16th November 2010, 19:50 | #10201 | Link | |
The size of audio in the m2ts stream is nearly double the size of the wav file. This can't be coincidence. I am convinced that the audio is somehow muxed twice. Another clue is the bit rate displayed. On the main screen BDinfo shows bit rate of 1152 kps for the LPCM track. But after doing a bit rate scan it shows a bit rate of 2304 kbs in the report. Exactly double 1152. Maybe a flag is set incorrectly somewhere?! BTW, I demuxed the audio with eac3to and the size was the same as with the tsmuxer, about 900 MB. |
16th November 2010, 19:50 | #10202 | Link | |
Uninstall your haali, delete the Haali folder in Windows Programs, and then download and install the correct haali from the first post of this thread. Then delete the BDREBUILDER.ini within your BD-RB folder. Then right click on REG_MSCOMCTL and Run As Administrator. Then right click on BD_Rebuilder.exeand Run As Administrator. Now you shoul be ready. |
16th November 2010, 20:13 | #10203 | Link | |
I did everything you say but also the same problem. I dont know. With XP SP 3 everything went fine and now with w7 problems. Shit |
16th November 2010, 20:18 | #10204 | Link |
LOL! Other way around for me. XP SP3 was garbage for me. Windows 7 is a godsend for me.
I may have to pick up the CARS BD to try that one out for "Diver90". But since Jdobbs has done it, Should go smooothly. |
16th November 2010, 20:30 | #10205 | Link | |
- WIN7 preferred AVC CODEC: Not Set correctly - WIN7 preferred VC-1 CODEC: Not Set correctly - WIN7 preferred MPEG2 CODEC: Not Set correctly Are you sure you have admin privileges when you try it? Also make sure the following isn't in your INI file: SUPPRESS_FF_WARNING=1 If it is, delete it. That gets added when you tell BD-RB to not ask you again about setting the registry. Last edited by jdobbs; 16th November 2010 at 20:34. |
16th November 2010, 21:05 | #10206 | Link | |
- WIN7 preferred AVC CODEC: Not Set correctly - WIN7 preferred VC-1 CODEC: Not Set correctly - WIN7 preferred MPEG2 CODEC: Not Set correctly And i must run as admin everytime. He write it not in the registry. No Idea. |
16th November 2010, 21:22 | #10207 | Link | |
16th November 2010, 21:33 | #10208 | Link |
This will take care of that. I've done it on multiple machines
http://windows7news.com/2009/02/03/e...rator-account/ Type/Run "CMD" in the start bar. Right click top CMD icon, and run as administrator. This will be the last time To enable the Windows 7 administrator account: net user administrator /active:yes To disable the Windows 7 administrator account: net user administrator /active:no |
17th November 2010, 05:45 | #10210 | Link |
hi i have this problem
[06:52:40] BD Rebuilder v0.35.01 (beta) - Source: MBD3 - Input BD size: 33.01 GB - Approximate total content: [02:27:23.291] - Target BD size: 7.84 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Auto Quality: Better (Faster), Two Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [06:52:40] PHASE ONE, Encoding - [06:52:40] Extracting A/V streams [VID_00001] - [07:00:37] Reencoding: VID_00001 (1 of 4) - [07:00:37] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 250 frames - Bitrate: 2,966 Kbs - [07:00:37] Reencoding: VID_00001, Pass 1 of 2 - [07:00:47] Reencoding: VID_00001, Pass 2 of 2 - [07:00:58] Video Encode complete - [07:00:58] Reencoding audio tracks (if req'd) - [07:00:59] Multiplexing M2TS - [07:00:59] Extracting A/V streams [VID_00002] - [07:01:00] Reencoding: VID_00002 (2 of 4) - [07:01:00] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 120 frames - [07:01:00] Reencoding: VID_00002, Pass 1 of 1 - [07:01:02] Video Encode complete - [07:01:02] Multiplexing M2TS - [07:01:03] Extracting A/V streams [VID_00003] - [07:01:04] Reencoding: