Old 8th November 2009, 18:51   #1021  |  Link
nurbs
I don't know about audio, but if you use a lossy source with video codecs then codecs that are similar to the codec the source has been encoded with have an advantage.
Old 8th November 2009, 19:23   #1022  |  Link
Abradoks
Right. But when somebody makes a comparison between 20 Mbit/s BD source and 3 Mbit/s rips made with different codecs nobody blames him (even if he uses non-DCT codec).
Abradoks is offline   Reply With Quote
Old 8th November 2009, 20:19   #1023  |  Link
yesgrey
Abradoks,
I've sent you a PM with a link where you can get a sample of a lossless 5.1 48kHz 24bit audio file. If you could rerun the test with it it would be great...
Old 8th November 2009, 21:46   #1024  |  Link
honai
Posts: n/a
The test was biased because inherently the "source" DTS has already been processed/filtered in favor of DTS.
Also, since we know that the LPCM track of At World's End is 16 bit, there is a very high probability that the source for the DTS was also 16 bit, regardless of the DTS header information.
Old 8th November 2009, 21:53   #1025  |  Link
Abradoks
Name		|  SNR	| PEAQ		||  SNR	  | PEAQ
		448 kbps		224 kbps
DD6, L		| 22.618| -0.205	||  16.188| -2.471
aften, L	| 18.541| -0.523	||  12.844| -3.115
DD6, C		| 23.644| -0.175	||  16.875| -2.203
aften, C	| 18.571| -0.377	||  12.790| -3.109
I know. But as I've already mentioned it doesn't make a difference. Look at results measured on the 24-bit PCM provided by yesgrey3.
Old 8th November 2009, 22:16   #1026  |  Link
raquete
i can't post in mumbers how much tests i did and i trust in your results but in particular, i'm interested to hear as encoding with aften for long time feel better results when comparing with softencode or with the Dolby encoder inside sound forge 9.
you and yesgrey3 could post yours samples for members apreciations if don't break forum's rules.
regards!
raquete is offline   Reply With Quote
Old 8th November 2009, 23:39   #1027  |  Link
yesgrey
Yes, DD still has better numbers, but the difference is smaller.
I would also like to see the numbers with 640kbps...
I have considered posting the file here, but decided not to do it because I did not knew if I could be violating any rule...
I've extracted the period between minute 1:00 to 2:10 of "quantum of solace" Blu-ray.
Old 9th November 2009, 02:53   #1028  |  Link
SquallMX
Special SeeD
Originally Posted by jruggle View Post
That is actually very good to know. I don't have access to a DD encoder. I would not be opposed to changing the defaults if that's what users would prefer. What are the other cutoffs for different bit rates and channel layouts?
edit: also, could you provide some small snippets of the DD-encoded files so that I can see what encoding features and params they use to get the better PEAQ and SNR values?
Aften use by default the average frequency cut of Dolby Encoders, example:
Dolby 5.1 AC3 448 Kbps, Freq 14/20, Aften 17 Khz
Dolby 2.0 AC3 192 Kbps, Freq 10/20, Aften 15 Khz
Probably because the lack of channel/frequency coupling in Aften, if I recall correctly you need 572/256 Kbps for true 20 Khz cut off on 5.1/2.0 audio files encoded by dolby encoders, ironical you can't get more than that in an official encoder, but with aften you can go up to 24 Khz if you want to.
SquallMX is offline   Reply With Quote
Old 10th November 2009, 12:16   #1029  |  Link
raquete
i posted few samples in lots of formats with round 10 seconds in the forum some time ago in differents threads and i don't break rules as the idea is too share and change informations then, i can't see any problem.
Old 10th November 2009, 14:31   #1030  |  Link
Abradoks
It's not because of lossless source. With 1 minute sample I've previously posted I get results that differ from the whole track results in the same way:
Name		|  SNR	| PEAQ
		448 kbps
DD6, L		| 23.382| -0.205
aften, L	| 19.154| -0.582
And the difference is not "smaller". Look at PEAQ values.
