Old 1st October 2013, 09:56   #21  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Originally Posted by LigH View Post
That won't make much sense without specific testing parameters.
Looking at the graph, you will see the parameters used : x264 -placebo + no-psy vs x265 defaults
Old 1st October 2013, 10:21   #22  |  Link
professor_desty_nova
professor_desty_nova's Avatar
Maybe in a few weeks/months, when x265 has Weight P and Weight B working and more stuff borrowed from x264 (look at their TODO list), it will be more "fair" to compare...
professor_desty_nova is offline   Reply With Quote
Old 1st October 2013, 19:03   #23  |  Link
mandarinka
mandarinka's Avatar
I don't think those are specifically the problem. It's probably the rate control that is most important.
mandarinka is offline   Reply With Quote
Old 2nd October 2013, 08:28   #24  |  Link
LigH
LigH's Avatar
@ Kurtnoise:
I thought zerowalker asked for any comparison screenshots, not specifically from the test above. That's why I continued thinking about its general sense in the current stage of development...
Apart from other working features, there is also some need for useful default values. From my experience so far, a default quantizer of 32 in x265 is not really a sensible value.
New German Gleitz board
Old 2nd October 2013, 08:50   #25  |  Link
BadFrame
Really love how development has picked up on the x265 project, I'm getting some good 'x264 vibes'
Is there a tool to decode the x265 generated raw hevc stream to another format at the moment?
BadFrame is offline   Reply With Quote
Old 2nd October 2013, 09:17   #26  |  Link
LigH
LigH's Avatar
The Osmo4 player in the GPAC Nightly Builds (Win32) can play it (muxed as MP4 with e.g. MP4Box in this package, or a current L-SMASH).
The HM reference decoder (ver. 12.0 currently?) can decode it to Y4M. JEEB's build (TAppDecoder.exe).
Old 2nd October 2013, 09:27   #27  |  Link
BadFrame
Thanks LigH!
Old 2nd October 2013, 22:22   #28  |  Link
Kurtnoise
Kurtnoise's Avatar
Wanna play with avisynth & libx265 on windows platforms ?
I've made a fresh compile of avconv from libav + patches from Daemon404...
Not all options from x265 cli are available yet but it's a good start.
Old 3rd October 2013, 07:37   #29  |  Link
Kurtnoise
Kurtnoise's Avatar
Maybe...when hevc support in matroska (i.e in Mosu's mkvtoolnix, not Rovi) will be officially supported.
Old 14th October 2013, 08:47   #30  |  Link
nakTT
Originally Posted by lainiwaku View Post
is it hard to use command line version ? i always used MeGui for x264
Same here. I hope some GUI like MeGUI etc could integrate this encoder. I would love to do testing with this new encoder.
nakTT is offline   Reply With Quote
Old 14th October 2013, 13:24   #31  |  Link
Selur
Selur's Avatar
gui support in MeGui and other tools will probably not come unless input via std::in is supported.
Most GUIs won't support tools which require huge temporary files as input.
Old 14th October 2013, 13:53   #32  |  Link
LigH
LigH's Avatar
Apart from that, x265 is not yet available for users, only for testers with sound background knowledge in video coding algorithms, and working with CLI encoders (at least by editing a batch file) is the least issue in the current stage of development.
There is no complete feature implementation yet.
There is no stabe set of command line options yet.
How often do you expect a GUI to follow sudden and unexpected changes in the set of encoder options?
And yes: There is not even support for streaming video sources (pipe / AviSynth) yet. GUIs could not efficiently serve frames to such an encoder.
Old 14th October 2013, 17:32   #33  |  Link
nekrosoft13
anyone could share a sample file encoded in x265?
nekrosoft13 is offline   Reply With Quote
Old 14th October 2013, 17:48   #34  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
Daemon404's test encodes are available in the directory.
