#41 | Link | ||
Posts: n/a
#42 | Link |
Posts: n/a
So as a little update, I've fixed BDSUP parsing code to finally handle subpictures with multiple image objects correctly which means that it no longer crashes in files such as this. It is now hugely simplified and easier to follow.
![]() Last edited by paradoxical; 1st February 2013 at 19:20. |
#44 | Link | |
where i can download it? |
#47 | Link |
Posts: n/a
Just as an additional heads up, until I post a build with the multiregion support I will be pushing lots of incremental changes to Git. If you are building from Git expect there to be breakages along the way until things stabilize again. While the parsing for SUP files works, decoding the separate regions and merging them into a single image is still wonky, proper BD SUP output maintaining the multiregions needs to be added. Also on the BDN+XML side, the input reading needs to be fixed so that any event with multiple graphics is supported correctly along with correctly outputting the multiple graphics when being generated from a BDSUP file with multiregion subpictures. All-in-all, it'll be big refactoring and change job so it might take most of the week to fix up, but in the end the tool will be much more useful in light of its current restrictions.
#48 | Link |
using 1.0.1 if I call 'bdsup2sub++.exe -h'
I just get a bunch of: Code:
QTextStream: No device Code:
APPCRASH Anwendungsname: bdsup2sub++.exe Anwendungsversion: 0.0.0.0 Anwendungszeitstempel: 51030a54 Fehlermodulname: nvinit.dll_unloaded Fehlermodulversion: 0.0.0.0 Fehlermodulzeitstempel: 506b31f3 Ausnahmecode: c0000005 Ausnahmeoffset: 72dace39 Betriebsystemversion: 6.1.7601.2.1.0.256.48 Gebietsschema-ID: 1031 Zusatzinformation 1: 0a9e Zusatzinformation 2: 0a9e372d3b4ad19135b953a78882e789 Zusatzinformation 3: 0a9e Zusatzinformation 4: 0a9e372d3b4ad19135b953a78882e789 He's using Windows 7 64bit primary graphic using Intel HD drivers v8.15.10.2827 secondary graphic: NVidia (GTX460) driver v306.97 Last edited by Selur; 5th February 2013 at 20:55. |
#57 | Link |
Hi, bdsup2sub is having dificulties dealing with this subtitle file: http://www.sendspace.com/file/igjzoy
It's from the star wars bluray which is using seamless branching. This sup file comes from a very short m2ts file (2min opening crawl) and contains no actual subtitles inside, which I guess is the cause of the problem. |
#59 | Link |
Yes, but i want to convert it to bdn xml and i can't.
You'll ask why i would like to do that? Because i want to re-author the bluray and it must contain these empty subs, because as i mention before it is seamless, so this part's subs are empty, but others aren't. Last edited by nautilus7; 14th February 2013 at 18:22. |
