Old 6th March 2007, 07:07   #81  |  Link
Originally Posted by Revgen View Post
One option I would like to see is to be able to turn off deblocking. Sometimes I'd rather deal with blocking issues myself using avisynth.
Good idea. I have implemented and tested it. You'll do it like this:
AVCSource("file.dga",deblock=false)
I'm sure you're aware that in H.264 the deblocked picture becomes the reference picture, so you may see inaccuracies that get progressively worse within a GOP.
It will be in the next alpha. The next alpha will also add an option to DGAVCIndex to generate a decoded video using the JVT reference software.
EDIT: It's 25% faster without deblocking. For one 25fps HD clip I have that made the difference in allowing me to play it at full frame rate.
Guest is offline
Old 6th March 2007, 08:05   #82  |  Link
Revgen
Thanks a lot.
I'm aware of some of the drawbacks, but in certain cases it just works better without it.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline
Old 6th March 2007, 08:58   #83  |  Link
ToS_Maverick
x264 Tester
first of all, thanks neuron2 for the great work!
my workflow looks like this:
Pro7 HD Transport Stream => mux to Matroska => cut with mkvtoolnix => demux with mkvextractgui => index => avisynth
i want to report the following issues:
- in your GUI, you can add files via drag&drop. after add file via D&D => index, if i drag another file into it, the indexfile will be created, but if i want to load it, an avisyntherror occurs: no video
- if i load a file, which was splitted with mkvmerge and demuxed, DGAVCSource looses the first ~60 frames, compared to DirectShowSource("file.mkv").
ToS_Maverick is offline
Old 6th March 2007, 13:05   #84  |  Link
lucassp
LoadPlugin("DGAVCDecode.DLL")
AVCSource("D:\HD\sky.dga")
Everytime I try to play the AVS file I get this message:
Evaluate: System exception - Access Violation
the streams are the ones from x264.nl
lucassp is offline
Old 6th March 2007, 13:07   #85  |  Link
Manao
neuron2 : can't you try to copy the decoded picture in the output buffer before deblocking it ? That way, there are no decoding accuracies.
Manao is offline
Old 6th March 2007, 15:05   #86  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
You can't expect anything to get fixed if you don't upload a test file. For what it's worth, I can't reproduce, it comes out on the correct frame here.
foxyshadis is offline
Old 6th March 2007, 15:25   #87  |  Link
ToS_Maverick
x264 Tester
ok sry, i noticed the problem yesterday and just wanted to report it. when i get home, i'll upload a sample for you, no problem
Old 6th March 2007, 15:56   #88  |  Link
Seba-
Hey,
Maybe it is possible to make avc/h264 support for satelite hdtv avc streams? Sample from FTA channel below:
Sample File
Seba- is offline
Old 6th March 2007, 16:25   #89  |  Link
lucassp
Originally Posted by Seba- View Post
Hey,
Sample File
first, you've got to demux the Transport Stream: MPlayer FILE.TS -dumpvideo -dumpfile FILE.264. and then do the job with DGAVCIndex
lucassp is offline
Old 6th March 2007, 16:51   #90  |  Link
Seba-
I tried but obviously it's not working with hdtv streams...
Seba- is offline
Old 6th March 2007, 17:24   #91  |  Link
You have to give me the .264 elementary stream if you want support!
Guest is offline
Old 6th March 2007, 17:27   #92  |  Link
If you want a failing stream to be supported, you have to give me the stream for testing. Otherwise, there is nothing I can do. I do not have a magic wand.
My guess is that it is PAFF, which is not supported. But I'd like to see the stream to verify that and to test out a more graceful exit.
Guest is offline
Old 6th March 2007, 17:30   #93  |  Link
Originally Posted by Manao View Post
neuron2 : can't you try to copy the decoded picture in the output buffer before deblocking it ? That way, there are no decoding inaccuracies.
Yes, that would be possible. You'd lose the speed advantage of course. But I'd have to modify libavcodec. We'll see. Let's find out how significant the effect is.
Guest is offline
Old 6th March 2007, 17:34   #94  |  Link
Yeah, because the DGA file is empty. I'll fix it.
Need the ES, please.
Guest is offline
Old 6th March 2007, 19:15   #95  |  Link
ToS_Maverick
x264 Tester
i think i know the source of the problem! wanted to split 20mb from the problematic file with mkvmerge, which couldn't do it... got a whole bunch of errors! i'll talk to mosu to find a solution and start a further investigation. i'll keep you posted
Old 6th March 2007, 19:20   #96  |  Link
Revgen
Okay I just tried this on another video and getting some strange issues when trying to fast seek to certain points. I don't know if this has anything to do with the IDR/SEI issues you mentioned.
1) The video is 640x480 @ 60fps and 400334 frames long.
2) I CAN fast seek anywhere in the video from frame 0 to about frame 189257. If I try to fast seek anywhere past frame 189257, VirtualDub will return me to the beginning of the video. When this happens I can even press "play" and it'll start playing at the begining of the video.
3) Furthermore, if I try to fast seek past about the frame 377623, VirtualDub doesn't even go back to the beginning of the video. Instead it shows a blank green screen. If I press "play" at this point, VirtualDub will play the green screen and sometimes the real video will shift in and out during playback.
4) Fortunately, none of these problems occur if I just press "play" before the 189257 frame. I can play all the way through the video and just press "stop" and it'll stop at the right spot. Unfortunately, this is a lot slower than just fast-seeking.
5) This also causes a problem with the trim command.
If I use trim(0,185000)+trim(370000,0) and I set my mark to lets say 184000 and press "play" in VirtualDub, by the time VDub plays past the 185000 frame it starts playing at the beginning of the video. I haven't tried any encodes doing this yet (I plan to later), but I wouldn't be surprised if it screws up the vid.
6) I have not encountered any of these issues using DirectShowSource on my original .mkv. I'm going to remux the .264 file I demuxed back into another .mkv and play it back to see if MKVExtract made a mistake probably later today.
EDIT: I just remuxed the .264 file I originally extracted and it seeked fine with directshowsource, so obviously MKVExtract can't be the culprit.
7) The entire .264 file is 4.21 GB. If you're interested, I might be better off sending you a DVD-R in the mail.
Moe: Why?
Revgen is offline
Old 6th March 2007, 20:01   #97  |  Link
@RevGen
First, please post a link to the entiire DGA file.
Guest is offline
Old 6th March 2007, 20:34   #98  |  Link
lucassp
http://x264.nl/h.264.samples/force.p...movies.9.hd.ts
MPlayer plays it using libavcodec
lucassp is offline
Old 6th March 2007, 20:39   #99  |  Link
Inventive Software
Turkey Machine
Neuron'll lynch you for not demuxing it...
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 6th March 2007, 20:45   #100  |  Link
Revgen
@RevGen
Here you go.
http://www.mediafire.com/?amermndmhuz
Moe: Why?
Revgen is offline