VID_00003 (3 of 4) - [07:01:04] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 370 frames - Bitrate: 2,857 Kbs - [07:01:04] Reencoding: VID_00003, Pass 1 of 2 - [07:01:17] Reencoding: VID_00003, Pass 2 of 2 - [07:01:35] Video Encode complete - [07:01:35] Multiplexing M2TS - [07:01:36] Extracting A/V streams [VID_00000] - [07:21:12] Reencoding: VID_00000 (4 of 4) - [07:21:12] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 211,499 frames - Bitrate: 4,953 Kbs - [07:21:13] Reencoding: VID_00000, Pass 1 of 2 - [10:15:04] Reencoding: VID_00000, Pass 2 of 2 - [14:16:09] Video Encode complete - [14:16:09] Multiplexing M2TS [14:19:20]PHASE ONE complete [14:19:20]PHASE TWO - Rebuild Started - [14:19:20] Rebuilding AVCHD file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Can't open file: K:\PELICULAS BD\MILLENIUM 3 RECODIFICADA\WORKFILES\00001.track_4608.SUP [14:19:20] - Failed to REBUILD whats this problem? it stopped at 99% Last edited by jdobbs; 17th November 2010 at 05:52. |
17th November 2010, 06:47 | #10212 | Link |
The movie is Predators. Tried two builds and got the following results:
15:56:20] BD Rebuilder v0.36.02 (beta) - Source: PREDATORS_WW - Input BD size: 26.10 GB - Approximate total content: [01:46:53.073] - Target BD size: 22.95 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [15:56:23] PHASE ONE, Encoding - [15:56:23] Extracting A/V streams [VID_00800] - [16:32:37] ExtractAudioSubs() 00075 1605 [17:31:44] - Failed to retrieve audio, aborted ----------------------- [17:34:56] BD Rebuilder v0.35.01 (beta) - Source: PREDATORS_WW - Input BD size: 26.10 GB - Approximate total content: [01:46:53.073] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [17:35:02] PHASE ONE, Encoding - [17:35:02] Extracting A/V streams [VID_00800] - [18:21:06] ExtractAudioSubs() 00075 1605 [18:58:16] - Failed to retrieve audio, aborted ----------------------- [18:59:17] BD Rebuilder v0.35.01 (beta) - Source: PREDATORS_WW - Input BD size: 26.10 GB - Approximate total content: [01:46:53.073] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [18:59:22] - Aborted per user request ----------------------- [19:00:28] BD Rebuilder v0.35.01 (beta) - Source: PREDATORS_WW - Input BD size: 26.10 GB - Approximate total content: [01:46:53.073] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [19:00:30] PHASE ONE, Encoding - [19:00:30] Extracting A/V streams [VID_00800] - [19:36:21] ExtractAudioSubs() 00075 1605 [21:32:48] - Failed to retrieve audio, aborted I have been successful with many backups previously. Thanks for your help. |
17th November 2010, 20:18 | #10216 | Link |
BD Rebuilder doesn't like languages other than english
Now I have tested some more BDs and some more languages. My finding is that it is not possible to keep languages which are not selected in setup. BD Rebuilder seems to ignore the selection from the stream list although the selection is apparently stored in the .inf file. In deed, I could produce a BD without any audio track by deselecting all languages in setup and then selecting them in the stream list.
17th November 2010, 20:23 | #10217 | Link | |
Are you doing a full backup, a movie-only backup, an ALTERNATE movie-only backup? The reason I ask for logs in bug reports is so that we don't have to do a constant back-and-forth dialog to find the issue. |
17th November 2010, 20:39 | #10218 | Link |
It was a full back up. I attached some logs in an earlier post, but I will do a new encode of Alice in Wonderland, keeping only English in setup, and selecting Turkish, German, French in the stream list. The logs will be attached then.
17th November 2010, 20:52 | #10219 | Link | |
Thanks again Jdobbs for a wonderful software. My trouble has been almost non existent |
