Old 23rd August 2007, 16:01   #101  |  Link
MatMaul
thanks a lot !
I'm waiting for the new version.
MatMaul is offline   Reply With Quote
Old 23rd August 2007, 19:34   #102  |  Link
MatMaul
for the audio I propose an other method to don't have to wait for the decode of the whole audio track at the beginning :
1) as long as the read is linear, we just decode the stream in the same time as we provide it to avisynth and we store it in the cache too.
2) if a seek appears forward, we continue the decoding and storing in the cache to the demanded position then we provide to avisynth and continue like in 1
3) if a seek appears backward, I think we have no choice and we need to decode the whole stream in the cache before go in the decoded position.
it could be a good solution as I think more than 50% of this plugin use is linear.
Old 23rd August 2007, 19:43   #103  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Now explain how you intend to report the exact number of audio samples at the time the filter is created.
Myrsloik is offline   Reply With Quote
Old 23rd August 2007, 19:43   #104  |  Link
G_M_C
Originally Posted by Leak View Post
Are you using LoadCPlugin to load it? (Note the extra "C" in there...)
LOL
Guess i noticed the extra C allright
G_M_C is offline   Reply With Quote
Old 23rd August 2007, 19:51   #105  |  Link
MatMaul
yep right I didn't think about that
what about a first fast read without store the data in a cache (in the same time than the video indexing perhaps ?) ? but I don't know if this will be significantly faster than decode and store in the cache.
Old 23rd August 2007, 20:15   #106  |  Link
TheRyuu
warpsharpened
Originally Posted by G_M_C View Post
LOL
I don't think you need LoadCPlugin anymore. I thought that was just for one of the "interm" builds.
TheRyuu is offline   Reply With Quote
Old 23rd August 2007, 20:37   #107  |  Link
Myrsloik
Myrsloik's Avatar
Parsing without decoding can't be done done for all formats due to variable block sizes (mp3 is fixed, vorbis isn't) so at least for some you'll end up having to decode every single audio frame to get a reasonable number. That and you'd still have to create the cache once you actually want to read the audio...
Old 24th August 2007, 10:35   #108  |  Link
Inc
Squeeze it!
Inc's Avatar
@Myrsloik
Did you look at the Videolan API? Maybe its more easy to implement that library as "Libavcodec" source as it also (as you know) bases on ffmpeg but maybe gots better Matroska etc etc etc support?!
Inc is offline   Reply With Quote
Old 24th August 2007, 13:17   #109  |  Link
Myrsloik
Myrsloik's Avatar
Version 1.9 released mostly for testing the flac cache stuff. If no one finds it useful I'll remove it in the next version.
Is there any useful documentation at all about libvlc? All I found was completely useless and didn't say anything at all about its limitations.
Old 24th August 2007, 13:40   #110  |  Link
MatMaul
thanks a lot !!
a little bug : the video cache is created even if vtrack = -2
I will test the flac cache tonight.
Old 27th August 2007, 08:28   #111  |  Link
Inc
Squeeze it!
Inc's Avatar
@Myrsloik
IIRC at videolan.org in its develping section there you can find a documentation.
Regarding ffmpeg .... do you know this one? Maybe one or two included things can be useful for your work: http://www.dranger.com/ffmpeg/
Old 28th August 2007, 09:39   #112  |  Link
ajp
I get an error when I try to use Flac compression... without it works fine.
"CAviStreamSynth: System exception - Access Violation at 0x0, reading from 0x0"
ajp is offline   Reply With Quote
Old 28th August 2007, 10:18   #113  |  Link
buzzqw
HDConvertToX author
be sure to exclude any other filters problem
try an avs with ffmpegsource and your source file, no other filters
are errors present again?
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 28th August 2007, 11:20   #114  |  Link
ajp
Yes, in fact I was only using ffmpegsource...no other filters. I removed all other plugins from plugin folder as well, no luck...
FFmpegSource(source="movie.mkv", vtrack=-1, atrack=-1, timecodes="timecodes.txt", vcache = true, accompression = 1, pp="", ppquality = 6, seekmode = 1)
Old 28th August 2007, 20:47   #115  |  Link
Myrsloik
Myrsloik's Avatar
No hints on what the file contains? does it happen with all files but only for you? You're making this far too simple for me and you should absolutely not upload a piece of whatever it is to ftp://upload:upload@mellbin.org/
If someone else is feeling generous and want flac to work for 8 and 24bit audio feel free to upload a small file because I'm too lazy to create that myself.
Old 28th August 2007, 20:59   #116  |  Link
ajp
The file contains one h264 track and one ac3 track. Normally I use NicAC3source for the audio but I wanted to try the complete ffmpegsource solution now that there's a chance to shrink the audio cache a little. I've tried a few different files with the same type of tracks, same error on all of them. I wanted to wait for someone else to comment on how it works but nobody has so...
I can't upload a sample right now, maybe tomorrow...
Thanks for the support..
Old 28th August 2007, 22:40   #117  |  Link
MatMaul
I don't have this problem, but problems with mono file : flac cache is twice bigger than wav cache and the audio is distorted
EDIT : if you want a sample this problem appears with my last mov sample I provided to you, and I have uploaded an other problematic mono file.
Old 29th August 2007, 00:47   #118  |  Link
Myrsloik
Myrsloik's Avatar
New version (1.10). This one actually works.
Old 29th August 2007, 07:24   #119  |  Link
ajp
Wohoo! Tried it, it works!
Any chance of DTS support as well?
Old 29th August 2007, 10:02   #120  |  Link
Myrsloik
Myrsloik's Avatar
DTS support where? I think libavcodec is already supposed to have its own decoder for it. Never tried it myself though.