[I'm human, no debug]
JEEB is offline   Reply With Quote
Old 14th October 2013, 18:15   #35  |  Link
filler56789
SuperVirus
filler56789's Avatar
This thread @ Videohelp has various sample videos:
http://forum.videohelp.com/threads/357754-%5BHEVC%5D-x265-EXE-mingw-builds
filler56789 is offline   Reply With Quote
Old 15th October 2013, 08:30   #36  |  Link
LigH
LigH's Avatar
Here are also a few of mine.
Also there are some new builds, compiled with MSys/MinGW GCC for x86 or with MSVC11 for x86 and AMD64 (latter may have a minimum requirement of Windows 7 and the MSVC 2012 Redistributable; a CPU with AVX support and 8 GB RAM are reommended): https://x265.cc/
Old 15th October 2013, 10:48   #37  |  Link
Kurtnoise
Kurtnoise's Avatar
who has created this buildbot ? It's from official devs ?
For MSVC builds, it's quite easy to support XP platforms and remove the c++ runtime.
I'll create a patch if needed.
Old 15th October 2013, 10:56   #38  |  Link
LigH
LigH's Avatar
The user registered with the nick "x265.cc" in the VideoHelp forum; I don't know if he is related to the development team.
Old 16th October 2013, 00:10   #39  |  Link
x265_Project
Posts: n/a
He is not.
Tom
MulticoreWare
Old 16th October 2013, 05:48   #40  |  Link
Kurtnoise
Kurtnoise's Avatar
Here is the patch:
# HG changeset patch
# User Kurtnoise <kurtnoise@free.fr>
# Date 1381898006 -7200
#      Wed Oct 16 06:33:26 2013 +0200
# Node ID 723e554191e14e6289342043225e485e656c27d7
# Parent  a998daed845922b3b880b48c0cafa32c422c941e
Add Windows XP support in MSVC11 builds. This requires CMake 2.8.11 or later.
diff -r a998daed8459 -r 723e554191e1 build/vc11-x86/make-solutions.bat
--- a/build/vc11-x86/make-solutions.bat	Tue Oct 15 20:57:47 2013 -0500
+++ b/build/vc11-x86/make-solutions.bat	Wed Oct 16 06:33:26 2013 +0200
@@ -3,4 +3,4 @@
 :: run this batch file to create a Visual Studion solution file for this project.
 :: See the cmake documentation for other generator targets
-cmake -G "Visual Studio 11" ..\..\source && cmake-gui ..\..\source
+cmake -G "Visual Studio 11" -T "v110_xp" ..\..\source && cmake-gui ..\..\source
diff -r a998daed8459 -r 723e554191e1 build/vc11-x86_64/make-solutions.bat
--- a/build/vc11-x86_64/make-solutions.bat	Tue Oct 15 20:57:47 2013 -0500
+++ b/build/vc11-x86_64/make-solutions.bat	Wed Oct 16 06:33:26 2013 +0200
@@ -3,4 +3,4 @@
-cmake -G "Visual Studio 11 Win64" ..\..\source && cmake-gui ..\..\source
+cmake -G "Visual Studio 11 Win64" -T "v110_xp" ..\..\source && cmake-gui ..\..\source
diff -r a998daed8459 -r 723e554191e1 source/CMakeLists.txt
--- a/source/CMakeLists.txt	Tue Oct 15 20:57:47 2013 -0500
+++ b/source/CMakeLists.txt	Wed Oct 16 06:33:26 2013 +0200
@@ -7,7 +7,7 @@
 endif()
 project (x265)
-cmake_minimum_required (VERSION 2.8.8) # OBJECT libraries require 2.8.8
+cmake_minimum_required (VERSION 2.8.11) # OBJECT libraries require 2.8.11
 # X265_BUILD must be incremented each time the public API is changed
 set(X265_BUILD 1)
XP platforms require v110_xp as toolset instead of v110. Otherwise, applications don't run correctly on this platform.
This patch requires CMake 2.8.11 because the flag dedicated to the toolset has been fixed in this version.
