Old 9th February 2008, 12:22   #1001  |  Link
Casimir666
Whouaaa so many messages about subtitles !
@pdanpdan
DXVA didn't works when there is filters between video decoder and renderer, so ffdshow or DirectVobSub are prohibited if you wan't to use hardware acceleration. Can you PM me a link with a sample that crash mpc?
@donaldtone
Not 100% sure, but I think VMR7 required at least a video card compatible with DirectX 7, and VMR9 at least DirectX9.
Tired of tearing?
Try this Media Player Classic mod : http://mpc-hc.sourceforge.net
Casimir666 is offline
Old 9th February 2008, 15:31   #1002  |  Link
3ngel
Casimir, can you add to
File->Open File... -> Dub -> Browse
the .AC3, .DTS, .EAC3, .Flac extensions in the "Objects of type" filter of the dialog box?
and
File->Open File... -> Open -> Browse
the .Avs extension in the "Objects of type" filter of the dialog box?
Thanks
3ngel is offline
Old 9th February 2008, 19:43   #1003  |  Link
jhoff80
On my 3870, DXVA is working GREAT with everything but 1080p files with this. 1080p files just show a green screen. What are the odds of that ever working, or is it just because of the way the files are encoded? (I remember reading something about level 4.1 being the max or something?)
Also, what are the odds that just the filters will be released alone (hopefully in x64 form) so that we can use DXVA on other programs (I mainly want to use it in Media Center.)
jhoff80 is offline
Old 9th February 2008, 22:14   #1004  |  Link
leeperry
Kid for Today
anyone manages to get rock solid 24.000 FPS ?
I got Reclock running with EVR on XP SP2, resampling 23.976@24 in 48.000 Hz
it's usually fine for 10/15 mins, then it starts oscillating between 23.99x/24.00x and starts dropping frames
If only I had an idea about wtf is up...
leeperry is offline
Old 10th February 2008, 00:04   #1005  |  Link
Casimir666
I don't think the problem is the resolution (i have some 1080p video that works). Some H264 with 5.1 level works too, but other display black or green screen. I haven't find a solution yet to detect such files and switch automaticly to software mode
Tired of tearing?
Old 10th February 2008, 00:56   #1006  |  Link
Shinigami-Sama
Solaris: burnt by the Sun
Shinigami-Sama's Avatar
I thought that it was determed down in the AVC forum that it was the ref_num_size block, and if it exceeded a certain threshold that hardware acceleration broke
Originally Posted by benjust View Post
interlacing and telecining should have been but a memory long ago.. unfortunately still just another bizarre weapon in the industries war on image quality.
Shinigami-Sama is offline
Old 10th February 2008, 13:51   #1007  |  Link
tetsuo55
MPC-HC Project Manager
If you perform the following checks on the header of the file you will know if the file is DXVA able or not
First check if the SAR is okay:
"only allowed are 1:1/4:3/5:4/16:9"
If SAR is okay, then check the resolution and ref frames with the following calculation:
For resolutions higher than 720x576
mod16 width X mod16 height X ref frames <= 8355840
For resolutions equal or lower than 720x576
mod16 width X mod16 height X ref frames <= 4561920
If SAR is not okay, default to software mode
If width or height is not mod16 default to software mode
If calculated values are higher than the maximum number default to software mode
In other cases enable DXVA
See here for more details : http://forum.doom9.org/showpost.php?...&postcount=199
Last edited by tetsuo55; 10th February 2008 at 14:59. Reason: Complete rewrite of post, much simpler now
tetsuo55 is offline
Old 10th February 2008, 15:59   #1008  |  Link
Casimir666
Ok this is the easiest things to check.
Hum... all broken files i had respect your rule :
- Sample1 : 640*480*8 = 2457600 < 4561920
- Sample2 : 720*416*6 = 1797120 < 4561920
I have read part of the thread, the incompatility rules seems not so clear
Tired of tearing?
Old 10th February 2008, 16:05   #1009  |  Link
tetsuo55
Could you post the avinaptic output of these samples?
