Old 14th October 2010, 17:49   #1  |  Link
Klagar
Klagar's Avatar
Concatenating 2 passes in FFmpeg : OS dependency
Hi !
Just a quick question because at the moment I don't have the material to test it out myself...
I learned that it is possible, in FFmpeg, to run many encodings in a single command line. Example taken from this site :
ffmpeg -i fluid8.mov -y out1.mp4 && ffmpeg -i fluid8.mov -y out2.avi && ffmpeg -i fluid8.mov -y out3.flv && ffmpeg -i fluid8.mov -y out4.mov
So the "&&" separator does that. Now my question is : will it work the same on any OS, or is it a Windows-only syntax ?
Regards.
Klagar is offline   Reply With Quote
Old 14th October 2010, 18:12   #2  |  Link
nm
"&&" is the same on Unix/Linux. The following command is only run when the previous command ends successfully (returns a zero exit code). If you want all the commands to run one after another regardless of their exit status, use "&" with cmd.exe and ";" on Unix/Linux (where "&" would make the previous command run in background).
Old 14th October 2010, 18:50   #3  |  Link
Klagar
Klagar's Avatar
Great ! Thanks a lot !
Old 14th October 2010, 20:57   #4  |  Link
Reimar
I feel pedantic: it only depends on the shell, not the OS. So if you want to make sure you have the same behaviour, use e.g. bash (e.g. from MinGW or Cygwin) on Windows. Even the Powershell seems to use ";" to separate commands, however the & seems to be misused for something else (though possibly only at a start of a command).
Reimar is offline   Reply With Quote
ffmpeg, linux, windows
