Old 11th December 2018, 17:54   #28221  |  Link
jdobbs
Yep! In my case setting both to Zero solved it. Thanks.
Surprisingly though all items were imported, processed and burnt to the disc including the playlists; it was only on the Stream Tab where some were missing.
Btw. could you already duplicate the .mp4 framerate issue?
That's how it's supposed to work. After they are imported they are treated like any other disc... and very small files (extras) are just kept intact to save time (since they won't save much space). Only the ones that will be processed are listed.
Website: www.jdobbs.net
Old 11th December 2018, 19:22   #28222  |  Link
Sharc
I see, this explains it. They are copied intact rather than being skipped - it seems I forgot that
Now there remains still the framerate issue. This problem remains as it happens already during import, it seems.
Old 11th December 2018, 23:39   #28223  |  Link
MrVideo
MrVideo's Avatar
Ah Ha! Found it. I still had BDRB set up in Movie Only Backup mode.
Old 12th December 2018, 05:03   #28224  |  Link
jdobbs
It happens to the best of us.
Old 12th December 2018, 07:56   #28225  |  Link
Lathe
Lathe's Avatar
DOHHHHHHHHHHHHHH!
Actually, I've done that before too
Lathe is offline   Reply With Quote
Old 12th December 2018, 13:45   #28226  |  Link
MrVideo
MrVideo's Avatar
Source Issue found
[06:35:09] Importing: SEASON-2
- [06:35:35] Importing video file: (1 of 7)
  - Collecting audio/video streams from source...
  - Integrating into pseudo-BD structure...
    - Source issue found, attempting correction...
[06:38:08]ERROR: Removing compression.  Aborted.
It would be really helpful if BDRB would log what the issue is. BDRB gets thru a little over 91% of the file before failing.
This particular file has been thru VideoReDo twice. The first time to create a TS file as a result of shortening the 2-sec blacks to basically nothing and to mark a spot for a chapter mark. Then that file is used to create the MKV file with chapter marks. VRD had no issues with the video at all.
Old 12th December 2018, 14:10   #28227  |  Link
MrVideo
MrVideo's Avatar
I think I found it. Like I said, it would have been very helpful if BDRB would display the error. In this case, I believe that it ran out of disc space. While setting up for a sat feed capture job, I check to make sure that there is enough space for the capture. There wasn't. And looking at what was left also meant that BDRB didn't have the space either for the first file.
EDIT: Yep, that was it.
Old 12th December 2018, 20:23   #28228  |  Link
Lathe
Lathe's Avatar
Hmmm... Let's see now:
1) Forgot the 'Movie Only' setting.
2) Forgot to check if there was enough space.
Yep, about time for 'The Home' I think...
Old 12th December 2018, 20:56   #28229  |  Link
AmigaFuture
AmigaFuture's Avatar
JD,
Coming back to an older problem report of "Doctor Strange (2D)".. When I select to either Movie Only or make an MKV with DTS to AC-3, DTS is not converted (correctly). The process "looks" good as BD-RB's doing it but in the WORKFILES directory, the AC-3 size is 2.50KB.
With MKV it fails to mux, of course. But Rebuilding BD structure doesn't fail and when playing back with Player or PDVD12..of course, not any audio.
Also, a friendly reminder. Checked "Role Models" extra yet?
