Old 18th July 2016, 03:59   #3981  |  Link
littlepox
Originally Posted by herbert View Post
Thanks again, littlepox.
Depending on the chosen speed preset the following options get enabled or disabled:
--no-rskip --limit-modes --rect
Do you have any data as to the usefulness of the above options yet?
--limit-modes is enabled by default at slower or above;
--no-rskip is intolerably slow with little improvement.
littlepox is offline   Reply With Quote
Old 18th July 2016, 06:25   #3982  |  Link
littlepox
--tune film Update:
--crf 18 --ctu 32 --pbratio 1.2 --cbqpoffs -3 --crqpoffs -3 --no-sao --subme 3 --b-intra --no-amp --weightb --aq-mode 3 --aq-strength 0.9 --rd 4 --psy-rd 2.5 --psy-rdoq 4.0 --rdoq-level 2 --rc-lookahead 80 --qcomp 0.65 --no-strong-intra-smoothing --limit-modes
Reintroduce --ctu 32 since further tests suggest the buggy term is --max-tu-size 16, while --ctu 32 is innocent.
Increase psy 2.0:3.0 to 2.5:4.0 which should further reduce blurriness, enhancing visual quality. (bit-rate should increase as well, but worthy)
Add --limit-modes in case someone enables --rect at preset medium (which I strongly DISRECOMMEND; --rect should only be used at preset slower or above)
At the same time, here we go for a --tune animation:
--crf 18 --ctu 32 --ref 4 --bframes 6 --pbratio 1.2 --cbqpoffs -3 --crqpoffs -3 --no-sao --subme 3 --b-intra --no-amp --weightb --aq-mode 3 --aq-strength 0.8 --rd 4 --psy-rd 1.8 --psy-rdoq 1.5 --rdoq-level 2 --rc-lookahead 80 --qcomp 0.65 --no-strong-intra-smoothing --limit-modes
Old 18th July 2016, 12:39   #3983  |  Link
mandarinka
mandarinka's Avatar
What sorts of artifacts do you get from --max-tu-size 16? I encoded some stuff with may/june builds so maybe I could look for them.
mandarinka is offline   Reply With Quote
Old 18th July 2016, 16:26   #3984  |  Link
Barough
Barough's Avatar
x265-v2.0+5-98a948623fdc (MSYS/MinGW, GCC 5.4.0, 32 & 64bit 8/10/12bit multilib EXEs)
Old 19th July 2016, 00:05   #3985  |  Link
benwaggoner
Originally Posted by littlepox View Post
--tune film Update:
For film, what about --ctu 64 --rdpenalty 1 --qg-size 32? That'll still allow those big 32x32 intra blocks, but bias strongly against them so they only get used when they really pay off, and still give you adaptive quant at the 32x32 level.
As for --limit-modes, that only does something when --amp or --rect are on anyway, which is make them a lot faster with a tiny reduction in efficiency.
Also, note there's an issue in --aq-mode 3 currently which causes it to use WAY more bits in CRF mode than --aq-mode 2.
Ben Waggoner
My Compression Book
Old 19th July 2016, 00:06   #3986  |  Link
benwaggoner
I wouldn't expect artifacts so much as reduced compression efficiency.
Ben Waggoner
My Compression Book
Old 19th July 2016, 08:55   #3987  |  Link
K.i.N.G
Wow, that '--no-sao' switch drasticly increased detail (grain) retention for me!
Anyone more knowledgeable on here can tell me what it does... Google results get kinda too technical for me (i dont understand the terminologie)
K.i.N.G is offline   Reply With Quote
Old 19th July 2016, 08:58   #3988  |  Link
RainyDog
Hasn't --aq-mode 3 always been like this even with x264?
RainyDog is offline   Reply With Quote
Old 19th July 2016, 09:04   #3989  |  Link
RainyDog
Also note that littlepox's --tune-film is geared for 1080p.
Old 19th July 2016, 10:35   #3990  |  Link
gamebox
@K.i.N.G: SAO is an encoding step that tries to compensate against some typical encoding artifacts seen in most MPEG compression technologies to date (h265 as well), by altering the image after it is compressed. It changes the way mostly edges look, trying to "iron" (smooth) some defects introduced by compression - the ones that are "expected" to be present in those areas. It does a very good job, but sadly seems to eliminate a lot of details by error too, as it can not define compression defects in an image "precisely" (it would take a lot of data to describe them), so it only has some "general impression" or "expectation" about the way they should look.
A small question about x265 "blurriness" most people complain about - has anyone tried pre-filtering the video before sending it to x265, by applying some sharpening to counter-effect the issue? To me, problem seems motion estimation related - defining further steps in sub-pixel motion precision over previous technologies increased efficiency but introduced many calculation steps that ended up smoothing the pixels too much. That's just an amateur guess, I might be wrong. The issue of x265 sharpness seems to influence "detail clarity" as well as (or even more than) "edge contrast" - it seems to need something like HDR filter in preprocessing as well to improve detail "amplitudes" by actually "over-accenting" them before compression takes place.
gamebox is offline   Reply With Quote
Old 19th July 2016, 10:43   #3991  |  Link
Barough
Barough's Avatar
x265-v2.0+8-669dc9bfe7eb (MSYS/MinGW, GCC 5.4.0, 32 & 64bit 8/10/12bit multilib EXEs)
Old 19th July 2016, 12:30   #3992  |  Link
K.i.N.G
Hey thanks for the very clear explanation.
I dont know about other ppl, but to my eyes, without SAO it still looks allot better than x264 at the same bitrate (arround 4500kb/s) and I dont notice any prominent artifacts (much less than the x264 encode for sure). At least, on my laptop screen it does... I'll be testing it later on my TV.
