22nd October 2008, 09:54 | #61 | Link |
I found two problems using this GUI
-when I extract an AC3 stream to WAVS using libvab (not nero) the log say it can't find the withe.noise file. -I can't extract AC3 to DTS anymore. the source is a Bluray directory hope this helps |
22nd October 2008, 12:43 | #62 | Link |
1) sounds like a bug with eac3to, do you get the same result when trying the same in a command window? If so, submit a bug on the eac3to thread
2) ahhhh.. due to the filtering of the audio extract types. I will remove this "feature" in the next version |
22nd October 2008, 12:45 | #63 | Link | |
The goal of this tool is to strictly extract streams, nothing more. |
22nd October 2008, 15:35 | #65 | Link | |
I'll try it later today to see if I can reproduce. |
22nd October 2008, 16:21 | #66 | Link | |
edit: try to check this screen capture at http cps.tech.free.fr/temp/pb.JPG Last edited by lobothefoots; 22nd October 2008 at 16:33. |
25th October 2008, 07:35 | #68 | Link |
Looks like it would be a nice GUI, but I can't get it to work. As someone else has said, it crashes on selecting an HDDVD feature as soon as "analysing" gets to 100%.
Tried with a BluRay and got an unhandled exception error. OS = Vista Ultimate. AnyDVD. Last edited by TMC; 25th October 2008 at 07:39. |
25th October 2008, 12:27 | #69 | Link |
Ok I am seriously getting Maybe it's my own discs but I have yet to have it crash on me.
I will release a version with verbose logging. Give it a try with that version on a couple of different discs that you've had issues with. It will be out later today... That way, I can figure out what the problem is and fix it. |
26th October 2008, 07:51 | #70 | Link |
it appears only in your gui, there is nothing in the log;
I guess it is because there is no [a**] tag in front of the line. I can report as well alot of crashes With die hard bluray movie, it loads the content but if I try to demux it crashes. I'll try the verbose version. |
26th October 2008, 22:15 | #73 | Link |
@nwg
I've the same problem. @Greif Great tool! Thanks! One thing, for all my DTS-MA streams the file extension is ".dtshd". But since Stream Extractor uses ".dts" as file extension for DTS-MA streams, I've to rename all the audio streams manually. That's a lot of work and I'm quite lazy , so it would be nice to have an additional file extension for DTS-MA streams and not only ".dts".
Agent 47: "Eat your sandwich, I need to get some sleep." |
27th October 2008, 01:04 | #74 | Link |
For those having problems with loading features, here is a debug version. This version has some extra logging and will create a log file named HdBrStreamExtractor.txt in the same directory.
If you are having issues, please run this version and upload the log file to http://pastebin.com/ so I can review. Thanks. @azad: I need to clean up some of the audio extract types. It should be done soon. |
27th October 2008, 01:12 | #75 | Link |
@nwg/@azad: could either of you show me the output of the discs you are trying to extract from (with DTS HD MA)?
Show me the result of this: Code:
eac3to.exe [disc location] ex. eac3to.exe f: Code:
eac3to.exe [disc location] [stream#] ex. eac3to.exe f: 1) |
28th October 2008, 12:22 | #80 | Link | |
[12.19.55] Retrieving features [12.19.55] Arguments: "C:\Moviez-HD\The Godfather" [12.19.57] Feature Retrieval Completed [12.19.57] Retrieving streams [12.19.57] Arguments: "C:\Moviez-HD\The Godfather" 1) -progressnumbers [12.20.22] M2TS, 1 video track, 6 audio tracks, 16 subtitle tracks, 2:57:09 |
eac3to, hdbrstreamextractor |