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 12th December 2018, 21:36   #28230  |  Link
musiclover
Originally Posted by musiclover View Post
General
Complete name               : F:\Muse - 2018-09-21 Reeperbahn Festival, Hamburg.ts
Format                      : MPEG-TS
File size                   : 1.44 GiB
Duration                    : 1 h 4 min
Overall bit rate mode       : Variable
Overall bit rate            : 3 221 kb/s
Video
Menu ID                     : 1 (0x1)
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : Main@L3.1
Format settings             : CABAC / 2 Ref Frames
Format settings, CABAC      : Yes
Format settings, ReFrames   : 2 frames
Format settings, GOP        : M=1, N=50
Codec ID                    : 27
Bit rate mode               : Constant
Nominal bit rate            : 2 800 kb/s
Width                       : 1 280 pixels
Height                      : 720 pixels
Display aspect ratio        : 16:9
Frame rate                  : 25.000 FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Bits/(Pixel*Frame)          : 0.122
Audio
Menu ID                     : 1 (0x1)
Format                      : AAC LC
Format/Info                 : Advanced Audio Codec Low Complexity
Format version              : Version 4
Muxing mode                 : ADTS
Codec ID                    : 15-2
Bit rate mode               : Variable
Channel(s)                  : 2 channels
Channel layout              : L R
Sampling rate               : 48.0 kHz
Frame rate                  : 46.875 FPS (1024 SPF)
Compression mode            : Lossy
Delay relative to video     : -1 s 159 ms
Menu
Menu ID                     : 1 (0x1)
List                        : 256 (0x100) (AVC) / 257 (0x101) (AAC)
Service name                : Service01
Service provider            : FFmpeg
Service type                : digital television
[16:21:43] Importing TS: MUSE_-_2018-09-21_REEPERBAHN_FESTIVAL,_HAMBURG
  - Preparing TS for processing...
  - Building pseudo-BD source structure...
[16:23:50] Video import completed successfully.
[AudioAdjust]
00000=.TimeStretch(tempo = 23.976/25.0*100.0)
[ImportFile]
00000=F:\Muse - 2018-09-21 Reeperbahn Festival, Hamburg.ts
[Options]
VERSION=0.60.0.4
ENABLE_TEST=1
ENABLE_BLANKING=1
BLANK_THRESHOLD=0
ALTERNATE_BLURAY=0
; AUDIO_AMPLIFY=NORMALIZE
; KEEP_HD_LPCM=0
; AUTO_TWOPASSONLY=1
MIN_M2TS_SIZE=0
ENCODER=0
MODE=3
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
AUDIO_TO_KEEP=dut;eng;nld;und;
SUBS_TO_KEEP=dut;eng;nld;und;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=0
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
AUDIO_DRC=0
DECODER=0
AVCHD=0
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=1
SUPTITLE=1
PGSTOSRT=1
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=22000
MOVIEONLY_TYPE=1
ALTCRF=20
ALT_TARGET=850
ALT_CRF_TARGET=5000
ALTMETHOD=2
ALTAUTOCROP=1
TARGET_SIZE=22000
ASSUME_DVD_PAL=1
MENU_BACKGROUND=C:\BD Rebuilder\BD_Rebuilder\misc\menuback.jpg
MENU_AUDIO=C:\BD Rebuilder\BD_Rebuilder\tools\blankclip\blank.ac3
IMPORT_THRESHOLD=0
IMPORT_PAL_TO_FILM=0
QUICK_PLAY_THRESHOLD=0
MENU_AUTO_BACKGROUND=1
MENU_AUTO_DVDAUDIO=1
MENU_PLAY_SEQUENTIAL=1
MENU_START_WITH_MENU=1
IMPORT_LIMIT_LANG=0
IMPORT_KEEP_PLAYALL=1
QUICK_PLAY_THRESHOLD=1
QUICK_EXTRAS=1
WIDE_PERCENT=100
WIDE_OFFSET=1
IMPORT_PREPARE_MKV=1
KEEP_HD_AUDIO=0
MENU_MAXITEMS=15
[Paths]
WORKING_PATH=F:\WORK\
NeroAACPath=C:\BD Rebuilder\NeroAACCodec-1.5.1\win32\neroAacEnc.exe
SupTitlePath=C:\BD Rebuilder\suptitle_v2.0.8_x86\SupTitle.dll
SOURCE_PATH=F:\WORK\IMPORTS\MUSE_-_2018-09-21_REEPERBAHN_FESTIVAL,_HAMBURG\
I can send you a clip of the offending file if it helps you
Does anyone have any idea why my 25fps file on import is being converted to a 23.976fps file? And, more important, how to avoid that?
musiclover is offline   Reply With Quote
Old 13th December 2018, 00:37   #28231  |  Link
Sharc
Does anyone have any idea why my 25fps file on import is being converted to a 23.976fps file? ….