(the other fail reasons are not so easy to detect)
tetsuo55 is offline
Old 10th February 2008, 16:54   #1010  |  Link
Casimir666
Sample 1 : crash ATI Driver
Originally Posted by sample1
[ Generic infos ]
Play duration: 00:24:30 (1469.888 s)
Container type: matroska
Creation time: 7/12/2007 23:27:22 UTC
Number of streams: 4
Type of stream nr. 1: video (V_MPEG4/ISO/AVC) {...}
Type of stream nr. 2: audio (A_VORBIS) {2.0 Vorbis}
Type of stream nr. 3: subtitle (S_TEXT/ASS) {ASS}
Type of stream nr. 4: subtitle (S_TEXT/UTF8) {SRT}
Audio streams: 1
Muxing Application: libebml v0.7.7 + libmatroska v0.8.1
Writing Application: mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
[ Relevant data ]
Resolution: 640 x 480
Width: multiple of 32
Height: multiple of 32
[ Video track ]
Codec ID: V_MPEG4/ISO/AVC
Frame aspect ratio: 4:3 = 1.333333
Pixel aspect ratio: 1:1 = 1
Display aspect ratio: 4:3 = 1.333333
Framerate: 23.975986 fps
[ Audio track ]
Codec ID: A_VORBIS
Channels (container): 2
Sample rate: 48000 Hz
[ About H.264 encoding ]
User data: x264
User data: core 45 svn-485M
User data: H.264/MPEG-4 AVC codec
User data: Copyleft 2005
User data: http://www.videolan.org/x264.html
User data: cabac=1
User data: ref=5
User data: deblock=1:0:0
User data: analyse=0x3:0x133
User data: me=umh
User data: subme=7
User data: brdo=1
User data: mixed_ref=1
User data: me_range=24
User data: chroma_me=1
User data: trellis=2
User data: 8x8dct=1
User data: cqm=0
User data: chroma_qp_offset=0
User data: slices=2
User data: nr=0
User data: bframes=3
User data: b_pyramid=1
User data: b_adapt=1
User data: b_bias=0
User data: direct=1
User data: wpredb=1
User data: bime=0
User data: keyint=250
User data: keyint_min=25
User data: scenecut=40
User data: rc=2pass
User data: bitrate=857
User data: ratetol=1.0
User data: rceq='blurCplx^(1-qComp)'
User data: qcomp=0.60
User data: qpmin=10
User data: qpmax=51
User data: qpstep=4
User data: cplxblur=20.0
User data: qblur=0.5
User data: ip_ratio=1.40
User data: pb_ratio=1.30
SPS id: 0
Profile: High@L5.1
Num ref frames: 8
Chroma format idc: YUV 4:2:0
PPS id: 0 (SPS: 0)
Entropy coding type: CABAC
Weighted prediction: No
Weighted bipred idc: B slices - implicit weighted prediction
8x8dct: Yes
[ Profile compliancy ]
Profile to check: MTK PAL 6000
Resolution: Ok
Framerate: 23.975986 <> 25
Warning: If you need a more complete report, then click on "DRF analysis"
[ Attachment nr. 1 ]
MIME Type: application/x-truetype-font
UID: 1723722417
[ Attachment nr. 2 ]
Name: Alberta Italic.ttf
UID: 816201406
[ Attachment nr. 3 ]
Name: Alberta Regular.ttf
UID: 412550843
Sample 2 : green screen
Originally Posted by sample2
[ Generic infos ]
Play duration: 00:24:30 (1469.929 s)
Creation time: 30/11/2007 12:38:38 UTC
Audio streams: 1
[ Relevant data ]
[ Video track ]
[ Audio track ]
Codec ID: A_VORBIS
User data: x264
User data: core 54 svn-635M
User data: cabac=1
User data: ref=5
User data: me=umh
User data: subme=7
User data: brdo=1
User data: 8x8dct=1
User data: cqm=0
User data: deadzone=21,11
User data: threads=2
User data: nr=0
User data: decimate=1
User data: mbaff=0
User data: b_bias=0
User data: direct=1
User data: wpredb=1
User data: bime=1
User data: scenecut=40(pre)
User data: rc=2pass
User data: qpmin=10
User data: qpmax=51
User data: qpstep=4
User data: aq=1:1.0:15.0
SPS id: 0
Profile: High@L5.1
Num ref frames: 8
PPS id: 0 (SPS: 0)
8x8dct: Yes
Resolution: Ok
UID: 2081959055
UID: 2561216676
UID: 445150875
[ Attachment nr. 4 ]
UID: 78096267
[ Attachment nr. 5 ]
UID: 3072692916
[ Chapters ]
Prologue: 00:00:00,000 - 00:00:33,000
Opening: 00:00:33,000 - 00:02:13,000
Clannad 09: Until the Very : 00:02:13,000 - 00:22:20,100
Ending: 00:22:20,100 - 00:23:50,100
Preview: 00:23:50,100 - [undefined]
By the way, how did you compute the limit value 8355840, because i have also seen 8294400 (1920*1080*4) in your thread?
