21st December 2009, 17:49 | #322 | Link | |
The Next Generation Internet Video Codec project.[/url]. |
21st December 2009, 17:53 | #323 | Link | |
21st December 2009, 18:00 | #324 | Link |
Just wanted to say great job so far!
I have tested it for the first time just now on my HTPC and for almost all samples I tested it's usually the fastest, if only by a few percent really. Only thing a bit annoying is slighly longer initialization time when opening a video. Can't wait for the beta which I guess will be even faster? Can you estimate how much? Also, I understand DiAVC will be payware, is that correct? I ask because on your homepage there is a link to the source. Thnx |
21st December 2009, 18:05 | #325 | Link |
Software Developer
There only are the sources of "DiAVCSettings.exe", a small configuration utility. They were published, because some AntiVirus programs triggered FALSE ALARMS with that file
I don't think that the sources of DiAVC itself will be published. And the "BUY" button on their web-site clearly indicates that DiAVC is supposed to be payware...
21st December 2009, 18:15 | #326 | Link | |
The DiAVC will be a payware. But it will be cheap and all following improvements such as super-resolution, 64-bit and new features are free for customers.
21st December 2009, 18:23 | #327 | Link |
I see, thnx for that.
Luckily my Core Duo (not Core 2 Duo) in the HTPC seems to support SSE3, so that's good. SuperResolution you say? So...Fancy Resizing? Stuff like FFDShow has? Looking forward to the Beta...if it's about the price of other decoders it's fine with me :-) |
21st December 2009, 18:32 | #328 | Link |
Software Developer
Usually "SuperResolution" means that instead of one expensive "high resolution" camera we use several cheap "low resolution" cameras. Then we combine several "low resolution" shots to one "high resolution" picture by using a fancy SuperResolution algorithm. The result will (hopefully) be much better than just upscaling a single "low resolution" shot. However in the case of DiAVC I think the "SuperResolution" simply refers to a fancy upscaling method, because we only have one single "shot" of each frame. Maybe something like Edge-Directed Interpolation or tritical's NNEDI filter.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st December 2009 at 18:37. |
21st December 2009, 18:34 | #329 | Link | |
I just google it and get the following link, there is some pictures at the end of that paper. http://graphicon.ru/oldgr/en/publica...d%20Fusion.pdf
The Next Generation Internet Video Codec project.[/url]. Last edited by schweinsz; 21st December 2009 at 18:38. |
21st December 2009, 18:42 | #330 | Link | |
Software Developer
Do you have any sample clips on how this looks with "real life" footage and in motion?
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 22nd December 2009 at 02:52. |
21st December 2009, 18:49 | #331 | Link |
No, I designed most of the algorithms last month but I have not implemented it.
21st December 2009, 19:09 | #333 | Link | ||
Edit: BTW, while super resultion might be useful, many people watch mainly HD stuff anyways and since their panel can't display anything higher it's perhaps not that useful. Now Motion-Compensated-Frame-Interpolation on the other hand..... I know, I'm just dreaming....but I would def. pay a premium for that one :-) Last edited by the_corona; 21st December 2009 at 19:12. |
22nd December 2009, 02:41 | #334 | Link | |
Derek Prestegard IRL
@CanTsTop:
You're a little confused ~MiSfit
These are all my personal statements, not those of my employer :) |
22nd December 2009, 02:47 | #335 | Link |
Software Developer
Well, it seems Neuron2 isn't very happy with libavcodec!
The latest version of DGAVCDec still used an old outdated version libavcodec (one that is broken with various samples), because all newer versions of libavcodec have frame-accuracy problems. If I remember correctly, there even were plans to make DGAVCDec use CoreAVC, as soon as CoreAVC exposes a suitable API. But now it seems that this won't happen, as CoreAVC won't offer such an API. Therefore CanTsTop's question about DiAVC Decoder and DGAVCDec isn't completely absurd
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 22nd December 2009 at 02:51. |
22nd December 2009, 07:41 | #338 | Link | |
Besides, the DiAVC never uses any mmx code, it only uses sse2 code. as Dark Shikari said, it hurts performance for old cpu.
avc, diavc, fastest decoder, h.264, software |
