#61 | Link |
High frequencies can mean an edge, in which case you want a low quantizer ... or it can mean noise or texture, in which case you want a high quantizer. Also expecting the encoders to make sane choices all the time is probably way too optimistic.
I still think your efforts would be better spend in a place where the data you want is actually available ... try taking a look at DMPGdec, writing a drop in replacement for it's post processing is relatively easy, and the postprocess function already gets an array with the per block quantizer values. |
#62 | Link | |
Confused...my english is probably not good enough;-) |
#64 | Link |
Aaa, that's what writing a drop means... Well, how about only adding an option to the MPEG2Source to produce the mask of quantizers? I could do then whatever i want with that later...
Then I really like to have confirmed from someone, whether there are other codecs with variable quant within one frame than those which can be processed by DGMPGdec... |
#65 | Link |
ангел смерти
![]() Join Date: Nov 2004
Sure, practically any codec can use adaptive quantization, and they can be stored in most containers. Not all implementations do, but it's very common to find MPEG (1-4) and VC-1 with quants varying per-block.
You have to take into account the quant matrix, if you really want to figure out what quant was there before, because a 'high detail' matrix can cause a lot of blocking while also keeping a lot of noise/texture. (Texture means a pattern, though it doesn't have to be regular; here it means all of the useful non-edge information.) High quants with these matrices cause a lot of ringing/mosquito noise, instead of just removing high frequencies. Last edited by foxyshadis; 27th November 2007 at 03:20. |
#66 | Link | ||
error_uv=quant*m_uv/2 error_uv=max error for frequency uv m_uv=value in quant matrix ...at least for non AVC keyframes, right? |
#67 | Link |
ангел смерти
If you never use the capabilities, then AQ won't be present, obviously. You can make your own by enabling that option in xvid, x264 (patched), mainconcept h.264, Nero, or various ffdshow codecs (in the 'Masking' option page).
#68 | Link |
after reading some MPEG-2 docs and thinking over I got following (pls comment whether I am mistaken if you like): - maybe I know what is pattern already. extreme example: when all freqs are veeeery strongly quantized except the last one, then on decoded frame the last frequency can dominate and we see it as 2D wave…thats the pattern…? This example does not happen because the coefs are increasing to higher freqs…but is that the principle. - the amount of detail in decoded block does not say anything about the possible error=>blocking magnitude - the amount of detail in decoded block does say about the possible damage when zeroing hi-freq coefs with DCTFilter on shifted video - if I learn the quantizer from DGDecode and read the Qmatrix, I can calculate various values and averages of max or expected error…this could help for deblocking adaptability - this calculation is same way possible for I frames or P frames (except the [0,0] coef?), I don't know how about B frames - surprise: it is not that a frame DCT is either frame based or field based. My feeling is it can differ every macroblock. Some blocks are encoded progressive, some interlaced within one frame… R* |
#69 | Link |
Hi, again begging for opinions:
I played with excel and simulated the codec process using MPEG quant matrix I obtained from DGDecode and random 8x8 sample blocks with following results (maybe I am discovering discovered thing but thats the risk ![]() I defined Code:
TME(Q)= (theoretical maximal error for quantizer Q) = (value of pixel[0,0] if all values of freq coefs before inverse quantization equal 0.5) example: TME(1)=7 TME(2)=12 TME(3)=19 TME(4)=24 TME(5)=30 Now all calculated values can be formed as multiplication of this TME for desired quantizer. Result looks like: Code:
