Go Back   Doom9's Forum > Capturing and Editing Video > DV
Old 12th December 2004, 07:54   #61  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
no! you should have read the AVISynth documentation.
FixBrokenChromaUpsampling() will correct a progressively upsampled to interlaced upsampling. But that is NOT the case with the canopus decoder. it upsamples correctly in relation with interlacing.
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 12th December 2004, 10:28   #62  |  Link
henryho_hk
I am referring to ScrollLock's sticky thread DV decoder differences.
From your advice, as my target is YV12 (MPEG1 or WMV actually), I think I should either:
1) grab the YVY2 output of Canopus and then point-sample (reducetoyv12) it to YV12; or
2) try the YV12 output of ffdshow's VFW module.
I am particularly interested if ffdshow will deliver both PAL and NTSC outputs correctly.
henryho_hk is offline   Reply With Quote
Old 12th December 2004, 14:56   #63  |  Link
scharfis_brain
brainless
if your chroma look coarse interlaced instead of being fine combed, you will need fixbrokenchromaupsampling().
otherwise you won't need it.
my canopus decoder is working correctly!
PAL can be used with ffdshow's YV12 output.
but for NTSC it is a mess, cause it puts out the 4:1:1 samples chroma as YV12 data, which is handled by AVISynth as 4:2:0 sampled chroma.
Just use normal NTSC-DV decoding as it is.
maybe use reinterpolate411() afterwards.
you will not gain anything by working with YV12 output here.
Old 12th December 2004, 15:54   #64  |  Link
Wilbert
@scharfis_brain
Natural video is not that suited for checking for half pel chroma displacements, I think.
So I came to that (probably wrong) conclusion that DV Cams are building conventional YV12.
I disagree. But, perhaps it differs by DV codec. Let's consider MainConcept, and look at the following script
function translation(clip clip, clip "LClip", int "start_frame", int "beginX", int "beginY", int "end_frame",
  \  int "endX", int "endY") {
  return Animate(start_frame, end_frame, "layer", clip, LClip, "Add", 255, beginX, beginY,
    \  clip, LClip, "Add", 255, endX, endY)
c = BlankClip(width=720,height=576,pixel_type="YUY2")
c2 = ImageSource("F:\411_vs_420\1-720-pal.bmp",0,250,25,false).ConvertToYUY2()
ct = translation(c, c2, 0, 0, 0, 99, 720, 288)
cf = ct.SeparateFields.SelectEven
cf.Weave
AssumeFPS(25)
c1 = last.KillAudio
c2 = DirectShowSource("F:\411_vs_420\mc_int.avi", fps=25)  # interlaced YV12
#ConvertToYUY2(interlaced=true)
c1 = c1.ConvertToYV12(interlaced=true)
#Subtract(c1,c2)
StackVertical(c1,c2)
1) picture: http://www.geocities.com/wilbertdijkhof/pal.zip
2) mc_int.avi is the script (forming the clip "c1") encoded with MainConcept (also in pal.zip).
If mc_int.avi would have been upsampled to YV12 using MPEG-2 sampling, the clips c1 and c2 would be identical. As you can see, they are not.
Old 13th December 2004, 17:59   #65  |  Link
ixpi2001
sorry to intefere in your discussion.. i wonder if there is a possibility to only display one of the color channels a time. not in interpolated fullscreened size, but with ie the red pixels in just the position they are stored:
l1:x x x
l2: blank
l3:x x x
would be interesting to see, dont you think?
ixpi2001 is offline   Reply With Quote
Old 14th December 2004, 01:07   #66  |  Link
henryho_hk
I have a shot that a man in a grey suit is moving in front of a red background. I think it help beginners like me to see how interpolate420() and fixbrokenchromaupsampling() works.
Is the following script correct?
<<deleted>>
Old 23rd June 2005, 19:57   #67  |  Link
Video Dude
Senior Member
Sorry for the late reply, but better late then never.
Its not a question of which better, but which format you use, PAL or NTSC, which depends on what county you live in.
Yes, I would recommend using the ReInterpolate411 filter if you are encoding NTSC DV into MPEG-2. It does a great job.
Video Dude is offline   Reply With Quote
Old 27th August 2005, 17:24   #68  |  Link
FredThompson
FredThompson's Avatar
Post your screenshots.
Reclusive fart.
Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers
FredThompson is offline   Reply With Quote
Old 6th September 2005, 11:17   #69  |  Link
Wilbert
Still waiting for your screenshots
edit: oops sorry
# ffdshow
m_dvsd_yuy2=avisource("p3.avi",pixel_type="YUY2",fourcc="dvsd")
m_dvsd_yv12=avisource("p3.avi",pixel_type="YV12",fourcc="dvsd")
This can't be the DV codec which comes with ffdshow. The latter is a DirectShow based codec which can only be accessed by DirectShowSource. But perhaps i'm missing something
Old 6th September 2005, 12:57   #70  |  Link
henryho_hk
There is no vidc.dvsd setting in my registry but I've enabled ffdshow's DV decoding in its VFW & DS decoder. I do have a set of png files made by directshowsource but the forum does not allow me to post them (since they are identical to the dvsd vfw files).
Old 6th September 2005, 17:23   #71  |  Link
FredThompson
You might also want to test the MainConcept and Ulead (Sony) codecs.
Reclusive fart.
Old 8th September 2005, 07:05   #72  |  Link
henryho_hk
They seem a bit off-topic. I have moved them to the thread "DV decoder differences - update".
Old 21st July 2006, 23:44   #73  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
I updated ReInterpolate420 plugin a little:
v3, 22 July 2006 -
color tint decreasing in progressive mode;
speed increasing in both modes by integer processing