Tired of tearing?
Old 10th February 2008, 16:56   #1011  |  Link
Casimir666
Oups i'm stupid it's 1920x1088*4
Tired of tearing?
Old 10th February 2008, 17:06   #1012  |  Link
tetsuo55
That limit is based on the real HD resolution 1920x1088
Well from your problem descriptions its obvious that DXVA is enabled, otherwise you would not be seeing the crash/green screen
Now as too why the files do not work, there are 2 issues i can see here.
Issue 1, mkv problems, you can try remuxing the video's with the latest version of mkvmerge.
Issue 2, Those files where made with old to very old versions of x264, it is actually known that these older versions contain a bug that break DXVA.
(Issue 3, the level is wrong, but this does not matter for your player, if you change the level to 3.1 you can test them with the cyberlink decoder)
This is not something you can easily test the file for, maybe its a good idea to report these non working files in the dxva problem thread, and see what the others have to say about it.
I say we ignore these for now, as a new encode with the latest version of x264 should work(as proven in the dxva problem thread)
tetsuo55 is offline
Old 10th February 2008, 17:26   #1013  |  Link
Xin-Hong
Originally Posted by pdanpdan View Post
It's already unchecked, and the subtitles are not loading in the mplayerc (not HC).
Also, all files play OK with mplayerc (not HC) with or without susbtitles enabled (x264 decoded by ffdshow).
The subtitles are included in the MKV files, not external.
I had the same problem too with subtitles in MKV. I have to delete the key "HKEY_CURRENT_USER\Software\Gabest\Media Player Classic" in the registry, reconfigure MPC HC and then, I have subtitles.
Xin-Hong is offline
Old 11th February 2008, 08:26   #1014  |  Link
Casshern
on my machine with r396 mpc hc some files do not work with DXVA which work fine with cyberlink h264 decoder in DXVA mode. These are mainly 25fps h264 sky captures (these show black and white / half screen garbled in MPC HC) and some files show just green/black screen. So it seems apart from level 4.1 compliance there is something cyblerlink does, which sets up the ATI drivers to properly do DXVA acceleration - maybe it sets some additional parameters.
One other thing: Is there a way to make m2ts or evo files show up in the file requesters by default - i always have to set it to "show all files"... is this configurable?
Casshern is offline
Old 11th February 2008, 08:58   #1015  |  Link
juffi
@pdanpdan
What is the way of getting subtitles and still have DXVA?
juffi is offline
Old 11th February 2008, 08:59   #1016  |  Link
Shinigami-Sama
use a renderer that supports subtitles
like
vrm9 renderless and, haali, and evr
Old 11th February 2008, 14:24   #1017  |  Link
CruNcher
CruNcher's Avatar
Haalis renderer supports DXVA now???
Originally Posted by Casshern View Post
Most probably a MBAFF Decoding problem how it sounds seems this kind of decoding has to be specialy triggered in Nvidias and ATis APIs to work in DXVA, especialy in combination with their Motion Adaptive Deinterlacing Stuff.
It is about Time
CruNcher is offline
Old 11th February 2008, 14:29   #1018  |  Link
jaybox
hi forumashi
I've just changed icon groups
v6.4.9.1 mpc hc 1.0.11.4
icon sizes:
high res:
16x16
32x32
48x48
and 16x16 [256 colors]
http://rapidshare.com/files/90911167...lassic.7z.html
jaybox is offline
Old 11th February 2008, 19:45   #1019  |  Link
Casimir666
Is it interlaced video? I think there is a problem with such video at the moment.
Tired of tearing?
Old 11th February 2008, 21:40   #1020  |  Link
Shinigami-Sama
from what i've read it appears to, but I might be wrong, I kinda suck with renderers
dxva, h264, home cinema, media player classic, mpc-hc
