16th March 2010, 21:08 | #11102 | Link | |
I found small bug in installer
options untouched but isCompMgr=0 is not created in registry [SOFTWARE\GNU\ffdshow] . Result ffdshow shows compatibility manager for any unknown file (for example avs2yuv.exe or x264_x86.exe) Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 16th March 2010 at 21:12. |
16th March 2010, 21:50 | #11103 | Link |
Yeah, that's what I figured.
@clsid would it be ok if I upload it on netload instead of mediafire? I have an account there... let me know if that is fine with you, else I'll up it on mediafire... Last edited by djesteban; 16th March 2010 at 21:55. |
16th March 2010, 22:01 | #11104 | Link |
It does not matter send your sample wherever you want
17th March 2010, 20:00 | #11107 | Link |
Hey.
I just tried the same video as djesteban. The latest build (rev3316) really screws the image up - anime movies are basically unwatchable (I also tried build rev 3267, it glitches exactly the same way). Live action seems ok, tough. If I revert to build revision 3222, everything is ok. Let me know if you want screenshots, but it looks exactly the same as what esteban posted. |
17th March 2010, 22:45 | #11108 | Link | |
@clsid Have you been able to check my sample I uploaded? Let me know if you have any question. Cheers |
18th March 2010, 01:34 | #11109 | Link | |
4:2:0 hater
- Resize with bicubic still produces green video, everything else is fixed. - Deinterlacing, ffmpeg deinterlacers produce a extremely stuttering image, it doesn't look like a perfomance problem, CPU usage is at ~10% while without deinterlacing is at 20% (1080p H.264 high bitrate). That's with the default YUY2 output, with RGB32 I get a black screen. Yadif and the other deints are good. - Postprocessing, with mplayer checked and YUY2 output, same behavior as deinterlacing: stuttering. RGB32, black screen. Crashes fixed! - In Blur, stuttering with YUY2 and black screen with RGB32 again when using mplayer temporal noise reducer, it crashed once with error in libavcodec. - Luminance level fix, stuttering and black screen with YUY2 and RGB32. I didn't notice any other problems, all the crashes except that ocasional one are gone. Good work, you're almost there! Last edited by STaRGaZeR; 18th March 2010 at 01:37. |
18th March 2010, 13:09 | #11110 | Link |
I have pinpointed the h264 problem to revision 3256. I will attempt to fix it later.
MPC-HC 2.2.1 |
18th March 2010, 14:56 | #11111 | Link |
Media Control author
here is a new development build with the new ffmpeg scaling/postprocessing libraries. Fixes : now the DVD subtitles are okay. The fix (committed in previous revision) as well as the new fixes should resolve the last crashing issues that could occur Bluray subs may be cleaner too I have also added new functions to the keyboard control : there is now fast forward/rewind commands, and next subtitle stream & next audio stream commands. Please report back, thanks ! @Stargazer : I don't reproduce the issues you listed in the last build Last edited by albain; 18th March 2010 at 16:14. |
18th March 2010, 15:02 | #11112 | Link | |
BTW, it will be good to be able to setup "prefered" audio/subtitle track language
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 18th March 2010 at 15:05. |
18th March 2010, 15:39 | #11113 | Link |
@albain:
Some quick test with your test build: - open any MKV video in grapstudio (using MPC-HC MKV splitter), play and click on FFDShow icons = crash - it looks like FFDshow now refuse to accept AAC audio streams - subtitles color are white (in graphstudio) even if i setup to use yellow - hitting CTRL+ALT+F4 cause graphstudio crash instead of next subtitle stream - FFMPEG-MT causing h.264 video stuttering, libavcodec play fine here on IntelAtom CPU. ...do not have time for more test, hope my report will help you. Thanks again for your work. EDIT: here is test file i am working with:
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 18th March 2010 at 15:42. |
18th March 2010, 17:31 | #11116 | Link | |
Fixing will require some trial and error, but should be doable.
MPC-HC 2.2.1 |
18th March 2010, 18:47 | #11117 | Link | |
The Mask Developer of The FilmMachine An easy to use, wizard-like, AVI/MP4/MOV/RMVB/MKV to DVD conversion utility |
18th March 2010, 19:21 | #11118 | Link | |
4:2:0 hater
BTW, the issue with that white shadow in the DVD subs that I uploaded earlier is still there, but I don't know if that's supposed to be fixed in this beta. Oh and thanks for the new keyboard control features, they're very useful. Last edited by STaRGaZeR; 18th March 2010 at 19:24. |
18th March 2010, 19:34 | #11119 | Link |
This should work as always : in file mode there is a different behaviour for writing the content of the input stream instead of encapsulating it in bitstream format.
However this does not apply to TrueHD : there is special code for this format. So in the TODO list |
18th March 2010, 19:36 | #11120 | Link |
Ok, looking forward to it.
