Old 16th June 2008, 10:53   #401  |  Link
wyti
Insane Encoder
wyti's Avatar
Can anyone compile a patch with me-prepass ? Or the patch is actually borked ?
wyti is offline   Reply With Quote
Old 16th June 2008, 11:58   #402  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
from the author of pre-pass ...
ME-prepass is just a simple ugly hack to do tons of hex searches. Its not particularly pretty or efficient
Use most available patch doesn't mean always better quality!
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 16th June 2008, 12:35   #403  |  Link
wyti
Insane Encoder
wyti's Avatar
True but.
Dark Shikari isn't the author of pre-pass
And I ask this because I tried it, and I use it with a lot of my encodes (I usually encore small clips of 2-3 minutes) and it give me better results than --me esa.
Old 16th June 2008, 13:42   #404  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
dark shikari IS the author... iirc death the sheep just kept it up to date.
Old 16th June 2008, 13:53   #405  |  Link
wyti
Insane Encoder
wyti's Avatar
Thanks for the explanation, but what about this patch itself, is it borked, or no one want to use it ?
Old 16th June 2008, 14:10   #406  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
I'm too lazy to keep it updated with all the changes I've been making to me.c, I never figured out entirely why it worked at all, and people these days aren't exactly demanding more "lots of time for very little quality boost" improvements anyways.
Old 16th June 2008, 14:37   #407  |  Link
wyti
Insane Encoder
wyti's Avatar
Ok thanks, but i think that with the good speed boost, we can introduce some quality boost too.
if I understand, the patch isn't dead, but someone have to maintain it ?
Old 16th June 2008, 15:03   #408  |  Link
techouse
Strictly Rhythm
techouse's Avatar
A high --merange and --me esa or tesa would probably give you the same results.
techouse is offline   Reply With Quote
Old 16th June 2008, 15:07   #409  |  Link
wyti
Insane Encoder
wyti's Avatar
Yes but with pre-pass i got about 1.5fps, that was not bad for a 3minutes long clip. But with esa, it is significantly slower, i don't remember the exact numbers, but around 0.8-0.9 fps, with a very slighly better result...
for me umh + prepass was very good.
Now i have to learn how to maintain me-pre-pass patch
Old 16th June 2008, 15:26   #410  |  Link
techouse
Strictly Rhythm
techouse's Avatar
It's quite nasty cause the problem is in the encoder/me.c section which is very SENSITIVE. Good luck.
Old 16th June 2008, 16:07   #411  |  Link
bob0r
Pain and suffering
bob0r's Avatar
x264.886.modified.01.exe
x264.886.modified.01.source.zip
x264.psyRDO.0.22.diff
http://forum.doom9.org/showthread.php?t=138293
x264_hrd_pulldown.04_interlace.diff
HRD and pulldown for HD compatibility, updated patch for interlacing
http://forum.doom9.org/showthread.ph...19#post1047919
x264.progress.indication.01.diff
http://forum.doom9.org/showthread.php?t=135905
Link to x264 patches collected: http://files.x264.nl/x264_patches/
Here is the output of the patching process:
http://files.x264.nl/x264.886.modified.01.patch.out.txt
Here is the output of the compiling process:
http://files.x264.nl/x264.886.modifi...ofiled.out.txt
gcc -O4 -ffast-math -Wall -I. -DHAVE_MMX -DARCH_X86 -DSYS_MINGW -DPTW32_STATIC_LIB -DHAVE_PTHREAD -s -fomit-frame-pointer -fprofile-generate -c -o encoder/set.o encoder/set.c
encoder/set.c: In function `x264_sps_init':
encoder/set.c:215: warning: unused variable `cpbBrVclFactor'
gcc -O4 -ffast-math -Wall -I. -DHAVE_MMX -DARCH_X86 -DSYS_MINGW -DPTW32_STATIC_LIB -DHAVE_PTHREAD -s -fomit-frame-pointer -fprofile-use -c -o encoder/encoder.o encoder/encoder.c
encoder/encoder.c: In function `x264_encoder_encode':
encoder/encoder.c:1278: warning: 'cpb_removal_delay' might be used uninitialized in this function
darkorange = x264_hrd_pulldown.04_interlace.diff
The warnings that are not in the GIT code are highlighted with a color, and should not be there.
