Old 22nd May 2020, 10:32   #18541  |  Link
slalom
slalom's Avatar
You can add a file twice
i7 3930K @ 4.2GHz on GA-X79-UD3 16GB DDR3
Xeon E5-2670 v2 @ 2.9GHz 16GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 25th May 2020, 12:27   #18542  |  Link
ReinerSchweinlin
Hy there,
Ripbot really has become a workhorse in my workflows and I canīt thank you enough for this wonderfull tool
I whipped up some old servers and cranked them up with a lot of CPUs to assist the encoding farm. So far so good. These servers now have a really nice "Sleep mode" with the ability for "wake on LAN". It takes around 15 sec. Until they are online.
Is there a way to tell Ripbot to initially "ping" a server to wake him up and then start the encoding? At the moment, Ripbot thinks itīs sleeping - the inital call does wake the server up, though, but not quick enough for ripbot top recognice it.
if I hit the button in the Encoding Client manually after a while, it picks the server up... Maybe simply ping all servers once before the initial "copy video stream to temp" process?
Thanx
Old 25th May 2020, 14:52   #18543  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Have you tried auto reconnect option?
or
Old 26th May 2020, 09:31   #18544  |  Link
Pino72
have been using RB for some time now. Apart from update problems when one PC was on a different version than the other PC for DE it worked really well.
I am mainly reencoding 4K UHD files to lower bit rates keeping all the pixel sizes etc. Only video processing no audio and subtitles etc.
Now since a while I have some really weird behaviours on certain UHd files when I am using DE, my main PC is doing fine all the time (8 Core 9900K), my second PC (4 Core 6700K) is doing strange stuff on certain but not all chunks.
The end result is a file that is playable but has some picture freezes in terms of decoding seems to have stopped for the whole chunk with a more or less black screen.
When I am letting my main PC process the chunk it does it correctly, my second PC does not. To compare it I let them decode the same chunk and am posting the .txt file here and hope to find a solution as to why this is happening and how I can avoid this. Both RB PC's are on the same version of Win 10 and same RB version with the latest updates.
Encoding started...
""\\AQUAPC-9900\Ripbot264temp\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "\\AQUAPC-9900\RipBot264temp\job5\Chunks\1.avs" -strict -1 -f yuv4mpegpipe - | "\\AQUAPC-9900\Ripbot264temp\tools\x265\x265_x64.exe" --seek 0 --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display "G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,16450)L(10000000,1)" --pass 1 --bitrate 25000 --stats "\\AQUAPC-9900\RipBot264temp\job5\Chunks\1.stats" --fps 24000/1001  --min-keyint 24 --keyint 240 --frames 1424 --sar 1:1 --profile main10 --output-depth 10  --ctu 64 --merange 57 --no-slow-firstpass --y4m --pools "+" --output NUL -"
y4m  [info]: 3840x1600 fps 24000/1001 i420p10 sar 1:1 unknown frame count
raw  [info]: output file: NUL
x265 [info]: HEVC encoder version 3.2+34-8e6db24c1517
x265 [info]: build info [Windows][GCC 9.2.0][64 bit] 10bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x265 [warning]: Turning on repeat-headers for HDR compatibility
x265 [info]: Main 10 profile, Level-5 (Main tier)
x265 [info]: Thread pool created using 16 threads
x265 [info]: Slices                              : 1
x265 [info]: frame threads / pool features       : 4 / wpp(25 rows)
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge         : dia / 57 / 2 / 1
x265 [info]: Keyframe min / max / scenecut / bias  : 24 / 240 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt        : 20 / 4 / 2
x265 [info]: b-pyramid / weightp / weightb       : 1 / 1 / 0
x265 [info]: References / ref-limit  cu / depth  : 1 / off / on
x265 [info]: AQ: mode / str / qg-size / cu-tree  : 2 / 1.0 / 32 / 1
x265 [info]: Rate Control / qCompress            : ABR-25000 kbps / 0.60
x265 [info]: tools: rd=2 psy-rd=2.00 early-skip rskip signhide tmvp b-intra
x265 [info]: tools: fast-intra strong-intra-smoothing lslices=8 deblock sao
x265 [info]: tools: stats-write
x265 [info]: frame I:      8, Avg QP:9.25  kb/s: 45911.50
x265 [info]: frame P:    351, Avg QP:3.09  kb/s: 47679.73
x265 [info]: frame B:   1065, Avg QP:8.66  kb/s: 12120.18
x265 [info]: Weighted P-Frames: Y:19.4% UV:12.0%
x265 [info]: consecutive B-frames: 13.6% 4.7% 11.4% 11.7% 58.5%
encoded 1424 frames, 7.58 fps, 21075.05 kbps
Encoding started...
x265 [info]: Thread pool created using 8 threads
x265 [info]: frame threads / pool features       : 3 / wpp(25 rows)
x265 [info]: frame I:      6, Avg QP:13.97  kb/s: 654.90
x265 [info]: frame P:    465, Avg QP:4.52  kb/s: 36.56
x265 [info]: frame B:    953, Avg QP:10.59  kb/s: 28.62
x265 [info]: Weighted P-Frames: Y:0.0% UV:0.0%
x265 [info]: consecutive B-frames: 30.8% 6.6% 27.0% 0.8% 34.8%
encoded 1424 frames, 20.61 fps, 33.85 kbps
As you can see on the second PC the kbps is very low, luckily I can see this on DE while it is doing the job and can prevent it.
Any idea why he does not weight the P-Frames here?
THanks for this great tool and hope to get it wokring for DE soon, help is very welcome.
Cheers
Pino72 is offline   Reply With Quote
Old 26th May 2020, 14:24   #18545  |  Link
Atak_Snajpera
On 6700k open "\\AQUAPC-9900\RipBot264temp\job5\Chunks\1.avs" in mpc-hc. What do you get ? Are you sure that both pcs have the same avisynth versions? Does regular mode (non-de) work on 6700k?
Old 27th May 2020, 15:51   #18546  |  Link
Pino72
Hi Atak,
thank you for your reply. Indeed playing back the .avs file on the 6700k PC is not working, just gives me a green screen. Playing back the same .avs file on the 9900k is working fine it shows the video. On the other side encoding the file is working locally on the 6700K just fine.
Any suggestions? Something wrong with temp folders etc?
I checked all Tools in the setting menu of RB and everything was on the same version number. Not sure if Avisynth is also listed there or if I should check somewhere else? On other files DE still works fine though but not on all, really strange. So its not related to this one specific movie.
Old 27th May 2020, 15:56   #18547  |  Link
Pino72
I copied over the whole Avisynth and Avisynth Plugin folder from the ripbot tools folder from the 9900k to the 6700k PC...no difference.
Old 27th May 2020, 18:33   #18548  |  Link
Atak_Snajpera
Do you have this issue only in 4k/UHD resolution? Do you use GPU decoding or CPU decoding on AQUAPC-9900?
Old Yesterday, 08:41   #18549  |  Link
Pino72
Yes only in 4K resolutions (so far at least, but not all 4K files), indeed I have everything on GPU decoding on the 9900K except for OTHER and everything on CPU on the 6700K. Using a GTX 1050 on the 9900K and a RTX 2060 on the 6700K.
I now switched everything on all PC's to CPU decoding and it seems to work now.
Old Yesterday, 11:56   #18550  |  Link
ReinerSchweinlin
Thanx - that might do the trick, didn`t think of it. Will try when back at the rig. Thank you !
