26th November 2006, 22:48 | #302 | Link |
Life's clearer in 4K UHD
Does it still need Java to run?
26th November 2006, 22:55 | #303 | Link |
There is an version compiled to an exe ... Google -> Oozoon.
But he wants some money for that ... 8( But also the Java Version runs very fast ... very unlikely to java ..8) Program to compile to EXE : Excelsior JET Last edited by fogbav; 26th November 2006 at 22:59. |
26th November 2006, 23:02 | #304 | Link |
I'll pass....
27th November 2006, 07:07 | #306 | Link |
there is no real Java-Show-Blocking thing ... you even will not see anything ... and i think nearly every win pc has java onboard. so - no problem here ... Projectx looks like every other cli tool ... in command line mode.
Just try and you will see ... @Buzzqw : did you watch this topic ? http://forum.doom9.org/showthread.php?t=117889 8) Maybe some playground for automkv 1.11 beta ...8) Last edited by fogbav; 27th November 2006 at 07:41. |
27th November 2006, 08:31 | #307 | Link |
HDConvertToX author
no hassle at all...
in next stable version user can choose to use dgindex or projectx to demux BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
27th November 2006, 12:22 | #308 | Link |
Finally... After a clean reinstallation, bepipe always crashed every time i tried to start it... Finally i realized that it needed Framework 1.1 to run.. I suggest you mention it next to where you mention to download the nero aac encoder. Going back to further testing now, everything runs smooth atm.. =)
27th November 2006, 13:06 | #309 | Link |
One other tiny suggestion.
I have a movie folder that I keep all my movies in (as you might guess). Well I don't want to use it as my output folder because of all the extra files that AutoMKV makes. But then if I make it go to an temp folder once the encoding is done I need to go to that temp folder find the final avi and rename and copy it to my movie directory. So I prefer the approach than AutoGK, Dr 2, Avi.net takes in that they let you select your temp (working folder) and the output file name/location. |
27th November 2006, 14:05 | #310 | Link | |
It seems I have a new problem that I cant solve: after automkv rips the subs off the dvd and starts encoding the audio it goes straight away to Finished Jobs. It doesnt even really start encoding the audio. In the processing log I get the following.
27th November 2006, 14:12 | #311 | Link | |
HDConvertToX author
try re-ripping (with ritit4me) BHH
27th November 2006, 19:40 | #312 | Link | |||
Hm i had the same problem again, using a different dvd, again the dvd was ripped, as well the subs, but no audio streams where extracted or encoded, no video either. onlz 3 log files, dvd rip, movie.idx, movie.sub and para.lst are to be found in the target folder. here the log files:
27th November 2006, 19:54 | #313 | Link | |
HDConvertToX author
this message
i must suppose there is something wrong with avisynth... open in virtualdub time.avs and spot the error (maybe related to audio... since it works on avisynth) BHH
27th November 2006, 21:30 | #314 | Link |
Hm, I cant open time.avs in virtualdub, gives me the following error: AVI import filter error: (Unknown) 80040154
So what does it mean? i dont have avisynth installed, because i reinstalled windows... doh! You can also add that to the nero aac and frameworks lol. Thanks for the virtualdub hint, that made me realize... its encoding the audio atm, so seems to be working fine, will report back.. |
27th November 2006, 22:17 | #315 | Link |
I was wondering if it is possible to have the mkv file split, lets say into two times 650mb files? (so that i dont have one 1.3gb file) or is that impossible when a movie contians 4 subs, 2 audio tracks and 1 vido track?
27th November 2006, 22:24 | #316 | Link | |
HDConvertToX author
for 2 files of 650 mb do this: on disk setting choose "Write Here Custom MB Size" and overwrite it writting 650 on form that appear after writing 650 write 2 this will lead to 2 files of 650mb ! BHH
28th November 2006, 10:39 | #317 | Link | ||
I c, thanks so much. Already another problem has come up. Again it runs dgindex etc, but once it should start encoding the movie it doesnt. This time i selected copy original soundtrack, so it shouldnt have to encode it, as i always get that error in the log file. I ripped the dvd 10 times now, tried everything i could think of, just cant get it to work. Any ideas?
28th November 2006, 13:21 | #318 | Link |
HDConvertToX author
got the error... is due to NO filters NO resize NO deint (all in one), will be fixed in next release
now apply at least a filter (undot...) BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 28th November 2006 at 13:30. |
28th November 2006, 13:42 | #319 | Link | |
I meant to let you know about this error a couple of weeks ago
28th November 2006, 13:56 | #320 | Link |
HDConvertToX author
ops...
i miss it... (or forget it) thank SMD ! BHH
