 44100 - 2 channels) Saving C:\x264\Movie_2D\Movie_X264_2D.mp4: 0.500 secs Interleaving Encoding started at 11:50 AM and finished at 12:15 PM but x264 [info]: slice I:2 Avg QP:24.81 size: 12698 x264 [info]: slice P:103 Avg QP:21.88 size: 19737 x264 [info]: slice B:118 Avg QP:23.60 size: 9047 x264 [info]: final ratefactor: 21.43 vs x264 [info]: slice I:2 Avg QP:24.39 size: 13165 x264 [info]: slice P:103 Avg QP:21.71 size: 20739 x264 [info]: slice B:118 Avg QP:24.23 size: 8159 x264 [info]: final ratefactor: 17.72 Is normal ? final ratefactor smaller by 4 almost ? Also the mbtree build seems to ignore param->rc.f_qcompress = 1.0f; param->rc.f_pb_factor = 1.1f; Does not show up in the mediainfo window, ipratio does. |
3rd August 2009, 10:35 | #34 | Link |
what about the results ?
but x264 [info]: slice I:2 Avg QP:24.81 size: 12698 x264 [info]: slice P:103 Avg QP:21.88 size: 19737 x264 [info]: slice B:118 Avg QP:23.60 size: 9047 x264 [info]: final ratefactor: 21.43 vs x264 [info]: slice I:2 Avg QP:24.39 size: 13165 x264 [info]: slice P:103 Avg QP:21.71 size: 20739 x264 [info]: slice B:118 Avg QP:24.23 size: 8159 x264 [info]: final ratefactor: 17.72 Is normal ? final ratefactor smaller by 4 almost ? |
3rd August 2009, 10:38 | #35 | Link | |
x264 developer
If you want to make a meaningful comparison, at a minimum compare SSIM or something like that? |
3rd August 2009, 10:57 | #36 | Link |
MPC-HC Project Manager
Does any other h264 encoder have a feature like this?
Does this have any influence on the decode difficulty? EDIT: And that really low bitrate anime example is simply amazing...
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
3rd August 2009, 11:00 | #37 | Link |
x264 developer
Almost surely not.
Follow x264 development progress | akupenguin quotes | x264 git status ffmpeg and x264-related consulting/coding contracts | Doom10 Last edited by Dark Shikari; 3rd August 2009 at 17:39. |
3rd August 2009, 11:09 | #38 | Link |
Here is a silly question!!
How fast does the motion have to be, to be affected by this patch?
http://www.7-zip.org/ |
3rd August 2009, 11:16 | #39 | Link | ||
lookahead 100 only taked 335 mb on my xp
lookahead 200 crashed ( 236 frames source ) ---pass 1 --slow-firstpass --preset slow --tune ssim --mbtree --lookahead 100 --ssim --bitrate 2000 : Quote:
3rd August 2009, 11:19 | #40 | Link |
i was wonder the same, image a scene like the killa sample (the one from BBC where the flock of birds fly over the moving and reflective sea), would this patch "kill" it or help it.
development, testing, x264 |
