Old 13th May 2009, 18:57   #1  |  Link
Sivar
MeGUI: Producing corrupt files. Suspect MKVMerge.
I am trying to back up movies (from DVDs which work fine) and have run into a problem with several of them.
The resulting file ends up being small (a little larger than the encoded MP3) and corrupt.
This started just in the last 5 weeks or so, but may be related to the movies encoding rather than the version of a tool that comes with MeGUI.
The log (complete file attached) repeatedly says:
[Warning] A warning occurred: Warning:
'D:\path\to\movies\movieName_Video_0.264' track 0: This MPEG audio track contains 2 bytes of non-MP3 data which were skipped. The audio/video synchronization may have been lost.
(italic parts change)
I use the 1-click encoder and choose a VOB file and encode it with fairly slow 2-pass settings. The problem occurs whether I am transcoding the audio to MP3 or simply adding the original AC3 or DTS track, so I don't think it has anything to do with MP3.
It seems to be similar to the problem this guy is having:
http://forum.doom9.org/showthread.php?t=145881
He suspects that MKVMerge thinks the video file is actually an MP3. Why it would think that, I am unsure.
With at least one of the movies, I got a good encoding in CRF mode, so I think the DVD rips are fine.
How can I fix this or otherwise get working MKV files? TIA.
Sivar is offline   Reply With Quote
Old 13th May 2009, 19:51   #2  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
replace the files in megui/tools/mkvmerge folder with the ones that come with this: http://www.bunkus.org/videotools/mkv...0090513-128.7z
and report back.
Old 13th May 2009, 20:46   #3  |  Link
juGGaKNot
juGGaKNot's Avatar
Originally Posted by Sivar View Post
This MPEG audio track contains 2 bytes of non-MP3 data which were skipped. The audio/video synchronization may have been lost.[/INDENT](italic parts change)
When i use ripbot with mp3 it always skippes 1024 bytes.
juGGaKNot is offline   Reply With Quote
Old 15th May 2009, 20:45   #4  |  Link
Sivar
No go.
Sadly, this appears to have not entirely worked.
I was able to encode one movie which previously did not work, but when encoding K19, the log filled with the same error messages.
Attached is the log.
On another note, I've noticed that MeGUI's auto-update feature has an update for MKVMerge. Perhaps I will try it.
Sharktooth: If there anything else I might try?
Old 24th May 2009, 14:40   #5  |  Link
Sivar
I recently tried the updated MKVMerge which the auto-update installs (2.8.0-129) and it, too (assuming it's MKVMerge at all) has the "non-MP3 data" warnings and creates corrupt video files.
Old 22nd March 2013, 13:02   #6  |  Link
raynold
same here by encoding a HD dvb capture
video file
Allgemein
ID/String                        : 1 (0x1)
CompleteName                     : D:\temp\mux\Der Heilige Krieg (1_5) - ZDF HD - 2011-08-16.ts_new.ts
Format                           : MPEG-TS
FileSize/String                  : 4,16 GiB
Duration/String                  : 43min
OverallBitRate_Mode/String       : variabel
OverallBitRate/String            : 13,6 Mbps
OverallBitRate_Maximum/String    : 35,5 Mbps
Video
ID/String                        : 4113 (0x1011)
MenuID/String                    : 1 (0x1)
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format_Profile                   : Main@L4.0
Format_Settings_CABAC/String     : Ja
Format_Settings_RefFrames/String : 5 frames
CodecID                          : 27
BitRate/String                   : 11,9 Mbps
BitRate_Maximum/String           : 12,0 Mbps
Width/String                     : 1 280 Pixel
Height/String                    : 720 Pixel
DisplayAspectRatio/String        : 16:9
FrameRate/String                 : 50,000 FPS
ColorSpace                       : YUV
ChromaSubsampling                : 4:2:0
BitDepth/String                  : 8 bits
ScanType/String                  : progressiv
Bits-(Pixel*Frame)               : 0.258
StreamSize/String                : 3,62 GiB (87%)
colour_primaries                 : BT.709
transfer_characteristics         : BT.709
matrix_coefficients              : BT.709
Audio #1
ID/String                        : 4352 (0x1100)
Format                           : MPEG Audio
Format_Version                   : Version 1
Format_Profile                   : Layer 2
CodecID                          : 4
BitRate_Mode/String              : konstant
BitRate/String                   : 256 Kbps
Channel(s)/String                : 2 Kanäle
SamplingRate/String              : 48,0 KHz
Video_Delay/String               : -261ms
StreamSize/String                : 80,0 MiB (2%)
Language/String                  : Deutsch
Audio #2
ID/String                        : 4353 (0x1101)
Format                           : MPEG Audio
CodecID                          : 4
BitRate/String                   : 192 Kbps
Video_Delay/String               : -271ms
StreamSize/String                : 60,0 MiB (1%)
Audio #3
ID/String                        : 4354 (0x1102)
Format                           : AC-3
Format/Info                      : Audio Coding 3
Format_Settings_ModeExtension    : CM (complete main)
Format_Settings_Endianness       : Big
CodecID                          : 129
BitRate/String                   : 448 Kbps
ChannelPositions                 : Front: L R
BitDepth/String                  : 16 bits
Video_Delay/String               : -262ms
StreamSize/String                : 140 MiB (3%)
Audio #4
ID/String                        : 4355 (0x1103)
Format                           : MPEG Audio
CodecID                          : 4
Video_Delay/String               : -280ms
Language/String                  : qaa
megui log attached
raynold is offline   Reply With Quote
Old 22nd March 2013, 13:12   #7  |  Link
raynold
Now that i demuxed with tsmuxer before i got the following error
corrupt, megui, mkvmerge, non-mp3
