19th January 2009, 14:38 | #21 | Link |
Commercials and movies do not always start and end on GOP boundaries. That's why I'm looking for frame-level editing.
Actually, at the end you don't need to encode anything. Just leave out some frames after the cut. And can't you just take the first frame and apply all changes of the next frames and use that as your new first frame for the beginning of a new cut? Anyway, we're only re-encoding the fraction of a second. That won't be much work (for the CPU) and the quality loss is almost invisible. |
19th January 2009, 16:52 | #22 | Link |
Ya these are all okay in technology. But I do not have any practical program.
Like what we did to mpeg2, to avc/264, I can find IDR of the start point, start decoding from IDR, when we meet start point we re-encode frames into a new file, we keep doing so till we meet next IDR, called IDR2. Then we got a new prefix-264-file. Second, I can demux original file from IDR2 into a new middle-part-file. Attention: this will also generate new audio stream file(s), call them middle-audio-file. Third, I can link (prefix-264-file) and (middle-part-file + middle-audio-file) by a 264 re-mux operation. I do have all these source code we need, but they are all coarse source code, needed to be combined together. That is not very difficult, but a time-consuming work. And finally comes the real hard job: a/v sync. Since the prefix file has no audio boundled, select a start point of middle-audio will be important. This will lead to a/v out of sync if we do not take care of it. The in-fluency you mentioned before, may comes from such kind of problem. Sorry friend, I did not do any real help. I was busy on managing a project on web-video-stream, something relavant to 264/avc. May be after that, I can find some time, make a so-called 'smart' program. Not so many people need this high-demand thing, but it looks useful, and worth a try. By the way, the middle-part-file may be held in the memory buffer, make the operation in-the-fly. Last edited by guodongzhe; 19th January 2009 at 16:53. Reason: color not comfortable |
19th January 2009, 23:02 | #24 | Link |
TSPE actually can edit to Sub-GOP accuracy. It's not yet video frame accurate, but you can set end points at P frames. Start points need to be at I/IDR frames. I know the UI is somewhat complicated, but you can remove some of the buttons. The workflow should still be pretty simple, there are some examples on the website. The very basic workflow is to set the start point, set the end point, then hit edit. This will trim a file. 3 clicks and you are finished. I don't know how I can make that more simple! If you need to edit out commercials, all you do is: Set start point, set end point, click Add, repeat for next segements, then hit edit. Again, 3 clicks per segment followed by 1 click for the edit. In some cases, TSPE will automatically find the start/end points for you. How much simpler do you want it? One of TSPE's main objectives is to be able to open any type of transport stream and edit. It is not limited by any type or number of video streams or audio streams. It is also a transport stream analyser and can fix some types of errors in the stream. Hope that helps, Regards, Vent |
19th January 2009, 23:12 | #25 | Link | |
Another thing I've run into, when you highlight a couple of your edits in the edit list that the highlight doesn't stay, it sort of grays out and it's hard to determine that they are highlighted, which is no biggie, but if you finish editing and adding the sections you want for the final file and then click edit, the highlighted ones are the only ones that get processed. |
19th January 2009, 23:31 | #26 | Link | ||
Hope that helps, apologies for straying off topic! (please do post in the TSPE thread for further discussion) Regards, Vent |
20th January 2009, 07:37 | #28 | Link | |
Anyway, what is a P/I/IDR frame? Does it occur more often than every 100 ms? And when cutting within the movie, I really need to find the very same frame, not something a few 100 ms off. |
15th February 2009, 18:02 | #29 | Link | |||||
Everybody takes this for granted from mpeg2 editing. For mpeg2 there is excellent freeware availble which sets a comfortable standard, for example Mpeg2Schnitt for PAL footage. We need and want the same comfort for h.264! It is astonishing, all those who can do it with re-encoding seem to not want to do it with re-encoding the first and last edited GOP only. Maybe they are so proud being able to re-encode that simply to copy the middle part is too less a challange for them? Quote:
I am happy to use Ventolin's TSPE until you or somebody else will come up with a "H264Cutter" with features for h.264 footage like Mpeg2Schnitt provides for mpeg2 footage. TSPE does an excellent job for all projects where cutting to a millisecond is not required. You learn to use it fluently by doing 2 or 3 jobs. Then it is easy to use. Gives exact control of what is done. Produces output at the speed of a copy operation. Best of all, a/v-sync is conserved throughout all processing and does not require demuxing and remuxing steps in the workflow! It will be an interesting competition. Who will be first to provide the real thing? Ventolin, guodongzhe or others working to the same goal? For the time being, Ventolin is ahead, only multi-stream support and frame-accurate smart editing of first and final GOP of each EDL needs to be added. Then it will be perfect. Or, take Ventolin's a/v-sync solution and mix it with guodongzhe's prefix/postfix-264-file solution... Just dreaming... Quote:
Cheers, Cela Last edited by Cela; 15th February 2009 at 18:08. |
16th February 2009, 12:27 | #31 | Link |
Avisynth language lover
Cuttermaran (which is free) provides frame-accurate MPEG1/2 editing, re-encoding only where necessary to rebuild an edited GOP.
16th February 2009, 18:03 | #32 | Link | |
LOL. Mpeg2Schnitt (german for "Mpeg2Cut"), like Cuttermaran, IS frame-accurate if you use it correctly!
