Old 24th January 2018, 20:53   #21  |  Link
Taurus
Taurus's Avatar
Originally Posted by Bexley View Post
Ah yes, of course. Stupid mistake. But surely SYSWOW64 since it's a 32-bit file, right?
Aah,
everybody is running in this trap sometimes
Taurus is offline   Reply With Quote
Old 24th January 2018, 21:17   #22  |  Link
Bexley
I spoke too soon. It hung on the 3rd run with 8 threads.
Bexley is offline   Reply With Quote
Old 24th January 2018, 21:55   #23  |  Link
Groucho2004
I assume no error message? Try to isolate the plugin that causes the problem by removing the filters one by one. Try without multi-threading.
Groucho's Avisynth Stuff
Old 26th January 2018, 02:19   #24  |  Link
Bexley
I've made about a dozen test runs of different scripts with AVSmeter, and although it doesn't really mean anything definitively, I have had 2 hangs when I include RemoveDirtMC(). No hangs with just TemporalDegrain(). So......
I know that RemoveDirt has a checkered past, so it doesn't surprise me that it might be the problem. So at this point I think I probably have 3 options. 1) go back to 2.6MT, 2) find a different version of removedirt.dll that plays nice, or 3) find a comparable function to RDMC() that gives a similar result. I'm open to suggestions.
And actually, everything I use except RDMC() seems to work great in 64-bit, so if I could find a similar function with 64-bit plugins it might allow me to just go 64-bit and be done.
Old 26th January 2018, 11:09   #25  |  Link
Groucho2004
Post a short sample clip that shows the grain/dirt you want to remove. Someone may suggest an alternative to RemoveDirt.
I'm not sure if you have seen this already, here is a list of plugins/scripts with a similar purpose.
Old 26th January 2018, 21:52   #26  |  Link
Bexley
Sample here showing before and after using the script above.
Old 26th January 2018, 22:24   #27  |  Link
Groucho2004
Can you also post the unprocessed/uncompressed source sample?
Old 27th January 2018, 06:18   #28  |  Link
Bexley
Yes, if I can find a free VOB splitter that isn't full of adware. That's not a standard tool in my toolbox.
Old 27th January 2018, 11:52   #29  |  Link
Groucho2004
I use DGIndex for that. The manual explains how to select a part of the timeline. Then you can export it as an elementary stream (File -> Save project and demux video).
Old 27th January 2018, 19:42   #30  |  Link
Bexley
Thanks, did not realize it did that. Untouched DVD sample here.
Old 27th January 2018, 20:05   #31  |  Link
Groucho2004
DeSpot() might be worth a try.
avisynth+, compatibility
