20th October 2011, 21:34 | #11366 | Link | |
Speaks dts
S* = Back B* = Side Last edited by Spc01; 20th October 2011 at 21:57. |
21st October 2011, 15:18 | #11368 | Link |
To 2.0 -> 5.1 read the Sticky: GUIDE LIST: Stereo-to-Surround Conversion Guides
21st October 2011, 16:00 | #11369 | Link | |
User of free A/V tools
At least that's how I understood the wording "between 2.0 and 5.1" of his post's context. |
29th October 2011, 04:47 | #11372 | Link |
Is it possible to output 32 bit audio to stdout?
For 24 bit I use: eac3to.exe in.mp2 stdout.pcm -24 "eac3to.exe in.mp2 stdout.pcm -32" doesn't seem to give 32 bit audio (it isn't in the docs so no surprise) but is there a way? |
29th October 2011, 05:03 | #11373 | Link |
Banned
Use the -full switch to get 64-bit floating point. It's either 24-bit integer or 64-bit float, nothing in between. What is even going to accept 32 float as an input? What is the point? It offers the same precision as 24-bit integer if nothing goes over 0dB.
29th October 2011, 07:09 | #11374 | Link |
Thanks, it makes a lot more sense now.
It turns out I am just getting 24 bit from the eac3to, there are no more bits to get. (-full gives 24 bit) I am piping to qaac, I think 24 bit is all that exist for this mp2 source but qaac could take 32bit float if it did exist. So there is no point. |
30th October 2011, 22:59 | #11375 | Link |
Hello,
I think a found a little bug: With this command line: "C:\MasProgramas\eac3to\eac3to.exe" "C:\Temp\VideoSynch\Vsy_Segmento_Aud_000.ac3" "C:\Temp\VideoSynch\Vsy_Segmento_Aud_000_sil001.ac3" -silence -edit=0:00:00.544,1088ms Eac3to shows a error: Invalid edit format "edit=0:00:00.544,1088ms And also with: -edit=0:00:00.544,544ms but not with: -edit=0:00:00.544,543ms If the silence duration to insert, is bigger than the insertion position, eac3to trows a error. So: -edit=0:00:00.789,800 is a error -edit=0:00:00.789,788 is not I think is a easy fix (an outdated check in action, I think). Is the source code available? |
30th October 2011, 23:07 | #11376 | Link |
nope
31st October 2011, 03:57 | #11377 | Link |
Guys this is a long thread but please excuse me I couldn't read it all.
I have noticed that eac3to can not read a 32bit float wav file created by audition as input. If I convert the same file in audition to 24bit, eac3to can read it. Any ideas? |
31st October 2011, 11:22 | #11378 | Link | |
Please put a sample (1 second is enough).
31st October 2011, 19:40 | #11379 | Link |
Hi. I'm doing
eac3to input.dtshd output.flac -down2 -mixlfe -down16 Code:
Clipping detected, a 2nd pass will be necessary. <WARNING> ... Applying -6,73dB gain... Should I redo it using like -7dB to be safe? Or is it fine after second pass? Does it use the source dtshd for 2nd pass or just created flac? |
eac3to |