EA(Vert)=expected absolut value of average of absolute values of pixel errors on vertical edges E(Vert)=expected absolut value of average of pixel errors on vertical edges MA(Vert)=maximum absolut value of average of absolute values of pixel errors on vertical edges M(Vert)=maximum absolut value of average of pixel errors on vertical edges ....and E(Vert)=1.6% E(Hor)=1.7% M(Vert)=6.2% M(Hor)=6.4% EA(Vert)=7% EA(Hor)=6.7% MA(Vert)=14.1% MA(Hor)=13.3% M(Max8x8)=47% E(Max8x8)=28% and so on Code:
...macroblock with quant 10 comes, I know: TME(10)=60 E(Vert)=1.6%*60=0.96 E(Hor)=1.7%*60=1.02 E(Hor)=6.4%*60=3.84 ..and even per pixel if needed E(pixel[0,0])=6.9%*60=4.14 M(pixel[0,0])=24.61%*60=14.766 E(pixel[1,0])=8.65%*60=5.19 M(pixel[1,0])=29,28%*60=17.568 Code:
E(Hor)*TME(40)=1.7%*242=4.114 M(Hor)*TME(40)=6.4%*242=15.488 M(Max8x8)*TME(40)=47%*242=113.74 Conclusion: I think, this can be together with with edge detection solid base for adaptive deblocking in my filter. However 1) I modelled the samples simply =INT(RAND()*256), which is not reality...in reality the samples would be correlated and the error will be smaler. How to model more real-like situation, any ideas? 2) I hope there are no errors like the 113 example or higher. I guess the encoder chooses lower quant but how to estimate this. Is there any SNR or block complexity/variance rule which can help? Thanks for ideas. R* |
#70 | Link |
Step one finished: I have the quantizer mask from MPEG file from here;-)
Now...can anyone guess the distribution of the error values in non-intra block? Or at least some average...or something. What I think is, that the values are small compared to intra values but can be negative... but any better estimation? |
#71 | Link |
Can you tell me opinion how to make weighted smoothing correctly?
If we have weight clip w and values clip x then (symbolically): Code:
s="1 2 3 2 1" #weights of moving average y=w*x z=y.convolution(s) ww=w.convolution(s) output=z/ww But how about smoothing using DCTFilter? Code:
y=w*x z=y.DCTFilter(1,1,1,1,0,0,0,0) #for example #now which formula for ww is correct? ww=w ww=w.DCTFilter(1,1,1,1,0,0,0,0) ww=w.DCTFilter(1,0,0,0,0,0,0,0) #probably not output=z/ww Thank you. |
#72 | Link |
@Tobias (or whoever else can answer)
Once you mentioned, that for smoothing in my filter, quantization with the original matrix which was used to encode would be better than using DCTFilter. I am thinking about implementation. I plan to read DGDecode quants, and DGIndex quantmatrixlog, so it is possible. But can you please explain the reasons, so I know whether it is worth the effort? If I finish, expect improved MMX SmoothDeblock, so no more speed issues… so I wanna do it well. |
#73 | Link | |
Professional Lemming
Hi redfordxx,
good work. Keep up the speed ![]() Quote:
Could you post performance figures for your MMX code once you get them? It would be great to use that for playback on HD resolutions ![]() bis besser, 708145
projects page: ELDER, SmoothD, etc. |
#74 | Link | |||
There will be the option to smooth with larger matrices...I think 12x12 or 16x16 might be interesting. How to apply the rule you mentioned on that? What should look a matrix bigger than 8x8 like to smooth similarily like a the known 8x8 matrix? Seems to me that the down right corner could look similar...but I dont know Quote:
* first pass, which would be very fast, will be done on a clip with showQ=true and saved (look at the link few posts above) * second, the real deblocking will happen |
#75 | Link | |
Bored...
Bwt, good to see some movement in here... :] Thx n' Bye |
#76 | Link | |
Whatever frequencieds the matrix and quantizer quantize, it always results in high frequencies in shifted block. And these high frequencies should be partially/fully removed. Or it is different? |
#77 | Link | ||
![]() Quote:
bis besser, 708145
#78 | Link |
ангел смерти
If you remove all or most high frequencies, you may as well just use Deblock() or fft3dfilter(). In fact I can't really find any way around the inevitable detail-or-noise aspect of ringing, except in special conditions like anime.
#80 | Link | |
Original: Highly quantized - blocking: o | o | | o | o o o o | o | o o o o| o | | o | | o | | o| | |o | | o | | o | | o | | o |o o o o | o | o o o o | o | | o | high frquencies here ^ Code:
Removed hi freq on shifted block: | | | o o o o | o | o o | o| | | |o | o o | o | o o o o | | | | shifted block | |
