9th June 2013, 22:36 | #17401 | Link |
I'm not familure with MakeMKV, however that's interesting. I've not noticed any flaws in A/V when watching my original (2 times) or my backups (Full Backup and Movie & Menus blanking extras) (several...with friends). Interesting to note, though, because though I haven't noticed it even in the extras doesn't mean it isn't there. I appreciate the note.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 9th June 2013 at 23:17. |
10th June 2013, 10:25 | #17403 | Link |
@colinhunt
I get your frustration. Did you remove all "metallic debris" from fans, RAM, chips? Check everything really well from an "explosion" like that. I mean, use a magnifying glass! If you're still using the same Motherboard and RAM.. Get the idea? :-) BSOD is something to Notice; it's not BD-RB! Attention to the Blue message. It's not just "random characters". Nothing is random.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
10th June 2013, 13:19 | #17407 | Link | |
But i didnt find another one for Chinese/Mandarin Last edited by dt5; 10th June 2013 at 13:21. |
10th June 2013, 16:05 | #17408 | Link |
So I'm a little tested and found out I'm as though problem evidently does not make BD Rebuilder, but TsMuxer. Problem featured in my threads above displays also at Blu-ray movies that the were to be trimming in TsMuxer without packing.
It is possible anyhow repair TsMuxer, to build in Blu-ray correctly? If Blu-ray built in TsMuxer yet process without compression only with remove some subtitles in DVDfab so result already this feature has not. Evidently some error at generation CLPI file. Thank for nomenclature, help and pertinent correction problem in TsMuxer. |
10th June 2013, 16:30 | #17409 | Link | |
TSMuxer builds correctly. I've personally used it on thousands of builds. I can't speak to trimming -- as I never use it (and neither does BD-RB). Last edited by jdobbs; 10th June 2013 at 16:33. |
11th June 2013, 02:09 | #17410 | Link |
Auto Crop Black Borders?
Not sure if this is a bug, or just my needing a better understanding of this option...
Doing Alt Movie only, MKV 1920x1080.... I converted a few movies without "auto crop black borders" set. The output files looked as expected, and appeared to have the black borders as part of the files. So I set the option for "auto crop" and encoded. I did Star Trek 4 - The Voyage Home, its source M2TS was 1920x1080 with top and bottom black bars in the M2TS. Its output MKV was what I expected... 1920x818 with no black bars. Then I did Star Trek 6 - The Undiscovered Country, when I look at the source main M2TS from the disc, its the same 1920x1080, and has black bars top and bottom only, so I expected the output MKV to be 1920 by something. Instead the output MKV was 1596x818, and the sides are definitely cropped off. So does this sound like a bug and something I should post logs for? or is there an explanation for what happened? Last edited by Mark_Venture; 11th June 2013 at 02:13. |
11th June 2013, 02:48 | #17411 | Link |
@Mark_Venture
It's possible that the section sampled for cropping was dark on the left and right side fooling the software into assuming black bars. As far as cropping BD's, you might be saving less than 1% of the final size. |
11th June 2013, 02:51 | #17412 | Link | |
11th June 2013, 05:07 | #17414 | Link |
THe best option I can think of, would be to measure the black bars (and or video), and instruct rebuilder to crop that particular size. Because even making a calculation based on aspect ratio may not be spot on (Decimals). For example, you could tell rebuilder that the finished frame height should be 840Px high, thereby cutting 120 off the top, and 120 off the bottom. Seems like this would be the most error proof to me But I'm certainly no coder.
Only one rooster, need be in the hen house... |
11th June 2013, 05:27 | #17415 | Link |
A sampling like what AutoGK does for DVD's to AVI/DivX/XviD would be a good idea...? It samples small bits of the entire video to get the right cropping digits. How exactly, I'm not sure. I've never seen a bad crop with whatever method was used with it. That might also prove helpful for movies like, The Matrix... For what it's worth. :-)
11th June 2013, 18:53 | #17416 | Link |
Having trouble with Wreck it Ralph, after several failed attempts - can someone tell me what i'm doing wrong ? and provide me some guidance as normally I have no problems Thanks ! ---------------------- [06/11/13] BD Rebuilder v0.44.06 (beta) [18:32:42] Source: WRECK_IT_RALPH_00800 - Input BD size: 24.23 GB - Approximate total content: [01:41:13.525] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: iPad MP4 HD, 1280x720, 128Kbs AAC - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [18:32:42] PHASE ONE, Encoding - [18:32:42] Processing: VID_00875 (1 of 57) - [18:32:42] Extracting A/V streams [VID_00875] - Extracting A/V to M2TS [VID_00875] - Extracting A/V from M2TS [VID_00875] - [18:44:17] Reencoding video [VID_00875] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,313 frames - [18:44:17] Reencoding: VID_00875, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.44.06 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [18:44:24] - Failed video encode, aborted Last edited by amidlad; 11th June 2013 at 18:55. |
11th June 2013, 19:18 | #17417 | Link |
@amidlad
I'd recommend you uninstall/reinstall FFDSHOW, HAALI, and AVISYNTH. If you have any "codec packs" -- remove those first, FFDSHOW has all the CODECs anyone needs. Sometimes other software will impolitely intercept or interfere with the CODECs -- and not even inform you it is doing so. When all the reports say "ok" -- that's usually the issue. |
13th June 2013, 00:37 | #17418 | Link |
BD Rebuidler v0.44.14 (beta)
I have updated the first post of this thread with a link to the most recent version of BD-RB (v0.44.14). Changes for this release:
- Changed the hidden setting MKV_MUXSUPS so that "ON" is now the default. - Removed opencl.dll from the TOOLS folder, with the latest release of X264 it is no longer needed. - Added a new resizing option, 720p-->1080p in the SETUP dialog. - Added two new hidden options "DOWNRESIZE" and "UPRESIZE" enables you to choose an alternate resizing algorithm to be used when video is being made smaller or larger. See the file HIDDENOPTS.TXT for details. - Fixed an error in which encoding was not being forced for 3D conversion, as it should, because a source is already small enough. - Corrected overall progress indicator for pass two of 3D encoding. - Fixed an issue in which PSEUDO sources may not be forced to be reencoded when BD-25 output is selected. - Corrected an issue in which aspect ratio could be incorrectly set on some imported sources with odd height/width settings. - Added code so that chaptering is now enabled for iPhone/iPad output. These products do not use standard MP4 chaptering. - Disabled open GOPs when outputting to Level 4.1 supporting iPads, iPhones & iPods. This should result in better seeking during playback. - Added the ability to browse for and use the Nero AAC encoder for ALTERNATE output in the SETUP dialog -- for those who prefer it over FAAC. The Nero encoder is not included in BD-RB and must be installed separately. - Corrected an anomaly that could result in zero titles selected and a "Runtime Error 76" during import of a DVD. - Updated the included version of MP4BOX to the latest revision (v0.5.0) - Other minor corrections and cosmetic fixes. |
13th June 2013, 01:00 | #17419 | Link |
about that neroaacenc audio coder. You may be able to include it. Nero is offering the codec themselves for free. http://www.nero.com/enu/company/about-nero/nero-aac-codec.php. They only need an email to download it (and don't even check if its a real one, the download link appears and download starts after entering one. It's not mailed. I enter "none@ofyourbusiness.com" as always . Don't like giving such companies my mail ^^)
13th June 2013, 01:31 | #17420 | Link | ||
