14th January 2010, 20:12 | #10301 | Link | |
@Blight
http://en.wikipedia.org/wiki/Unified...D_enabled_GPUs For NVIDIA Cards: http://en.wikipedia.org/wiki/Nvidia_..._.28HD.29_GPUs
Cheers, The REAL Joe |
14th January 2010, 21:56 | #10303 | Link | |
MPC-HC filter behaves differently for each splitter, I'm hoping for a better solution: I hope a common ground can be reached on how the splitter should behave. (reorder B frames or not). however, I'm not sure I have a full understanding of the issue at hand, please correct me if I'm wrong in any way. Regards, Tal |
14th January 2010, 22:09 | #10304 | Link |
albain,
you may already know this, but: 1. I think the colorspace in the flat DXVA decoded buffer is NV12: 8-bit Y plane followed by an interleaved U/V plane with 2x2 subsampling. however, it seems that each plane is drawn in blocks, I had some experience with a similar format in the past, so I can try to help in deciphering the format if all else fails. 2. I'm not sure what's the best route to convert it to FFDShow. 3. It would be indeed best to "templetize" the copy mechanism, so you could use SSE 4 / SSE 2 / memcpy, I don't know how, but I think that there are a few examples already in ffdshow. sorry for not being of more assistance, Tal Last edited by tal.aloni; 14th January 2010 at 22:15. |
15th January 2010, 08:53 | #10305 | Link |
Didée Fan
Your welcome. I have updated the wiki again; this time I described how to build icl11 builds.
link And to clsid, visual studio pro as described by me in the wiki can compile kerneldeint, tomsmocomp, xvidcore. libmpeg2. I will post my ffdshow I build today, 3202 using SE't patch and where visual studio built kerneldeint, libmpeg2, tomsmocomp, xvidcore, so you can test it to see if it's ok and the wiki is fine since my build is fine. link
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. |
15th January 2010, 09:27 | #10306 | Link | |
Media Control author
I hope that we can use others with DXVA. But for the moment indeed I assume that we have NV12 buffers 2. I have made a patch. Here is the link. I cannot test it because I am at work and my laptop does not support dxva. The project file is updated because a new macro (DXVA_INSIDE_FFDSHOW) adds DXVA decoding and dialogs inside FFDSHow video filter. I have copied the decompress method from TvideoCodecLibavcodec and splitted into 2 methods . The processFrame method is called at the end (after DXVA or software decoding for a given frame) and from the AVFrame (frame) will analyze it and create a TffPict (uncompressed picture) to process it through the FFDShow internal filters. What I have done is to fill the AVFrame structure with the DXVA buffers that I have copied back from the GPU. I took my inspiration from TvideoCodecUncompressed class that received flat uncompressed buffers too. Then it should work. This should work but what I am not sure about what the MPC patch affect or not : there may be some missing parameters in the AVFrame (I have set a few such as the pix_fmt, the type of frame). If you have time to review the patch thank you ! |
15th January 2010, 10:13 | #10307 | Link | |
Didée Fan
One build using the visual 2008 compiler the other one uses msys, both built in xp mce. Code:
icl 11, 3202, vmr7, 720p, libmpeg2 built in msvc user: 5 kernel: 3 total : 8 real: 91 fps: 492.7 dfps: 47.7 icl 11, 3202, vmr7, 720p, libmpeg2 built in gcc msys user: 5 kernel: 3 total : 8 real: 89 fps: 500.7 dfps: 48.8 Code:
Codecs tab Set Mpeg2 to Libmpeg2, and check "DVD decoding". Set Avisynth to Avisynth, Raw video to All supported Subtitles tab, Unchecked Uncheck "Decode closed captions" Uncheck "Accept embedded subs" Uncheck "Accept SSA, ASS, ASS2 Subtitle (experimental) Vobsub subpage, uncheck Vobsub Enable. Avisynth tab checked YV12 checked, Add FFdshow Video source Unchecked, 3:2 Pulldown box: Ignore Pulldown checked, check Buffer back/Ahead: 3, 3 setmtmode(2) Last=ffdshow_source() setmemorymax(550) setmtmode(2) a= last b=a.Spresso() SeeSaw(a,b) LimitedSharpenFaster(strength=11) LimitedSharpenFaster(strength=11) distributor() Resize & aspect tab checked Process whole image checked Specify horizontal and vertical Resize: 1280, 720 Process Pixel aspect ratio internally checked No aspect ratio correction checked spline Luma Sharpen: 0.00 Luma Guassian Blur 0.50 Accurate rounding checked Output tab rgb32 checked high quality yv12 to rgb conversion checked rgb conversion tab ycbcr: itu-bt 601 high quality yv12 to rgb conversion checked Dithering checked contrast: standard Output levels: Tv/Projector ffdshow libmpeg2 built using msys ffdshow libmpeg built using msvc
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. Last edited by Jeremy Duncan; 15th January 2010 at 10:16. |
15th January 2010, 23:09 | #10308 | Link |
Hey there guys, I could really do with some help.
