14th March 2011, 08:09 | #16601 | Link |
Can you re-check your Video Render or Internal Splitters, to fix the Full speed playing bug???
you can test this bug in realmedia (RealMediaSplitter.ax 2010-XX+ compile ver) or mpg file. ie.repetitive drag and drop the media file to mpc-hc Last edited by hayan; 14th March 2011 at 10:41. |
14th March 2011, 11:00 | #16603 | Link |
This is not the mpg file problem
I download new mpg file(another), and re-reproduce it. Can you re-check your Video Render or Internal Splitters...? EVRCP MPC-HC x86 ~1.5.2.2962 (xvidvideo or XhmikosR ver) Geforce 8600GT ~260.99, GT430 ~266.58 Win7 x64 sp1 Last edited by hayan; 14th March 2011 at 11:27. |
14th March 2011, 15:10 | #16604 | Link |
Feature suggestion:
Currently it is possible to rotate the video an arbitrary number of degrees with Alt+4/6/2/8/1/3 (on numeric keyboard). I suggest adding Alt+7 for a 180 degree horizontal flip and Alt+9 for a 180 degree vertical flip. I would also be useful to add those commands to the Pan&Scan menu. Now most people don't know that the rotate feature exists.
MPC-HC 2.2.1 |
14th March 2011, 17:31 | #16605 | Link |
@hayan
Pretty sure this is an old issue with the EVR Custom scan line/refresh rate detection. There is an open ticket #805 on the issue. I opened that 6 months ago, but the issue has been around much longer, since Beliyaal's changes. If you disable Vsync (press the v key) in EVR Custom you will probably not see it anymore. Also switching renderers to EVR Sync will help. If you have any relevant info not already in the ticket, feel free to add it. I don't think splitters have anything to do with it though. I've seen the issue with all kinds of splitters/containers. @devs I'd appreciate it if you could take a look at that ticket. Maybe one of you will see right away what goes wrong with the info I added today about the 32-bit minimum signed long scanlines number near the bottom. |
14th March 2011, 19:04 | #16607 | Link |
Thanks, but I already know the situation. I use that term about anyone who knows how to code in C++ (or other languages for that matter). I've been following this thread and the project since it started.
My point was, I know several bright/skilled devs follow this thread, so I was asking if they maybe could take a look in case it's a "simple" cast issue. I don't have the knowledge to tell. JanWillem is certainly one of those devs I was addressing, especially since he's working on EVR Custom. Last edited by Ger; 14th March 2011 at 19:24. |
14th March 2011, 20:35 | #16609 | Link |
Sorry, I don't understand what you're asking? If you're asking how to reproduce the issue I can't help. It only seems to happen occasionally on a few systems. I can't even reliably reproduce it myself. Maybe hayan or one of the other people who reported this in different threads here over the years can help.
14th March 2011, 20:41 | #16610 | Link | |
Sturreting seems to be fixed if i use FFDshow audio decoder with disabled jitter correction.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
14th March 2011, 20:43 | #16611 | Link |
.NET Web App Dev
Fixed issue by resetting CoreAVC and manually purging registry from Haali / Matroska.
Two feature suggestions come to mind now, - Warning Dialog: Current configuration failed, try resetting all settings. - Warning Dialog: Subtitles cannot be displayed. Please update DirectX. Both of these errors are silent right now for some reason.
Intel i7 5820k / 16 GB DDR4 / NV 970 / 4K ASUS Windows 8.1 |
14th March 2011, 22:28 | #16612 | Link |
primus inter pares
feature request
make the buffer adjustable!
sometimes i have ongoing IO on the hdd but many GBs of free RAM... so i wanna buffer the file (or parts of it) (like mplayer -cache N) KornX
Field Application Engineer Advanced Micro Devices Last edited by KornX; 14th March 2011 at 22:33. |
15th March 2011, 02:18 | #16613 | Link | |
(Haali's renderer requires YUY2 or RGB32 output, it will not connect if YV12 or NV12 is the only thing selected) If DirectX is too old, there is an error message. Last edited by namaiki; 15th March 2011 at 02:25. |
15th March 2011, 02:46 | #16614 | Link | |
.NET Web App Dev
There were no error messages. - There were no error messages indicating why VMR/EVR options were grayed out. - There were no error messages indicating that Haali was refusing to work. If I didn't notice missing subtitles, I would simply be unaware of these issues.
15th March 2011, 02:52 | #16615 | Link | |
Also, Vsync adjustment is fundamentally broken in your test build. |
15th March 2011, 13:35 | #16616 | Link |
I used to run rmvb files with MPC, but this time I don't know what I have do wrong. audio streams won't play whatever I do, I tried to add MPC - RealAudio manually and set it as prefer but no luck ... here's what I have
note: other players run rmvb with no problem Code:
K:\xxxxxx.rmvb::Output 00 (Audio Stream) Media Type 0: -------------------------- Audio: RealAudio COOK 44100Hz stereo AM_MEDIA_TYPE: majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71} subtype: Unknown GUID Name {4B4F4F43-0000-0010-8000-00AA00389B71} formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 1 lSampleSize: 14880 cbFormat: 112 WAVEFORMATEX: wFormatTag: 0x2004 nChannels: 2 nSamplesPerSec: 44100 nAvgBytesPerSec: 0 nBlockAlign: 930 wBitsPerSample: 16 cbSize: 0 (extra bytes) pbFormat: 0000: 04 20 02 00 44 ac 00 00 00 00 00 00 a2 03 10 00 . ..D¬......¢... 0010: 00 00|2e 72 61 fd 00 05 00 00 2e 72 61 35 00 00 ...raý.....ra5.. 0020: 00 10 00 05 00 00 00 4e 00 18 00 00 03 a2 00 00 .......N.....¢.. 0030: 00 00 00 07 55 67 00 00 00 00 00 10 03 a2 00 ba ....Ug.......¢.º 0040: 00 00 00 00 ac 44 00 00 ac 44 00 00 00 10 00 02 ....¬D..¬D...... 0050: 67 65 6e 72 63 6f 6f 6b 01 07 00 00 00 00 00 10 genrcook........ 0060: 01 00 00 03 08 00 00 25 00 00 00 00 00 06 00 05 .......%........ |
15th March 2011, 13:37 | #16617 | Link |
No Real Alternative installed?
15th March 2011, 14:53 | #16619 | Link |
15th March 2011, 15:58 | #16620 | Link |
Hello there!
GPU:ati HD4850,catalyst 11.4 preview(same result with 11.2) WIN 7 64bit mpc 32bit evr. custom pres. With every build I've tried(xhmikosrR's,xvidvideo.ru,JanWillem32's) in over a month I get no chroma upsampling(or bad?) and the osd color is grey.Can you explain to me where is the problem? With 1.5.1.2903 none of the above happens but I can reproduce the bad chroma thing by forcing 10 bit rgb input(I don't use that option generally). Is the YV12 chroma upsampling shader the way to go for now? |
