Old 14th April 2014, 22:18   #1  |  Link
benwaggoner
Maximum buffer size in HEVC per profile/level?
I am having a hard time finding a definitive reference for the max buffer size (VBV/HRD) for different different HEVC profiles and levels.
I can kinda squint to see how I could figure it out from the spec, but I'm not the world's best spec->parameter translator ?
Has anyone done this already? Given that Main/Main 10 lowered the max bitrate a lot from H.264, I imagine that buffer sizes may have seen a similar (proportional?) reduction. I want to make ensure I'm making spec-compliant test streams. And have a public reference everyone can clearly see for setting their --vbv-bufsize or similar parameters
Ben Waggoner
My Compression Book
Old 14th April 2014, 22:27   #2  |  Link
sneaker_ger
Originally Posted by sneaker_ger View Post
Vbv values can be found in the spec, table A.1 (page 203/217) and A.2 (page 205/219).
http://www.itu.int/rec/T-REC-H.265-201304-I
Table A.1 lists buffers for main and main10 profile. Note that main and main10 profiles are divided into main and high tier.
Old 14th April 2014, 22:35   #3  |  Link
benwaggoner
And so they are! I got confused because they're also the same as maximum bitrate and assumed it was just repeated data.
As I warned, reading specs isn't my strong suit .
Thanks!
Ben Waggoner
My Compression Book
Old 14th April 2014, 22:38   #4  |  Link
sneaker_ger
The H.264 and H.265 specs are extremely incomprehensible indeed, so wait for someone to confirm it.
Old 17th April 2014, 22:26   #5  |  Link
pieter3d
That should be right. The spec is hard to read like a book, but it is very unambiguous.
pieter3d is offline   Reply With Quote
Old 17th April 2014, 22:31   #6  |  Link
benwaggoner
It is interesting that the buffers for Main Tier are so much lower than for H.264 - HEVC Level 5 is less than H.264 Level 4! Presumably this is to constrain worst-case decoder complexity. And HEVC certainly should be able to get away with a lot less VBV.
Anyone have any sense for whether many real-world decoders will be constrained to Main Tier, or if High Tier is going to be ubiquitous?
Ben Waggoner
My Compression Book
buffer underflow, vbv, x265
