30th April 2010, 10:17 | #11541 | Link | |
Intel Pentium Dual Core E2200 | Intel(R) G33/G31 Express Chipset Family (256Mb) | 4 GB DDR2 | Windows 8.1 Pro RTM x64 Last edited by onomatopellan; 30th April 2010 at 10:20. |
30th April 2010, 11:33 | #11542 | Link | |
@devs: I have updated libsamplerate to v.0.1.7 locally. The increase in the installer's size is ~800KB. Test binaries (x86 and x64) and the patch can be found here. The changelog for libsamplerate since 0.1.2 mentions:
30th April 2010, 11:53 | #11545 | Link |
LZMA2 doesn't help much.
As usual I vote against the huge libsamplerate. Few people actually use it and most of them would probably not even hear a difference in a double-blind test.
MPC-HC 2.2.1 |
30th April 2010, 12:33 | #11547 | Link |
MPC-HC Project Manager
the size increased because the current version was fundamentally flawed and the author had to refactor a large portion of code iirc
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
30th April 2010, 12:54 | #11548 | Link | |
Thanks in advance . . . (providing just the single dll would suffice) |
30th April 2010, 13:30 | #11549 | Link |
@Shark007: I updated my previous post (both the binaries and patch). Keep in mind I haven't tested the x64 version at all since I don't have 64bit Windows.
30th April 2010, 18:58 | #11550 | Link |
Lost In The Web
I think I have a bug with the Resize & Aspect option
video size that don't work correctly : 400x300 / 480x352 / 512x384 / 576x432 / 640x480 / 640x496 / 704x512 / 1008x762 No problem with : 640x360 / 704x388 / 704x396 / 704x400 / 720x400 / 1008x560 Here is a test done with version 3387 and two video clip (640x480 / 704x396). The parameter for Border are left with default option & setting > Lock / Bicubic if I put this resize parameter The clip 1 is not resized right, has you can see the image has a black border. http://i40.tinypic.com/6edizc.jpg but clip 2 is resized correctly http://i39.tinypic.com/2a9prbo.jpg With this resize parameter It resize correctly the two clip http://i41.tinypic.com/msbxy1.jpg http://i39.tinypic.com/vxnec4.jpg I'm doing something wrong or forgetting a option ?
Windows 11 11th Gen Intel(R) Core(TM) i5-11400F Nvidia Geoforce RTX 3050 MPCHC - madVR - Lav Filters - XySubFilter |
30th April 2010, 20:58 | #11551 | Link |
Well, although I haven't seen anything in the changelog, I decided I'll give rev. 3390 a try, perhaps the issue mentioned here - http://forum.doom9.org/showthread.ph...78#post1394378, is gone.
The good news is the issue is not presented anymore, the bad news is it's because subtitles are not displayed at all :-) Back to rev. 3367. |
30th April 2010, 21:00 | #11552 | Link |
@devs: I have updated all the mingw libs (libgcc.a, libmingwex.a, libws2_32.a) and the boost lib (r61712). I've tested MSVC x86/x64 Release builds x86 ICL11 Release build and I didn't face any problems. Although I had to add BOOST_NO_RTTI in the Preprocessor definitions for ff_vfw in order to get the ICL11 x86 build to compile. From Debug builds, I've only tested MSVC Debug x86.
Are the mingw libs in the SVN specially compiled? Because I see that they have a big difference in size compared to my mingw ones. PS. I still wait for libsamplerate. Only clsid has replied so far and he is against the update. |
30th April 2010, 21:22 | #11553 | Link | |
4:2:0 hater
About libsamplerate I say go with the update, better quality is always better. There are a lot of things that people use less than resampling that could be removed from ffdshow yet they're there |
1st May 2010, 02:39 | #11554 | Link | ||
In clip one, there is also black bars in the video on the left and right within the 16:9 area in the centre of the screen touching the inside of the screen, so now there are black bars left and right from ffdshow and top and bottom because there is nothing there. If you put the video into a window (not full screen), you will see that there are only black bars on the left and right. Quote:
In the second clip, the black bars on the top and bottom are part of the video and put there by ffdshow to keep the original aspect of the video. If the second video was resized to 1440x1080 without aspect ratio correction/black bars, the aspect would be 4:3 and not the original 16:9. TL;DR the aspect ratio of the clips is being kept. |
1st May 2010, 02:41 | #11555 | Link |
4:2:0 hater
Albain, r3374 causes subtitles to disappear on a seek. This happens at least with subtitles readed from file. The only solution is to reload them. The culprit is:
if (subs) subs.onSeek(); Removing this line fixes the issue. Maybe that's why adam777 can't see any subs now. |
1st May 2010, 06:11 | #11556 | Link |
Albain,
I just tested rev 3383 and 3387, just playing the original Blu-ray disc Sword Of The Stranger with zoom player but the subtitles are not displayed. Build 3370 is the last working version for me, I don't know if anything changed with the way the subs are displayed after 3370 or if the problem is with zoom player. You can download a trial copy of Zoom Player Home MAX here http://www.inmatrix.com/files/zoomplayer_download.shtml. Here is the update http://www.mediafire.com/?zldjdyomz2w which fixes a problem where ffdshow's subtitles were being disabled, copy and replace original .exe in zoom player install folder. Untick the option Disable FFDShow subtitle rendering when no subtitle files/streams are found (see image). I'm using the Win7 Direct Show Filter Tweaker 3.1 to change video renderers to FFDShow. System Setup: Windows 7 Professional 64bit GeForce GTX 280 - Forceware 197.25 AnyDVD HD - 6.6.3.4 Zoomplayer 7 Home Max - 7.10 Alpha 3 Gabest Mpeg Splitter - standalone filter svn 1824 32bit Haali splitter - 27-03-2010 EVR renderer, YV12 Output Let me know if you need any more info. Thanks FreeFall |
1st May 2010, 08:50 | #11557 | Link | |
I have to test, i have a strange issue, and i try to figure out, but on m2ts and last FFDshow, the sub out pin don't want to connect to input pin of FFDshow, i have enable subtitle. If i use old version (3364) but not all old version the connect is made, i use a quick test by graphstudio to look this. Also, i have see that you have work for SSA positionning. I have a question about .srt file, it's normal that i don't succeed to have the same (font, position) that i obtain with directvobsub and MPC-HC ? Another think, but i thik that all issue come from me lol. If i have a movie with in the same directory an .srt with part of the name of the movie, the sub is load automatly with the bad .srt Example : movie -> sample.mkv and sub in directory : sample2.srt Agin in MPC-HC or Directvobsub, it take only subs with the match name and don't load sample2.srt. Thank you Cheers, Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
1st May 2010, 08:51 | #11558 | Link | |
same problem but with MPC-HC and ffdshow since 3371 |
1st May 2010, 09:36 | #11559 | Link |
Those who can't see the Bluray subtitles, can you also see THIS on the top of your filter list?
Intel Pentium Dual Core E2200 | Intel(R) G33/G31 Express Chipset Family (256Mb) | 4 GB DDR2 | Windows 8.1 Pro RTM x64 |