Slowdown due to too many beers from the Reeperbahn?
Old 13th December 2018, 00:49   #28232  |  Link
jdobbs
@AmigaFuture
Sorry... I'm so many layers deep in the UHD muxing thing that I'm not really looking at anything else.
To everyone... please keep track of your bug reports so you can remind me after I make the next UHD release. I'll try to catch up then.
Old 13th December 2018, 04:35   #28233  |  Link
MrVideo
MrVideo's Avatar
I shouldn't have to check for space. It is a computer, it is supposed to tell me these things when it happens, not crash the program and make me hunt-n-peck as to what happened.
Old 13th December 2018, 04:48   #28234  |  Link
MrVideo
MrVideo's Avatar
I just discovered a nice new feature in the latest version, which I must have missed in the changes list. And that is the conversion of EAC3 file to AC3 files, instead of BDRB failing. I was testing the standalone playability of some MKV files and noticed that the EAC3 was being converted. I wasn't paying attention that the files even had EAC3 audio.
Old 13th December 2018, 14:43   #28235  |  Link
jdobbs
BD-RB tells you how much space you have available in the log. The secret is that you have to look at it.
Old 13th December 2018, 16:42   #28236  |  Link
MrVideo
MrVideo's Avatar
Where?
[06:54:18] Importing: 16._GOD_JOHNSON
- [06:54:25] Importing video file: (1 of 1)
[06:55:49] Video import aborted per user request.
[08:12:35] Importing: SEASON-2
- [08:13:04] Importing video file: (1 of 7)
- [08:15:28] Importing video file: (2 of 7)
- [08:17:50] Importing video file: (3 of 7)
- [08:20:13] Importing video file: (4 of 7)
- [08:20:23] Importing video file: (5 of 7)
- [08:20:39] Importing video file: (6 of 7)
- [08:20:46] Importing video file: (7 of 7)
- [08:20:55] Creating Quick-Play Menu...
   - Encoding menu background...
   - Building menu structure...
[08:21:59] Video import completed successfully.
[21:16:56] Importing: SEASON-3
- [21:17:04] Importing video file: (1 of 2)
  - Converting audio, Track #2, EAC3 to AC3...
- [21:19:06] Importing video file: (2 of 2)
- [21:21:30] Creating Quick-Play Menu...
[21:22:33] Video import completed successfully.
[09:23:25] Importing: SEASON-3
- [09:23:45] Importing video file: (1 of 9)
- [09:24:25] Importing video file: (2 of 9)
- [09:25:03] Importing video file: (3 of 9)
- [09:25:49] Importing video file: (4 of 9)
- [09:26:31] Importing video file: (5 of 9)
- [09:27:24] Importing video file: (6 of 9)
- [09:30:39] Importing video file: (7 of 9)
- [09:33:17] Importing video file: (8 of 9)
- [09:35:45] Importing video file: (9 of 9)
- [09:38:09] Creating Quick-Play Menu...
[09:39:12] Video import completed successfully.
Old 13th December 2018, 17:27   #28237  |  Link
jdobbs
Where?
In a normal backup run... but not an import. It doesn't matter anyway. BD-RB isn't responsible for managing your hard drive space.
Old 13th December 2018, 17:37   #28238  |  Link
MrVideo
MrVideo's Avatar
In other words, it isn't in the log.
That is true. The point is that most programs report that it has run out of disc space, Just being friendly to the user. In this case, BDRB ran out of HD space and went off in a tangent. The tangent made me believe that there was something wrong with the source file. IMHO, a bug.
Old 13th December 2018, 17:42   #28239  |  Link
jdobbs
IMHO, a bug.
IMHO, not.
Old 13th December 2018, 17:45   #28240  |  Link
AmigaFuture
If you are literal about it, BD-RB didn't run out of space at all, the HD did. BD-RB only reports it or shows it if "told" to do so, as other programs do as you noted. Reporting is different than causing. Windows will report low storage, only because it's programmed to. It doesn't "care".
