Old 29th November 2017, 21:57   #1101  |  Link
Groucho2004
Groucho2004's Avatar
Originally Posted by felicityb View Post
I upgraded everything and I'm still getting the same error. AVSMeter says the error is coming directly from Dither.dll.
AVSMeter 2.6.8 (x86) - Copyright (c) 2012-2017, Groucho2004
AviSynth+ 0.1 (r2544, MT, i386) (0.1.0.0)
Exception 0xC000001D [STATUS_ILLEGAL_INSTRUCTION]
Module:   C:\Program Files\AviSynth\plugins\dither.dll
Address:  0x60457EA0
I suggest starting from scratch. Remove all plugins (make a backup, just in case) and add plugins as needed.
I also couldn't find a version of avs+ r2544 without MT
There is no such thing. AVS+ has been multi-threaded since r16xx.
Old 30th November 2017, 12:11   #1102  |  Link
OK, but whats difference in the '-MT' postfixed versions then ???
Latest release
r2544-MT
53b8d15
Avisynth+ r2544-MT
@pinterf pinterf released this 15 days ago 2 commits to MT since this release
Avisynth+ r2544 (20171115)
20171115 r2544
Fixes
Expr: fix "scalef" for 10-16 bits
modification, additions
Expr optimization: eliminate ^1 +0 -0 *1 /1
Avisynth+ r2542 (20171114)
Fixes
Fix: RGB (full scale) conversion: 10-16 bits to 8 bits rounding issue; pic got darker in repeated 16<->8 bit conversion chain
Fix: ConvertToY: remove unnecessary clamp for Planar RGB 32 bit float
Fix: RGB ConvertToY when rec601, rec709 (limited range) matrix. Regression since r2266
EDIT: Arh, the one in red is not post fixed, perhaps pinterf adds -MT or not, depending upon mood
EDIT: Nah, my mistake, all are postfixed now in actual file name.
EDIT: Guess that I should not skim read.
EDIT: Think I'm finally gonna try avs+ (long-long time since done that), and in x64 I think.
Old 23rd March 2018, 13:58   #1103  |  Link
tormento
Acid fr0g
tormento's Avatar
Dither
Am I wrong or dither is one of the most used plugin and yet with old AVS 2.5 API?
@pinterf and @all
A refresh would be welcome. Last version is AFAIK 1.27.2 from 2015.
@turment on Telegram
Old 6th April 2018, 10:41   #1104  |  Link
DJATOM
@pinterf and @all
https://mega.nz/#!f4sHXYgQ!Hf-5Di0ym...dSe9Bn4CkPyRO4 I just made both win32 and x64 versions with AvisynthPluginInit3. If you know valid up-to-date mt modes for dither, I can add them internally.
Me on GitHub | My Telegram
DJATOM is offline   Reply With Quote
Old 6th April 2018, 10:46   #1105  |  Link
tormento
Acid fr0g
tormento's Avatar
I use external MT with AVS+ (if I've correctly understood your question).
PHP Code:
SetFilterMTMode("DEFAULT_MT_MODE"2)
Prefetch
(6
Old 6th April 2018, 10:53   #1106  |  Link
DJATOM
# Filters from Dither 1.25.0. Tested by Firesledge (not extensively though)
SetFilterMTMode ("DitherPost", MT_NICE_FILTER)
SetFilterMTMode ("SmoothGrad", MT_NICE_FILTER)
SetFilterMTMode ("Dither_box_filter16", MT_NICE_FILTER)
SetFilterMTMode ("Dither_bilateral16", MT_NICE_FILTER)
SetFilterMTMode ("Dither_limit_dif16", MT_NICE_FILTER)
SetFilterMTMode ("Dither_resize16", MT_NICE_FILTER)
SetFilterMTMode ("Dither_out", MT_NICE_FILTER)
SetFilterMTMode ("Dither_removegrain16", MT_NICE_FILTER)
SetFilterMTMode ("Dither_repair16", MT_NICE_FILTER)
SetFilterMTMode ("Dither_median16", MT_NICE_FILTER)
SetFilterMTMode ("Dither_add16", MT_NICE_FILTER)
SetFilterMTMode ("Dither_sub16", MT_NICE_FILTER)
SetFilterMTMode ("Dither_max_dif16", MT_NICE_FILTER)
SetFilterMTMode ("Dither_merge16", MT_NICE_FILTER)
It was in my MtModes.avsi, but Idk if that's up-to-date.
Old 6th April 2018, 10:57   #1107  |  Link
tormento
Acid fr0g
tormento's Avatar
Never had problems with mode 2.
Old 6th April 2018, 11:07   #1108  |  Link
DJATOM
Mode 2 will eat more RAM, so it's better to stick with mode 1 if possible. Anyway new build (now with sources), with mt mode 1 declared internally: https://mega.nz/#!CtcRVLgZ!qzrTRjvu9...fWniOrbuG_lmjY
Old 6th April 2018, 12:52   #1109  |  Link
GMJCZP
GMJCZP's Avatar
Thanks DJATOM for the new paint job!