Name		|  SNR	| PEAQ
		640 kbps
DD6, L		| 27.809| -0.039
aften, L	| 22.764| -0.172
DD6, C		| 28.911|  0.003
aften, C	| 22.982| -0.056
Here is "Quantum of Solace" source wav, output.448.DD6.ac3 and output.224.DD6.ac3. You can get compiled aften from MeGUI server. Try to compare DD encoding with default aften frequency range and with tweaked through -w option.
But you should note, that all these numbers are mostly about development. If you feel that aften "sounds better" then you should use it.
Old 10th November 2009, 18:44   #1031  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
And you start to use ears instead some numbers. AC3 use different acoustic models to cheat human perception, that mean if some number show that codec A is better than B, B still can be fully transparent to A. Same as PSNR and SSIM for Video measuring.
shon3i is offline   Reply With Quote
Old 10th November 2009, 21:07   #1032  |  Link
yesgrey
Yes, I forgot to look at those...
Name		|  SNR	| PEAQ
		640 kbps
I know that maybe it could be slightlt off-topic, but could you, by any chance, also show the numbers for DTS 1510kbps?
It would be interesting to compare the results with the AC3 640kbps, since some tests showed that AC3 640kbps is superior to DTS 1510kbps...
Old 11th November 2009, 20:22   #1033  |  Link
raquete
Abradoks
first i thank you to send the samples and source.
to encode with aften i use WAVtoAC3Enc4.1, all adjusts default(aften R832, newers versions don't work in my old win2000).
224k: sounds equal, frequences don't go ahead 9KHz.
448: WOW, your sample sounds good, is clever and go ahead 20KHz.
with aften sounds good too but don't go ahead 17KHz.
see?!? hearing we can feel differences!
...now i have requests to use it in WAVtoAC3Enc
cheers and thanks again.
Old 11th November 2009, 21:16   #1034  |  Link
Abradoks
Please try to compare aften encodings with different frequency cutoffs. Here are six samples: aften_wide ("-w 60" for 448 kbit/s and 224 kbit/s; full range), aften_spec ("-w 48" and "-w 8"; DD range) and aften ("-w 34" and "-w 6"; default range).
Old 12th November 2009, 15:58   #1035  |  Link
raquete
Abradoks, i'm horrible in command lines and i use WAVtoAC3Enc4.1(Aften) and don't know how to do the rights adjusts in this prog too.
can you write the command lines to use Aften with yours parameters posted please?
thanks.
Old 12th November 2009, 17:34   #1036  |  Link
arestarh
arestarh's Avatar
thanks.
Maybe this option in WAVtoAC3Enc is equel to key -w in command line mode:
arestarh is offline   Reply With Quote
Old 12th November 2009, 19:26   #1037  |  Link
Abradoks
It was just a description of samples I was linking to. You can just download it, no need to encode by yourself.
Old 13th November 2009, 13:49   #1038  |  Link
raquete
ok, i got the files to hear and measure.
output.224.aften don't go ahead 9KHz.
output.224.aften_spec don't go ahead 9,5KHz.
output.224.aften_wide go ahead 23KHz.
output.448.aften don't go ahead 17KHz.
output.448.aften_spec go ahead 20,5KHz.
output.448.aften_wide go ahead 23KHz.
"wide" samples are very very good, 224.aften_wide and 448.aften_spec is very nice too!
i could feel better differences if was know musics but the samples are clevers.
thanks and regards!
Old 15th November 2009, 19:36   #1039  |  Link
jruggle
So far the only significant difference I've found between the Aften output and the DD output is channel coupling. The bandwidth reported for DD is the upper end of the coupling range. Aften does not support channel coupling yet.
The problem I've had implementing it in Aften has been the complexity of the code due to simd and multi-threading. As an experiment, I stripped all of that out and was able to get working channel coupling (although it was much slower obviously). I'm still working on trying to get it ported over to Aften.
Based on the AC-3 features used, the only other place where there could be some differences is in the exponent strategy decision. I have not analyzed this very thoroughly yet. I think Aften's exponent strategy implementation is pretty good though.
edit: oh, and not that it will matter a lot, but for any further comparisons you should turn on block switching in Aften since DD does block switching by default.
jruggle is offline   Reply With Quote
Old 15th November 2009, 19:50   #1040  |  Link
tebasuna51
tebasuna51's Avatar
Very much appreciated your effort to improve Aften.
