Old 25th January 2006, 06:16   #281  |  Link
dumbas..
Its all in the name....
@ChronoCross
Thanks for the reply and Link post
Tried 1/19/06 (result below) and the other two in the link with the same result.
Unfortunately....
Yes, you guessed, they did not crash but still gave the error
Starting job job1 at 05:00:23
Job is a mux job. Commandline:
-add "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\megui video.mp4" -add "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\megui audio.mp4":lang=eng -new "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\blah.mp4"
successfully set up muxer
Processing ended at 05:00:24
Log for job job1
IsoMedia import - track ID 1 - Video (size 640 x 272)
Unknown input file type
Error importing C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\megui audio.mp4:lang=eng: Feature Not Supported
(Feature Not Supported)
Grrrrrr, IS IT ME ?
dumbas.. is offline
Old 25th January 2006, 06:27   #282  |  Link
ChronoCross
Does it really matter?
ChronoCross's Avatar
What audio encoding are you using?
ChronoCross is offline
Old 25th January 2006, 07:53   #283  |  Link
puffpio
Originally Posted by berrinam
Can you test this in 0.2.3.2041 when it is released? I _think_ I fixed it there, but your testing again would be appreciated.
yes.. I will definately test it once it is released
puffpio is offline
Old 25th January 2006, 14:56   #284  |  Link
dumbas..
AAC via Besweet,FAAC.exe & dll
See output log
http://forum.doom9.org/showthread.ph...305#post774305
Tried to anticipate your next and changed Besweet from ver dated 17 May 2005 to that used in Staxrip ver 1.5b31
All seems ok now on test vob. I will try a full DVD and see what happens.
Hope I won't be troubling you again (fingers crossed)
dumbas.. is offline
Old 25th January 2006, 16:09   #285  |  Link
The Link
The Link's Avatar
Probably a mistake/misunderstanding on my side but could it be that the one-click encoder is broken, i.e. if i click "go" only the dgindex job is sent to the job queue.
When birds burp, it must taste like bugs! (Calvin&Hobbes)
The Link is offline
Old 25th January 2006, 16:18   #286  |  Link
Raithmir
2033 shutdown after encoding box on the queue tab seems to only work if you click it before you start processing.
Raithmir is offline
Old 25th January 2006, 16:36   #287  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
Yes, you are mistaken. We does'nt need count && names of the output of dgindex job so we can't add all of them at once. When dgindex job was finished special postprocessing code will be invoked. This code analyzes dgindex output via folder scan and add encoding/mux jobs to queue
dimzon is offline
Old 25th January 2006, 16:38   #288  |  Link
Doom9
clueless n00b
There's a German saying I like "Probieren geht über Studieren". Try it and see what happens. Hint: MeGUI as currently incapable of creating video jobs without the AviSynth input being present.. and that input only exists once the indexing job has been run.
Could you elaborate this a bit? What exactly can be done to reproduce the problem, starting with the double click on megui.exe.
Doom9 is offline
Old 25th January 2006, 16:43   #289  |  Link
The Link
The Link's Avatar
Hmm ... well, after the dgindex job has finished megui (2045) simply silently quits and that's it (shutdown after encoding is not activated).
edit2: could the problem be that the extracted audiotrack is a wav file?
The Link is offline
Old 25th January 2006, 16:56   #290  |  Link
dimzon
dimzon's Avatar
I'm not shure (i'm not take close look @ this part of code) but i guess you are right - problem is wav audio...
dimzon is offline
Old 25th January 2006, 16:58   #291  |  Link
The Link
The Link's Avatar
Yepp, just tested another source with ac3 audio, which works. The culprit seems to be pcm audio extracted to a wav file by dgindex.
The Link is offline
Old 25th January 2006, 18:43   #292  |  Link
ChronoCross
The only DVD's I've seen that use wav audio are the anime ones I import from japan. What kind of DVD's are these?
Old 25th January 2006, 18:46   #293  |  Link
The Link
The Link's Avatar
I used a simple music video from my massive attack DVD. Music videos on DVD often have pcm audio afaik.
The Link is offline
Old 25th January 2006, 19:48   #294  |  Link
Doom9
clueless n00b
iirc (and without looking at the sources), I think the "find audio after dgindex" routine only looks for ac3 files.. it probably b0rks when there's none found even though you chose to demux something. I should definitely have a look but then again, right now I have to spend that free time on other things.
Doom9 is offline
Old 25th January 2006, 22:16   #295  |  Link
berrinam
berrinam's Avatar
Actually, it *should* pick up wav audio, too:
					if (file.IndexOf(trackNumber) != -1 &&
                        (file.EndsWith(".ac3") ||
                         file.EndsWith(".mp3") ||
                         file.EndsWith(".mp2") ||
                         file.EndsWith(".mpa") ||
                         file.EndsWith(".dts") ||
                         file.EndsWith(".wav"))) // It is the right track
						audioFiles.Add(file);
However, that code is case sensitive, which means it requires the extension to be in lower case (that's the bug).
@The Link: What is the filename of your wav audio?
berrinam is offline
Old 25th January 2006, 22:25   #296  |  Link
The Link
The Link's Avatar
The filename is "VTS_01_1 T01 48K 16bit 2ch.wav". Perhaps there is another reason then.
The Link is offline
Old 25th January 2006, 22:32   #297  |  Link
berrinam
berrinam's Avatar
Hmm.... weird..... it *should* pick it up. Could you upload a small sample, just so I can test a VOB-with-PCM?
berrinam is offline
Old 25th January 2006, 22:50   #298  |  Link
stax76
stax76's Avatar
Hehe, I think the apps that create upper case want to test other apps which just to easiliy fall over that. Recently I got some feedback that DVD Decrypter demuxed files (upper case) won't mux with DivXMux (needs lower case!). Being warned I searched then my code for 'EndsWith' and was embarrassed to find how often I was using 'EndsWith' for file extension comparison.
stax76 is offline
Old 26th January 2006, 00:40   #299  |  Link
berrinam
berrinam's Avatar
Found and fixed: it was looking for the delay, and crashed when it didn't say it in the filename. Fixed in 0.2.3.2050.
berrinam is offline
Old 26th January 2006, 11:50   #300  |  Link
L4z4rus
L4z4rus's Avatar
Cannot Open Video input error
Since 0.2.3.2048 (now using .2050) I seem to keep getting this message when clicking the Preview button in the Avisynth script generator window (to update Video Preview after using resize).
I haven't had any problems in the past, and the initial preview opens fine after loading a d2v file:
The file LoadPlugin("C:\Program Files\Media\DGIndex\dgdecode.dll")
mpeg2source("C:\DVD\24-08\VTS_01_1.d2v")
#blank deinterlace line
#crop
LanczosResize(640,352)
#denoise
cannot be opened
Unable to load DLL 'AvisynthWrapper': The specified module could not be found
The script opens fine in Virtual Dub, Media Player etc. & I have Helix YUV codecs installed / FFDShow (setup as per guide).
L4z4rus is offline