(The GIT warnings are there because of a bug in Windows, they prevent the usage of extended zones, example: x264 --zones 1,100,bframes=0)
The GIT warnings:
gcc -O4 -ffast-math -Wall -I. -DHAVE_MMX -DARCH_X86 -DSYS_MINGW -DPTW32_STATIC_LIB -DHAVE_PTHREAD -s -fomit-frame-pointer -fprofile-generate -c -o common/common.o common/common.c
common/common.c: In function `x264_param_parse':
common/common.c:252: warning: unused variable `saveptr'
gcc -O4 -ffast-math -Wall -I. -DHAVE_MMX -DARCH_X86 -DSYS_MINGW -DPTW32_STATIC_LIB -DHAVE_PTHREAD -s -fomit-frame-pointer -fprofile-generate -c -o encoder/ratecontrol.o encoder/ratecontrol.c
encoder/ratecontrol.c: In function `parse_zone':
encoder/ratecontrol.c:564: warning: unused variable `saveptr'
encoder/ratecontrol.c: In function `parse_zones':
encoder/ratecontrol.c:607: warning: unused variable `saveptr'
bob0r is offline   Reply With Quote
Old 19th June 2008, 06:59   #412  |  Link
IgorC
sorry for offtopic
Could somebody show a clear sample where --merange > 16 and --me (t)esa would be helpfull? Really.
I tested some videos and never have seen where is it so usefull (at all?).
And --me-prepass was more efficient than tesa and merange some time ago.
http://forum.doom9.org/showthread.php?p=1054774
IgorC is offline   Reply With Quote
Old 19th June 2008, 09:20   #413  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Originally Posted by IgorC View Post
sorry for offtopic
Well I make a little test with 10 000 frame from Casino Royal (1080p24 at crf 22) and tesa + merange 32 produce something like 1% improvement (lower bitrate and higher metric).
Old 19th June 2008, 18:28   #414  |  Link
IgorC
Thanks for throw some numbers. I expected practically the same.
But I think it's correct to keep insane settings (tesa, merange). This way user know the limits of encoder and there is no paranoid thoughts about if it's possible to squeeze the last .% of quality when it's necessary.
Old 20th June 2008, 05:19   #415  |  Link
skystrife
skystrife's Avatar
x264.889.modified.exe - Source
(alt download link)
Patches:
gcc 3.4.5 fprofiled build
Built in mingw on Windows Vista x64.
Enjoy.
skystrife is offline   Reply With Quote
Old 24th June 2008, 13:13   #416  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
Hmm.... I think i developed a small patch that relaxes the qpfile to be able to only specify certain frames of the video (i believe this was mentioned as a feature request somewhere)
http://kemuri9.net/dev/x264/x264_qpfile_relax.diff
(based on r889)
if someone else can confirm this for me that would be great
Edit:
Just changed it up a little to increase efficiency on reading the qpfile for only specifying certain frames
kemuri-_9 is offline   Reply With Quote
Old 25th June 2008, 04:49   #417  |  Link
MythCreator
x264.modified.r891.exe
Source
General thread:
http://forum.doom9.org/showthread.php?t=130364
X264_progress.indication.diff
x264_qpfile_relax.diff.diff
http://forum.doom9.org/showthread.ph...19#post1151919
x264_interlaced_signaling.r886.diff
http://mailman.videolan.org/pipermai...ne/004656.html
GCC 3.4.5 build fprofiled
MythCreator is offline   Reply With Quote
Old 25th June 2008, 18:18   #418  |  Link
jethro
http://kemuri9.net/dev/x264_qpfile_relax.diff
(based on r889)
Edit:
You mean the feature request in this thread?
http://forum.doom9.org/showthread.php?t=120449
So with your patched qpfile we may e.g., force key frames at specific frames?
jethro is offline   Reply With Quote
Old 25th June 2008, 19:36   #419  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
Ah yes, there was that thread where I read that.
yes, that's how I've been testing it so far and confirming its success in the stats file.
qpfile (entire file)
99 I 35
100 I 30
stats
in:99 out:99 type:I q:35.00 itex:326 ptex:0 mv:308 misc:326 imb:1350 pmb:0 smb:0 d:-;
in:100 out:100 type:I q:30.00 itex:224 ptex:0 mv:418 misc:318 imb:1350 pmb:0 smb:0 d:-;
I did back-to-back keyframes in an attempt to see if it can override the min-keyint parameter and it does.
The qp for the frame is still mandatory, but that's not too big of a deal in my opinion
Old 25th June 2008, 20:05   #420  |  Link
akupenguin
x264 developer
akupenguin's Avatar
btw, relaxing (qp < 0) to (qp < -1) will let you specify some frames as qp=-1 meaning auto.
It's a bad idea to mix a few auto frames into a lot of forced ones, but the other way around should work.
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
