#41 | Link |
Derek Prestegard IRL
![]() Join Date: Nov 2003
Add to the fact that you're doing 1-pass VBR using x264vfw.... which isn't optimal _at all_.
Try a CRF18 encode using the CLI encoder the proper way. MeGUI or any number of GUIs can make this a simpler process ![]() ~MiSfit
These are all my personal statements, not those of my employer :) |
#42 | Link | |||
![]() Quote:
Basically, upscaling as such doesn't lose any detail. The end result, however, depends on lots of factors that are all correlated to each other: resolution to be encoded, source noise, sharpness/softness, codec settings, available bitrate, etc. It seems that you don't have full grasp of this meshwork yet. Keep on, experience grows by the day. Quote:
#44 | Link |
Encoding Dinosaur!
I'm stunned to see people giving this guy help on upscaling a 4:3 DVD source to 16:9 720p!
Typhoon, what you're doing is the biggest mistake of all times! You want the perfect rip? Encode at 704x480 (by cropping the black side bars), apply a gentle temporal smoother* (eventually a light spatial smoother too) and encode at the highest bitrate you can afford. Just make sure you specify 4:3 as aspect ratio when muxing to mkv. Will look 1000 times better than what you're showing here and detail loss will be minimal. Make sure to enable Bicubic Resizing within MPC HC to ensure a sharp look while playback in full screen. *something like this: TemporalSoften(2,4,8,15,2) Last edited by DJ Bobo; 16th February 2009 at 14:35. |
#47 | Link |
Well, YouTube does, any PC does - and there are plenty of 4x3 BluRay titles available - they are pillarboxed to 16x9.
EDIT: Here's a useful script: http://forum.doom9.org/showthread.php?t=138285 Cheers, David. Last edited by 2Bdecided; 16th February 2009 at 16:33. |
#48 | Link | ||
"It blows up the file size", they say. Well, it looks better. Last edited by Comatose; 16th February 2009 at 16:35. |
#49 | Link |
Encoding Dinosaur!
Pillarboxing huh? Well, I don't recommend it anyway, encoding upscaled videos is superfluous imho. If Bicubic is not good enough for you/him, one could always enable custom resizers and/or filters in ffdshow, no need to "hardcode" the upscaling.
#51 | Link |
Come on DJ Bobo - even your own avatar benefits from better upsampling than bicubic!
See attached pic (when cleared by mods) - your avatar resized by x2. left = nnedi2 right = bicubic Of course, when you're backing up your own DVDs, it doesn't matter how you upscale because you can always go back to your master SD copy if you later find that you can do better. ![]() Cheers, David. |
#53 | Link | |
Banned
*If you want, I can upload the VOB which is only 47.5MB and you can try some things out for yourself and compare with that same frame. Or a different one, doesn't matter. Last edited by Typhoon859; 16th February 2009 at 23:35. |
#54 | Link | |
Banned
ConvertToYV12() Toon(0.25) dfttest(sigma=1.6, tbsize=3) AAA(chroma=true) NNEDI(1,dh=true).TurnLeft().NNEDI(1,dh=true).TurnRight() aWarpSharp(24,4,0.3,1) LimitedSharpenFaster(edgemode=1,strength=200,ss_x=1,ss_y=1) spline36Resize(1280,720) I'm having trouble dfttest to work because I don't know how to install FFTW. I feel slow... |
#55 | Link |
Encoding Dinosaur!
*looooooooool*
Typhoon, you wanna teach me something about DBZ???? Want me to be specific? The screenshot you posted is from the 9th movie "Bojack", 32nd minute. Do I hear jingle bells? Go check your DGIndex infos again, you'll see that the aspect ratio is 4:3. |
#60 | Link |
Banned
I don't have a Blu-Ray player drive on my computer, one, and two, they put the same exact footage on DVD as they did on Blu-Ray. The difference is, they upscaled for me. Plus, that's besides the point. The picture is just an example.
