23rd November 2009, 15:20 | #162 | Link |
Software Developer
Yes, of course I did. As said before, it doesn't make TimeCodec freeze anymore, but doesn't show up in the list. Also it doesn't make GraphStudio freeze anymore, but adding the "DiAVC" filter from the list doesn't do anything. The filter cannot be added to the graph, although it appears on the list. So all seems like the filter is registered correctly but connect be instantiated. For detailed system specs, see my sig...
23rd November 2009, 16:40 | #164 | Link |
Software Developer
No, it didn't move for sure. But I will try again this evening
23rd November 2009, 18:00 | #165 | Link | |
23rd November 2009, 18:17 | #166 | Link |
Spinner of yarns
Incidentally, could you fix jerky-playback on DiAVC+madVR if the stream has non-mod16 height?
Ah, if this is madVR's problem, don't mind this.
僕と契約して、L-SMASH developerになってよ! L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software Last edited by VFR maniac; 23rd November 2009 at 18:26. |
23rd November 2009, 22:19 | #169 | Link | |
Spinner of yarns
Uhh, jerky-playback of non-mod16 streams is maybe madVR's problem. I found other bugs: 1. DiAVC cannot connect stream in WMP11, though DiAVC set as default decoder. But DiAVC can connect it after changing the merit value into 0xff80000X. 2. When the stream is repeated in any players and renderers, the frame-rate position (or timestamp position) is shifted. For example: first time: 0(24) 1(24) 2(24) 3(30) 4(30) 5(30) ... second time: 0(24) 1(24) 2(24) 3(24) 4(30) 5(30) ...
僕と契約して、L-SMASH developerになってよ! L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software |
24th November 2009, 11:39 | #170 | Link | |
24th November 2009, 11:55 | #171 | Link |
24th November 2009, 12:17 | #174 | Link | |
24th November 2009, 12:35 | #177 | Link |
Your welcome. DiAVC doesn't seem to have a problem with it, the only decoder I know of that does is CoreAVC. I don't know if out of spec mv's is still prominent in Paramount BD's but at one point I ran across 3 within a month of retail, stopped using coreavc after that so I don't know.
24th November 2009, 14:19 | #178 | Link |
Spinner of yarns
A timestamp shifting sample I encoded with x264.nl's x86 rev1347 and muxed as VFR MP4 is here.
http://www.megaupload.com/?d=CCKL7TY8 pass: bugreport@vfrmaniac (Sorry, I encrypted the sample because megaupload do not approve file deletion.) Timestamp shifting stands out remarkably around 00:56. Other AVC decoders do not reproduce this. This issue is fatal for VFR videos with deduplication.
24th November 2009, 22:54 | #179 | Link | |
Software Developer
Okay, I finally managed to get the latest DiAVC Alpha working on my system. And the results are quite impressive
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 30th November 2009 at 20:43. |
avc, diavc, fastest decoder, h.264, software |