You may not use it often. Or, if you use it, you did not set it up correctly. I use its frame-accurate cut feature every day! Google translation from the appropriate section in the (german) help file: 3. Cuts Set The parts of the video or (and) the audio files into the newly-cut files are to be taken must be cut in the cut list will be added (positive list). Each section consists of one IN and one OUT intersection. The IN-intersection is the first picture that is being adopted and the OUT-intersection is the last picture is still on. To create the cuts do you control the corresponding point in the video and then press the IN or OUT button. The intersection is taken over and the key right next to it appears. Clicking this button allows the slider to jump to the appropriate position. In addition, the cut as a blue area on the sliding scale. Is the IN and OUT of the intersection must be cut down in the cut list will be inserted. For this you click on the bottom button (with the small scissors). As cuts in the cut list can be inserted under Options -> cut list -> Others can be set. Should another short Einfügeart {~ input mode} can be used by Rechtsklich {~ right mouse button click} on this button a sub menu. The entry will overwrite the change in the cut list, cut marked with the actual value. If the IN or OUT button with a question mark and red text must be an intersection at this point to be recalculated. The intersection must be calculated are also in the cut list red. Cuts with no new points are calculated only on I and P frames possible. The sequence of cuts in cut list can push through with the mouse will change. Some functions, such as "Intersection delete", are available only through the context menu of the editing window or keystrokes away. This translation is really bad. But what it tells is: Mpeg2Schnitt does I-to-I frame and I-to-P frame cuts WITHOUT re-encoding and other cuts (marked with red text) WITH re-encoding (recalculation) to and from the next I frame. To use re-encoding you have to setup the connection between Mpeg2Schnitt and your favourite encoder first! In short: Quote:
Cela Last edited by Cela; 16th February 2009 at 18:06. |
16th February 2009, 18:16 | #33 | Link |
Last time I tried version 0.91, it did not allow to set in/out points somewhere else than every few frames. NOT everywhere. Can you please point me to the help page? I cannot find the text you're referring to. (German description is okay.)
16th February 2009, 22:18 | #34 | Link | |
http://www.mdienert.de/mpeg2schnitt/ Mpeg2Schnitt forum (in german): http://forum.dvbtechnics.info/forumdisplay.php?f=15 For a correct setup of frame-accurate cutting, please, refer to the instructions in the "Hilfe" (Help): > open Mpeg2Schnitt homepage (in german) at http://www.mdienert.de/mpeg2schnitt/ > Select "Hilfe" (Help) at the left side of the HP and you will get "Hilfe zum Mpeg2Schnitt-Programmpaket" (Help for Mpen2Schnitt) You can also download the Help File "Mpeg2Schnitt09HtmlHilfe.zip" in the Download section. Start reading by selcting "Erste Schritte" (first steps) > Einfuehrung in (Introduction to) Mpeg2Schnitt > Systemvoraussetzungen und Installation (System requirements and installation) > In wenigen Schritten zum geschnittenen Video (In a few steps to the cut video) For setup of frame-accurate cutting, please, consult > "Hilfe" > "Wie macht man was" (How to do it) > There select "Programmeinstellungen" (program settings) > The select "Encoder - framegenauer Schnitt, lange GOPs kürzen" (Encoder - frame-accurate cut, shorten long GOPS) It is very important to follow all the instructions precisely. I use "Encoder\EncoderHC21.prg" DGDecode.dll Version 1.4.8.0 217 KB HCenc_021.exe Version 0.21.0.0 1.168 KB and HC.ini with the following 4 lines as content: Code:
*MAXBITRATE 6000 *MATRIX mpeg *NOSCD *WAIT 0 EncoderHC21.prg with the following content: Code:
[Encoder HC021] X0X=*interlaced X1X= :enc Echo Videoteil berechnen ($BeginIndex#, $EndIndex#) cpsourcefile copyx "$ProgramDirectory#\Encoder\HC-M2S-org.ini" "$TempDirectory#\HC-M2S.ini" :eff copyx "$ProgramDirectory#\Encoder\HC-M2S-Eff-org.ini" "$TempDirectory#\HC-M2S.ini" Rem :all Rem "$ProgramDirectory#\Encoder\DGmpgdec\DGIndex.exe" -IF=[$PartFile#] -OF=[$PartFiled2v#] -hide -exit :enc RunnotCml "$ProgramDirectory#\Encoder\HCEnc\HCenc_021.exe" -i "$PartFiled2v#" -o "$NewFile#" -ini "$TempDirectory#\HC-M2S.ini" :eff RunnotCml "$ProgramDirectory#\Encoder\HCEnc\HCenc_021.exe" -i "$TempDirectory#\AViSynthscript.avs" -o "$NewFile#" -ini "$TempDirectory#\HC-M2S.ini" :all Rem DeleteTempFiles=0 > Erste Schritte (First steps) >> In wenigen Schritten zum geschnittenen Video (Few steps to the cut video) >>> 3. Schnitte festlegen (Doing the cuts - How to cut) There should be an english version out there, at least I know from the forum that there were translations done. But since my german is better than my english, I did not follow up. If you need more informations feel free to contact me by PM. Good luck, Cela |
