Old 19th October 2016, 13:19   #39761  |  Link
ashlar42
Originally Posted by Asmodian View Post
FLOPS, and I agree that it seems to indicate madVR performance quite accurately.
Ok, so my idea was correct.
If this is the case, there's a huge gap between 1050Ti and 1060.
2.1 Tflops vs 4.4.
RX480 should offer 5.8 Tflops. Is this confirmed by real testing (it being faster than GTX1060 in madVR)?
Note: the above values are calculated from specifications, according to Tech Report.
Edit: I searched for the comparison spreadsheet that was posted here, based on real testing, and no, GTX480 does not seem to confirm the theoretical advantage that it has based on specs.
Old 19th October 2016, 13:30   #39762  |  Link
the first test show it was not the case with polaris.
i just got my RX 480 back and it can easily do nnedi3 64 neuron 24p FHD-> UHD.
but that is mostly openCL.
just wait for the new algo i'm pretty sure people with different hardware will test it.
Old 19th October 2016, 14:45   #39763  |  Link
Shiandow
Keep in mind that FLOPS can only do so much to make things faster; running shaders always has some overhead (reading / writing memory etc.) and for modern GPUs this overhead seems to dominate the computation time for all but the most computation intensive shaders (e.g. NNEDI3).
Case in point, a while back I upgraded my GTX 560Ti to a GTX 960, and while the GTX 960 is definitely faster the difference in FLOPS is far greater than the difference in render times.
Old 19th October 2016, 17:47   #39764  |  Link
Asmodian
I have noticed this too. All the easy shader passes take 0.49ms on my Titan X and this is independent of clock speed and resolution. This means an easy six pass shader, like thin edges, is the same 3 ms on my Titan X as it was on my 980Ti while NNEDI3 256 is much faster on my Titan X.
More FLOPS = Faster in madVR, it isn't 1 to 1 but other aspects don't do much to help madVR at all.
madVR options explained
Old 19th October 2016, 20:13   #39765  |  Link
Shiandow
Interesting... the 0.5ms per shader pass seems to be pretty universal, I've had similar results on my GTX 560Ti and GTX 960. Not sure what's causing it, it doesn't seem to be just memory bandwidth as reading in more pixels doesn't slow things down much (in a rather extreme case I've had a shader read 1920 pixels per output pixel, that definitely slowed things down but it still worked). I think the number of output pixels has a bigger effect but I haven't checked it thoroughly.
At any rate if it's 0.5ms for every GPU then there's indeed no point in trying to make it faster, so FLOPS are pretty much the only benchmark that will have some effect. Although 2x more FLOPS won't necessarily mean 2x faster rendering.
Old 19th October 2016, 23:36   #39766  |  Link
AngelGraves13
VRAM plays a role too when upscaling. My 1080 GTX is a huge upgrade over my 980 GTX.
NNEDI3 at 256 for Chroma still isn't possible, but maybe one day...
AngelGraves13 is offline   Reply With Quote
Old 19th October 2016, 23:43   #39767  |  Link
Asmodian
Do you mean VRAM speed or amount? I haven't noticed a change in performance due to VRAM speed myself, and I never need more than 3GB of VRAM even with 4K and large buffer sizes.
Are you sure the improvement isn't simply due to the large increase in FLOPS (4981 v.s. 8873)?
edit: Why would you want NNEDI3 256 for chroma? I can do it but I do not.
Old 20th October 2016, 00:09   #39768  |  Link
with a GPU buffer of 16 i get more than 3Gb VRAM usages.
Old 20th October 2016, 00:26   #39769  |  Link
Asmodian
Relatively larger buffers then, or maybe simply not small buffers, the default of 8 stays under 3GB.
The 980 has 4GB of VRAM anyway, I don't see how the extra 4GB of VRAM on the 1080 helps.
Old 20th October 2016, 05:44   #39770  |  Link
AngelGraves13
I'd say VRAM usage. Doubt speed matters much, if at all. It's just better to have more buffer, especially for 4K video, though it will be a few years until we can play back 4K Ultra HD on PC, assuming the copy protection will ever be cracked
I have 128 for CPU, 24 for GPU and 16 for Present.
NNEDI3 128 I can do, but 256 isn't possible on a 1080 GTX. I use Jinc w/ SuperRes 4 for Chroma and Upscaling.
Old 20th October 2016, 07:50   #39771  |  Link
even with GPU buffer of 8 you get close to 3 GB Vram usage.
of cause 8 GB doesn't help but 3 GB is still very limited for UHD. with larger buffer size you simply have no chance with 3GB.
Old 20th October 2016, 08:05   #39772  |  Link
Betroz
Is this for real?
Betroz's Avatar
With 720p, 23.976fps content upscaled to 1440p, and then down to 1080p on my 1080p TV I can use the following settings in MadVr :
- Chroma upscaling : NNEDI3 64
- image downscaling : SSIM2D 100%, AR, LL
- image doubling : double Luma NNEDI3 256 + double Chroma NNEDI3 32 (quadruple off)
- image upscaling : Jinc AR
- upscaling refinement : only SuperRes 1X (2X is possible, but a bit higher render times)
This gives me a rendertime of 32-35ms. 480p content is upscaled with Jinc AR from 960p -> 1080p (after NNEDI3 settings has done it's job up to 960).
Or I can use these settings with the same content :
- Chroma upscaling : NNEDI3 256
- image doubling : double Luma NNEDI3 64 + double Chroma NNEDI3 64 (quadruple off)
Very little difference in IQ between the two setups, although I like NNEDI3 256 for Chroma Upscaling with native 1080p content on my 1080p TV that is not using any image upscaling/doubling or SuperRes refinement.
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED
Betroz is offline   Reply With Quote
Old 20th October 2016, 08:25   #39773  |  Link
ryrynz
ryrynz's Avatar
Spot the difference.
Old 20th October 2016, 09:19   #39774  |  Link
Betroz
Is this for real?
Betroz's Avatar
Hehe, I can't
I use the first settings from my previous post anyway (the one with NNEDI3 256 for Luma).
Old 20th October 2016, 09:26   #39775  |  Link
ryrynz
ryrynz's Avatar
Hehe, I can't
I'd almost suggest removing 128 and 256 neuron NNEDI3 for chroma but I don't think that'll happen, IMO it's best to avoid them.
Old 20th October 2016, 13:43   #39776  |  Link
Shiandow
Seems I may need to hurry along my latest experiment a bit.
Old 20th October 2016, 13:50   #39777  |  Link
Ver Greeneyes
Compared to NNEDI3, seems to sharpen the sleeve and instrument of the guy on the left a little more, but at the expense of some aliasing (or clipping) that makes it look a little rough. Had to switch between the images several times to even notice though! (I somehow noticed the aliasing before the increase in sharpness)
Old 20th October 2016, 14:07   #39778  |  Link
aufkrawall
Considering that I'm getting presentation glitches with default queues, which I don't get with longer queues, this is a real dealbreaker for 3GB cards.
Old 20th October 2016, 16:23   #39779  |  Link
Shiandow
True, although softer images almost automatically look less aliased. And compared to NNEDI3 it's quite a bit faster. Still somewhat of a work in progress though.
Old 20th October 2016, 18:31   #39780  |  Link
sauma144
Is it SSimSuperRes, its successor or a totally new algo?
What's the performance difference between NNEDI3 (64n) and your algo?
sauma144 is offline   Reply With Quote