By law and justice!
Flea Market
GMJCZP is offline   Reply With Quote
Old 11th April 2018, 21:51   #1110  |  Link
tormento
Acid fr0g
tormento's Avatar
@DJATOM
I gave a try to your latest build of dither and it gives me error.
Script:
PHP Code:
SetMemoryMax(8000)
LoadPlugin("D:\eseguibili\media\DGDecNV\x64\DGDecodeNV.dll")
DGSource("E:\in\2_00 Fuga di mezzanotte\fuga.dgi")
#CompTest(1)
SMDegrain (tr=6thSAD=400refinemotion=falselsb=truemode=0contrasharp=falsePreFilter=4truemotion=falseplane=4chroma=true)
Prefetch(6
Gives me the error:
[2018-04-11][22:44:18] Simple x264 Launcher (Build #1124), built 2018-02-27
[2018-04-11][22:44:18] Job started at 2018-04-11, 22:44:18.
[2018-04-11][22:44:18] Source file : E:\in\2_00 Fuga di mezzanotte\fuga_6_lsb.avs
[2018-04-11][22:44:18] Output file : E:\in\2_00 Fuga di mezzanotte\fuga_6_lsb.mkv
[2018-04-11][22:44:18] --- SYSTEMINFO ---
[2018-04-11][22:44:18] Binary Path : D:\eseguibili\media\x264 launcher
[2018-04-11][22:44:18] Avisynth    : Yes
[2018-04-11][22:44:18] VapourSynth : No
[2018-04-11][22:44:18] --- SETTINGS ---
[2018-04-11][22:44:18] Encoder : x264 (AVC/H.264), 64-Bit (x64), 8-Bit
[2018-04-11][22:44:18] Source  : Avisynth (avs)
[2018-04-11][22:44:18] RC Mode : CRF
[2018-04-11][22:44:18] Preset  : slow
[2018-04-11][22:44:18] Tuning  : <None>
[2018-04-11][22:44:18] Profile : High
[2018-04-11][22:44:18] Custom  : --level 4.1 --keyint 240 --aq-mode 2 --sar 1:1
[2018-04-11][22:44:18] --- CHECK VERSION ---
[2018-04-11][22:44:18] Detect video encoder version:
[2018-04-11][22:44:18] Creating process:
[2018-04-11][22:44:18] "D:\eseguibili\media\x264 launcher\toolset\x64\x264_x64.exe" --version
[2018-04-11][22:44:18] x264 0.155.2901 7d0ff22
[2018-04-11][22:44:18] (libswscale 5.0.101)
[2018-04-11][22:44:18] (libavformat 58.10.100)
[2018-04-11][22:44:18] (ffmpegsource 2.30.0.0)
[2018-04-11][22:44:18] built on Feb 26 2018, gcc: 7.3.0
[2018-04-11][22:44:18] x264 configuration: --chroma-format=all
[2018-04-11][22:44:18] libx264 configuration: --chroma-format=all
[2018-04-11][22:44:18] x264 license: GPL version 2 or later
[2018-04-11][22:44:18] libswscale/libavformat/ffmpegsource license: GPL version 2 or later
[2018-04-11][22:44:18] Detect video source version:
[2018-04-11][22:44:18] "D:\eseguibili\media\x264 launcher\toolset\x64\avs2yuv_x64.exe"
[2018-04-11][22:44:18] Avs2YUV 0.24bm5
[2018-04-11][22:44:18] > x264 revision: 2901 (core #155)
[2018-04-11][22:44:18] > Avs2YUV version: 0.24.5
[2018-04-11][22:44:18] --- GET SOURCE INFO ---
[2018-04-11][22:44:18] "D:\eseguibili\media\x264 launcher\toolset\x64\avs2yuv_x64.exe" -frames 1 "E:\in\2_00 Fuga di mezzanotte\fuga_6_lsb.avs" NUL
[2018-04-11][22:44:20] error: System exception - Access Violation
[2018-04-11][22:44:20] (D:/Programmi/Media/AviSynth+/plugins64/SMDegrain-3.1.2�97.avsi, line 739)
[2018-04-11][22:44:20] (D:/Programmi/Media/AviSynth+/plugins64/SMDegrain-3.1.2�97.avsi, line 200)
[2018-04-11][22:44:20] (E:\in\2_00 Fuga di mezzanotte\fuga_6_lsb.avs, line 16)
[2018-04-11][22:44:20] PROCESS EXITED WITH ERROR CODE: 1
Same script works fine with standard dither.dll
Old 11th April 2018, 22:22   #1111  |  Link
DJATOM
Yes, I forgot to add one line, fixed version.
Old 12th April 2018, 07:53   #1112  |  Link
tormento
Acid fr0g
tormento's Avatar
Tested, working.
color banding, deblocking, noise reduction
