Old 12th July 2019, 00:27   #4801  |  Link
LouieChuckyMerry
LouieChuckyMerry's Avatar
Back for more. After receiving enough help here to upgrade from 32 bit AviSynth+ to 64 bit--thanks again for all the help --for my usual Blu-ray sources, I'm now trying to learn how to use 64 bit AviSynth+ for my DVD sources. I've found all the required 64 bit .dll's for my upscale scripts except ColorMatrix (to convert from Rec.601 to Rec.709). After much searching and reading, it seems that I can simply replace the 32 bit line:
ColorMatrix(Mode="Rec.601->Rec.709")
with:
ConvertTo(Proper Symbols Here)
in 64 bit AviSynth+, but I can't figure out just what the proper symbols are. In case it matters, my script is something like:
DGSource Here
### Deinterlace ###
TFM(Mode=7,UBSCO=False)
### Color Conversion ###
### Adjust Color ###
MergeChroma(aWarpSharp2(Depth=16))
### Crop ###
Crop(8,1,-8,0)
### Gibbs Noise Block ###
Edge=MT_Edge("prewitt",ThY1=20,ThY2=40).RemoveGrain(17)
Mask=MT_Logic(Edge.MT_Expand().MT_Expand().MT_Expand().MT_Expand(),Edge.MT_Inflate().MT_Inpand(),"xor").Blur(1.0)
MT_Merge(Minblur(),Mask,Luma=True)
### Overall Temporal Denoise ###
SMDegrain(TR=3,ThSAD=200,ContraSharp=True,RefineMotion=True,Plane=0,PreFilter=2,Chroma=False,n16=True,n16_Out=True)
### Resize ###
EDI_RPow2(CShift="Spline64",FWidth=960,FHeight=720)
aWarpSharp4xx(Depth=5)
### Darken-Thin Lines ###
FastLineDarkenMod4(Strength=24,Prot=6)
aWarpSharp4xx(Blur=4,Type=1,Depth=8,Chroma=2)
### Deband ###
F3KDB(Y=100,Cb=100,Cr=100,GrainY=0,GrainC=0)
As always, thanks for any help.
Edit: Happy Saturday! After banging my (obviously thick) head against the wall for a while longer I realized that MeGUI has a copy of ColorMatrix.dll in its AviSynth_Plugins folder, so I borrowed a copy from the 64 bit version and all is well. I'd still be curious if "ConvertTo(Something)" would do the same job...
LouieChuckyMerry is offline   Reply With Quote
Old 14th July 2019, 20:01   #4802  |  Link
real.finder
bug in expr? in float(32)
mt_lut( "x range_half - 0.1 * range_half +", scale_inputs="floatf", U=3,V=3 )
not same as
expr( "x range_half - 0.1 * range_half +" ,scale_inputs="floatf")
without scale_inputs="floatf" they are same
My Avisynth Stuff
Old 16th July 2019, 10:02   #4803  |  Link
pinterf
not same as
Do you know which one is correct?
pinterf is offline   Reply With Quote
Old 16th July 2019, 15:19   #4804  |  Link
real.finder
the mt_lut one is correct
My Avisynth Stuff
Old 16th July 2019, 15:29   #4805  |  Link
pinterf
O.k. thanks, I check them both and found no problem for a quick five-minute investigation, so I need more time.
Old 21st July 2019, 08:08   #4806  |  Link
pinterf
This issue was fixed, it's on git already, I'll make a build next week.
Old 21st July 2019, 09:12   #4807  |  Link
real.finder
thank you
My Avisynth Stuff
Old 21st July 2019, 21:38   #4808  |  Link
djonline
Trim not work after Import, only after DirectShowSource.
DirectShowSource("avisynth-stage1-with-MTS.avs") still not work with LAV splitter 0.71
Originally Posted by LigH View Post
Then write the Trim in a separate line, not after a dot.
If the imported script returns a clip, then it should be passed to the usual internal variable "last", which is then implicitly assumed where no explicit clip variable was written.
If it does not return any clip, then it can't be used as video source anyway.
Still not work with Deshaker, video is shaked when using Import
"00425.MTS-pass2.avs"
vid="00425.MTS"
o=DirectShowSource(vid)
o+o.Trim(0,29)
ConvertToRGB32
LoadVirtualDubPlugin ("c:\Program Files\Vdub\vdub64\plugins64\Deshaker_64.vdf", "deshaker",0) deshaker ("19|2|30|4|1|0|1|0|640|480|1|2|1000|1000|2000|2000|4|0|6|2|8|30|300|3|f:\\00425.MTS.1.1000.1000.2000.2000.log|0|0|0|0|0|0|0|0|0|0|0|0|0|1|70|70|10|30|1|1|30|30|0|0|0|0|1|0|1|10|1000|1|88|1|1|20|30000|100|20|1")
00425.MTS-loader.avs
#DirectShowSource("00425.MTS-pass2.avs").Trim(30,0)
Import("00425.MTS-pass2.avs")
Trim(30,0) #video is shaked with this
djonline is offline   Reply With Quote
Old 21st July 2019, 21:51   #4809  |  Link
# "00425.MTS-pass2.avs"
vid="00425.MTS"
# o+o.Trim(0,29)  # Join o.trim(0,29) to END OF o
o.Trim(0,29)  # presume this is required
#o.Trim(29,0) # EDIT: Or, is it this
ConvertToRGB32
deshaker ("19|2|30|4|1|0|1|0|640|480|1|2|1000|1000|2000|2000|4|0|6|2|8|30|300|3|f:\\00425.MTS.1.1000.1000.2000.2000.log"
 \ + "|0|0|0|0|0|0|0|0|0|0|0|0|0|1|70|70|10|30|1|1|30|30|0|0|0|0|1|0|1|10|1000|1|88|1|1|20|30000|100|20|1")
Old 26th July 2019, 17:03   #4810  |  Link
Stereodude
Is there an avisynth+ version of DitherTools by any chance (I searched but came up empty)? If not, is there a way to get dithertool's rgb48y output into RGBP16 which AVIsynth+ handles? I think rgb48y and RGBP16 are basically the same thing just stored differently.
Stereodude is offline   Reply With Quote
Old 26th July 2019, 17:32   #4811  |  Link
real.finder
avisynth+ version of DitherTools? no, it's still avs25/avs26
some DitherTools functions for avs+? yes, like the one I post here maybe there are others by another persons
My Avisynth Stuff
Old 26th July 2019, 22:11   #4812  |  Link
qyot27
qyot27's Avatar
From the Dither tools wiki page:
"rgb48y" 48-bit RGB. The components R, G and B are conveyed on three YV12 or Y8 (if supported) stack16 clips interleaved on a frame basis.
I don't truly know how to interpret that description. Because from what it sounds like, you'd have to treat a Y8 frame (assuming it would default to Y8 on 2.6 and Plus) as an individual RGB plane, but you *also* have to apply ConvertFromStacked() and Select every third frame into individual variables to try then stitching them back together into a real RGBP16 stream with CombinePlanes. That's just my best guess, assuming the 'interleaved on a frame basis' means something like 6 frames being R1-B1-G1-R2-B2-G2, and not 'interleaved' in the sense that Stack16 format's counterpart Interleaved16 was for doing high bit depth.
IMO, I think it'd be easier to see if other Plus-compatible plugins (or its native HBD and dither functionality) can do what you want without bringing DitherTools into it at all.
