27th January 2010, 05:38 | #6781 | Link | |
27th January 2010, 06:57 | #6782 | Link |
@awake33:
Personnaly i can suggest you to try theses things. Uninstall all programs (avisynth, ffdshow, matroska). Reboot after this. Make a spot check if you don't have another directshow all-in-one application are installed in your system (like k-lite codecs pack, or any codec packages). After download and/or install this: - Latest DirectX Files ( http://www.microsoft.com/downloads/e...D-85FC422D1388 ) - Install ffdshow CLSID rev. (try mine are working right now rev.3176) ( http://sourceforge.net/projects/ffds...d.exe/download ) - Install matroska haali (available on the 1rst page of this thread) submited by Atak. - Install avisynth 2.5.8 stable rev. ( http://sourceforge.net/projects/avis...8.exe/download ) Try with this and let us know if it is working. I have experienced a trouble like you but with another program (HDConvertToX) wich i was using a ffdshow rev of CLSID, but i have re-installed ffdshow but rev of XXL. I never has or read something that said i was need to use ffdshow XXL with HDConvertToX. I was solved that trouble but for ripbot264, atak have recommand CLSID rev. (Not XXL or ICL-10). Good Luck for your case!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 27th January 2010 at 07:00. |
27th January 2010, 09:31 | #6783 | Link |
Ripbot264 stops immediately after starting
I'm re-encoding a DVD to PS3 format, and the program stops within a few seconds at "muxing." I already encoded the DVD once with Ripbot264, but the AR was wrong.
I first thought it was using the old temp files and failed because of that, but it stops even after deleting the temp folder for the job. Any ideas? edit: encoding any other file works fine Last edited by joae; 27th January 2010 at 10:20. |
27th January 2010, 13:35 | #6784 | Link | |
27th January 2010, 16:56 | #6785 | Link | ||
Not sure which file you mean, but here's two, hope they help
job7_EncodeVideoPass1: Quote:
27th January 2010, 23:01 | #6787 | Link |
To save time, while RipBot is encoding, I'm getting other jobs ready by ripping and demuxing them so when I add them ripbot doesn't have to demux.
I used eac3to to demux an m2ts file into a .h264 and .flac file (from PCM) and selected the .264 file. After a while ripbot came back with: AVCSource: Could not open one of the input files. (d:\Temp\RipBot264temp\job1\getinfo.avs, line 2) |
27th January 2010, 23:14 | #6788 | Link |
I can only suggest to use mkv instead of raw .h264 file
27th January 2010, 23:47 | #6789 | Link |
So it is not possible to submit a separate video and audio file for encoding and muxing by Ripbot264? There's a browse button on the audio filename in the second screen so I thought I would be able to submit a video file, then browse to my audio file? No possible?
27th January 2010, 23:50 | #6790 | Link |
as you can see no. DGAVCDec didn't like your file. Period.
28th January 2010, 10:58 | #6791 | Link |
Slower than HDC
i have a Intel Core-2-Duo-Prozessor T7200 and when i encode an Bluray with RipBot the ETA is about 60hrs with 0,94 fps !! I use the "[High 4.0] Bluray, Console" Profile with no modifications from v.1.15 Encoding the same Bluray with HDConvertToX shows me an ETA of 15hr using the x264 normal preset with crf of 22. I am using Vists Home Premium x86. Why is x264 encoding in RipBot so slow? Ciao Tulip001 |
28th January 2010, 13:45 | #6792 | Link | |
29th January 2010, 12:27 | #6793 | Link |
Recently switched to Windows 7. I've just installed the latest RipBot and I'm getting an error after the the source file has been demuxed. After demuxing, it says 'Please wait, gathering information' for about 5 minutes, then an error comes up saying 'DirectShowSource : Timeout waiting for graph to start. (D:\temp\RipBot264temp\job1\getinfo.avs, line 2)'. I've uninstalled/reinstalled ffdshow, avisynth and haali to no avail. Does anyone have any idea what could be causing this? |
29th January 2010, 13:45 | #6794 | Link | |
29th January 2010, 14:20 | #6795 | Link |
@ prettyboy85712 - I have the latest one as downloaded from http://haali.su/mkv/. In the 'About' properties it says 1.9.355.21.
29th January 2010, 14:58 | #6796 | Link | |
29th January 2010, 15:31 | #6797 | Link |
Isnt the latest one on the haali site the 19/12/2009 version?
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
29th January 2010, 15:36 | #6798 | Link |
have you read first post?
29th January 2010, 17:31 | #6799 | Link |
Yes I've read the first post. All it says in the first post is the latest Haali will not work with VC1 .m2ts files. However the source file is already remuxed into MKV, and the video codec is AVC not VC1. So therefore I assumed this advice was not applicable here.
29th January 2010, 19:45 | #6800 | Link |
I have the latest Haali, vc1 files inside m2ts will just not play. like if I try to play an m2ts with MPC (that's setup to use haali instead of the default codec) it will play just the audio and not the video.
I can still process vc1/m2ts fine through ripbot264. it just demuxes the vc1 into an mkv anyways (I assume that's what it's always done as ripbot doesn't recognize raw vc1) so the only thing the new haali will prevent you from doing is playin vc1 inside m2ts |