To me it looks like the SAO switch could use some more dev-tweaking and/or should only be used with very low bitrates... It is way to aggressive right now, imho.
Im using a slightly tuned 'slower' preset so it is allot slower than x264 (it's encoding 1080p at 1.34fps right now).
I'll be testing some more and try to get it faster. If things keep looking this promessing then this will probably make me switch over to x265.
Im using version 1.9+200-6098ba3e0cf16b11 (with staxrip).
Id like to test v2.0 but im still waiting for staxrip to update and have optimized UI for v2.0
Old 19th July 2016, 13:44   #3993  |  Link
Barough
Barough's Avatar
Regarding --ag-mode 3 so do i have to say that it can do more 'harm' then good some times. Have noticed on and off on some of my darker test videos that at the edges of dark & very dark areas there can be some kind of 'ghosting'. With -aq-mode 2 so have there been no 'ghosting' like 60 % of the time.
Preset : Medium
CRF : 19-22
Custom command lines used :
--me 3 --ref 4 --aq-mode 2 --aq-strength 2 --rdoq-level 1 --psy-rdoq 4 --rc-lookahead 80
--me 3 --ref 4 --ctu 32 --no-sao --aq-mode 3 --aq-strength 2 --rdoq-level 1 --psy-rdoq 4 --rc-lookahead 80
Old 19th July 2016, 15:37   #3994  |  Link
gamebox
@ K.I.N.G. You're welcome
You will not notice compression artifacts in x265 as often and as easily as in x264 partially because x265 encodes video differently. Artifacts in 64x64 and 32x32 image blocks are different than those in x264, slightly "dissolved" and sometimes covering greater areas.
Apart from that, your bitrate can be considered "generous", and not many artifacts should appear. I typically encode at bitrates closer to limits of "acceptable" image quality and "sane" quants - namely 3 Mbps for 1080p - and I could clearly see benefits from SAO. SAO will probably be very useful for broadcasting and streaming as it will "mask" disturbing artifacting during high motion scenes, when limits of data throughput force encoder to temporarily use extreme levels of compression.
Old 19th July 2016, 16:08   #3995  |  Link
littlepox
OK here is a good demo about x265's max-tu-size 16 bug:
https://www.dropbox.com/sh/slftjn7me...EE-V6P3ba?dl=0
source.mkv is the source with 99 frames; denoted as source.
dft_20.hevc is encoded with --preset slow --no-sao --crf 20; denoted as A
dft_19.5_maxtu16.hevc is encoded with --preset slow --no-sao --crf 19.5 --max-tu-size 16; denoted as B
The size difference of them is 0.6%.
In many frames (e.g, frame 17,21,63,83...) You see unpleasant patterns in the flat area of B, like worms on the wall, especially noticable when the grain is lost and the area is clean. In A the situation is much better.
This is A(part of frame 83):
This is B(part of frame 83):
Asking my friend to drop an issue to the https://bitbucket.org/multicoreware/...ew&status=open (done)
Old 19th July 2016, 16:39   #3996  |  Link
littlepox
After clearing the --max-tu-size bug, we tested various possibilities like --ctu 32, --ctu 64 + --rdpenalty 0/1/2
They are indifferent both quality-wise and size-wise, at least with our test settings.
The only difference is --ctu 32 is faster and better paralleled; that's why it is reintroduced.
That's why we suggest to tweak the aq-strength -0.2 for aqmode=3 and +0.2 for aqmode=2. With reduced strength, the bit-rate increase is acceptable and worthy.
Preset : Medium
CRF : 19-22
having aq-strength outside [0.5,1.5] is probably a bad idea, aq-strength=2 for mode=3 is WAY too large.
Also, you need to control your variables. I don't see it reasonable to use different sao settings for the test.
Old 19th July 2016, 17:42   #3997  |  Link
Barough
Barough's Avatar
Still doing tests here. Have lowered the aq-strength to between 1.2 and 1.5. Will do a full movie encode tonight of a dark movie. Will see what my bookshelf have 2 offer.
Also waiting for a m8 that work with video to get back to me. He's not into HEVC so much yet as i understand but his knowledge in the world of video encoding is good.
Old 19th July 2016, 17:46   #3998  |  Link
littlepox
I think 1.2~1.5 is still too high for aqmode 3. For me, I'd use it as 0.9.
Old 19th July 2016, 23:11   #3999  |  Link
divxmaster
@gamebox, I have tested sharpening before processing, and it makes a huge difference. Ironically it is through QTGMC in vapoursynth (I have just noticed that a few select cgi scenes in later seasons of ds9 are interlaced...ick!)
The side effect of the qtgmc deinterlacing is a strong sharpen and also seems to be colour enhancement. This does increase bitrate +25%, so I increased CRF from 21 to 22, but it still looks way better than no qtgmc/sharpen and is slightly lower bitrate (5%) as a bonus.
Specifically ds9 really benefits from degrain also 'vid = haf.SMDegrain(vid, tr=3,thSAD=300,RefineMotion=True,contrasharp=True,pel=2)'
params are --preset slow --rskip --crf 22 --no-sao --aq-mode 2 --rdoq-level 2 --psy-rd 2 --psy-rdoq 1.1 --qg-size 32 --tu-intra-depth 3 --merange 27 --weightb --early-skip --fast-intra --b-intra --tskip --tskip-fast --ref 6 --bframes 6 --max-merge 5 --min-keyint 23 --keyint 288 --deblock -1:-1 --no-open-gop
divxmaster is offline   Reply With Quote
Old 20th July 2016, 02:50   #4000  |  Link
nakTT
Is this the same as the one that can be found in the webpage below?
https://builds.x265.eu
nakTT is offline   Reply With Quote