I'm using win 7 32bit and i'm trying to use FFDShow Video to decode both SD Live TV and BBC HD. I've disabled the M$ DVD-DTV video and audio decoders along with the MP3 one. I've set merit of FFDShow to max in Radlight filter manager. In the FFDShow Video Config, I have set MPEG2 to libmpeg2 and MPEG in AVI to libmpeg2 and Raw Video to all Supported. Im using graph studio and remotely connecting to win7MCE, I'm using a DVB-S2 TV Card, but for the life of me FFDShow can't be inserted into the graph for MPEG2 streams or the h264 stream. Graphstudio simply refuses to insert the FFDShow Video Filter. Have I missed something or is FFDShow not compatible with live TV in win7. Any help would be greatly appreciated. Many Thanks Dave |
16th January 2010, 05:05 | #10309 | Link | |
Didée Fan
Reading the diff file it goes into the folder where the ffdshow_2008.vcproj is? And I would build ffdshow_2008.vcproj not ffdshow_2008.sln? May I ask that you supply a patch that's built with the sln version as I know I can do that easily?
16th January 2010, 09:01 | #10310 | Link |
@Jeremy,
1. Thanks for the offer, but the patch is not doing anything significant right now, it was only meant for review. @everyone unfortunately, the reading speed of the decoded DXVA frame is not fast enough to process 720p24 on CPUs without SSE 4.1, so Phenom, Athlon and Pentium 4 could not use full frame DXVA post processing. however, writing speed to the frame is much faster, so it seems we can overlay osd / subtitles (write only) or blend them (little read involved) fast enough for the older CPUs to handle. Last edited by tal.aloni; 16th January 2010 at 09:49. |
16th January 2010, 16:43 | #10311 | Link |
Yes, afterwards we will make performance tests to figure out if :
1/ DXVA decoding + copy back to system memory + FFDShow software processing is faster than 2/ FFDSHow software decoding + processing So at the end the DXVA filter will still be useful to develop dedicated DXVA internal postprocessing filters Status : FFDSHow postprocessing work now on DXVA decoded picture copied back to system memory (including resize) but there is a deadlock |
16th January 2010, 16:50 | #10312 | Link |
Perhaps I'm missing something, but does anyone know where the OSD-profile bar has gone? I've had rev.1341 installed untill today (today I updated till latest one) and already with rev.1341 the ability to save OSD-profiles has been removed as well.
I'd like to know why it has been removed and if it's coming back at all?
My hobby website |
16th January 2010, 17:24 | #10313 | Link |
OSD settings are now stored as part of your Profile/Preset.
MPC-HC 2.1.7.2 |
16th January 2010, 17:51 | #10314 | Link | |
however, overlaying OSD / Subtitles works quite well. Last edited by tal.aloni; 16th January 2010 at 17:54. |
16th January 2010, 22:08 | #10315 | Link |
Didée Fan
The svn is not downloading the files properly, please fix it.
I have a question, if I make a 64 bit ffdshow.ax, does the gcc files need to be 64 bit also, or can I use the custom mingw 32 bit to build the gcc files and use them with a 64 bit ffdshow.ax?
16th January 2010, 22:14 | #10316 | Link |
Everything must be 64-bit. You need MinGW64.
MPC-HC 2.1.7.2 |
16th January 2010, 22:27 | #10317 | Link | |
Didée Fan
If I installed your 64 bit ffdshow then took the gcc files:libavcodec, mplayer, ffmpeg and put the in the bin folder to build my ffdshow would that work?
Edit, and if I used mingw64 myself, which would I install? Can you please link to the one I would use in Windows 7 64 bit, the download link? I don't use mingw usually so I have no clue on which one I need. Edit, I found these instructions by Casimir666, Quote:
I have a few questions. Do I install mingw 64 before downloading the "MingW64 chaintool for i686-mingw platform". If so please link to the download fo both files because I don't know which one to choose. Once I get that step down I'll try to figure the rest out myself.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. Last edited by Jeremy Duncan; 16th January 2010 at 22:54. |
16th January 2010, 23:01 | #10318 | Link |
Those instructions are not needed for ffdshow.
Just unzip MinGW64 and add its /bin dir to your PATH environment variable. I am using the 4.4.0 MinGW64 build.
MPC-HC 2.1.7.2 |
17th January 2010, 00:34 | #10319 | Link | |
So I gave up on branching |
17th January 2010, 04:42 | #10320 | Link |
Hey guys does the Dolby Digital Plus decoder support 7.1 right now? I'm playing a Dolby test bluray and ffdshow only outputs 5.1:
Not a big deal since there's virtually no DD+ blurays besides that test disc AFAIK. Just wanted to know. Using MPC-HC 1453 and ffdshow 3181. Could it be the splitter? I'm using the internal one. Last edited by Andy o; 17th January 2010 at 04:44. |
