23rd July 2011, 17:28 | #2142 | Link | |
23rd July 2011, 20:22 | #2144 | Link |
Anime addict
thanks for your effort.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
24th July 2011, 11:36 | #2146 | Link |
2046 [x264] blu-ray device: added 1440x1080 as supported resolution blu-ray device: enhanced --sar detection 2045 [x264] added --subme 11 (requires x264 revision 2037+) 2044 [Lame] fixed always applying bitrate 128 in ABR mode 2043 [Flac] enhanced output handling if file already exists 2042 [OneClick] enhanced error handling 2041 [Audio Encoder] added 24 <--> 25 conversions 2040 [Source Detector] enhanced error handling 2039 [FFMSIndexer] added option to select the number of decoding threads. default and recommended value is 1 changed LoadCPlugin to LoadPlugi for the x64 plugin (requires ffms r507+) |
24th July 2011, 17:20 | #2147 | Link |
Anime addict
Hi, i discover a error fatal that dont let close megui if dont since task admin.
25th July 2011, 01:26 | #2150 | Link |
Anime addict
It occur when i try encoded wav file to flac. These wav file is exported by audition cs5.5 with duration of 3 sg, depth 32 bit. I cant upload because i decided convert to aif format & remove wav file.
27th July 2011, 20:53 | #2153 | Link | |
Megui won't shutdown after encoding
MeGUI Version : 2046 (svn) OS : Windows Seven Ultimate Edition x64 SP1 Latest .Net Framework installed : 4.0 (4.0.30319) Avisynth Version : 2.5.8.5 (21.12.2008 21:46:54) Quote:
28th July 2011, 23:14 | #2154 | Link |
I want to encode some HD videos to SD and I don't know how to convert color space (bt709 -> bt601) to keep right colors.
Should I use avisynth "ColorMatrix(clip, mode="Rec.709->Rec.601")" or use ColorMatrix in x264 settings ? Thank you.
How to setup MPC-HC with ffdshow, avisynth, reclock and more - Ezoden.com |
29th July 2011, 07:37 | #2155 | Link | |
So I use "ColorMatrix(mode="Rec.709->Rec.601")" to convert to bt601, then use the colormatrix section in MeGUI's x264 settings to write bt601 colorimetry info to the video stream. I just noticed, my preset color conversion AVS script doesn't include the "clip" parameter. It's just: "ColorMatrix(mode="Rec.709->Rec.601")" There's no doubt it works though so I assume "clip" isn't necessary? |
29th July 2011, 11:48 | #2156 | Link |
I think clip is not needed.
How to setup MPC-HC with ffdshow, avisynth, reclock and more - Ezoden.com Last edited by jeremy33; 29th July 2011 at 12:03. |
29th July 2011, 13:16 | #2157 | Link |
Anime addict
@jeremy33
29th July 2011, 14:18 | #2158 | Link |
I'm sorry I encode with megui so I post here but you are right the thread title is clear enough.
29th July 2011, 18:54 | #2160 | Link |
ah ok, thank you for the clarification.
