Old 13th March 2009, 10:40   #21  |  Link
buzzqw
HDConvertToX author
check here http://www.64k.it/andres/dettaglio.php?sez=avisynth
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 13th March 2009, 14:26   #22  |  Link
tebasuna51
tebasuna51's Avatar
Warning with BassAudio_Pack in http://www.64k.it/andres/dettaglio.php?sez=avisynth is very outdated and buggy.
Is your site?
Old 13th March 2009, 14:31   #23  |  Link
buzzqw
HDConvertToX author
yes
feel free to link me a new pack, i will glady update my site
BHH
Old 13th March 2009, 18:31   #24  |  Link
Wilbert
Wilbert, your site links to version 01(not working) and not the 02 from above(working).
Thanks! I corrected the link
Old 13th March 2009, 23:06   #25  |  Link
tebasuna51
tebasuna51's Avatar
Here is the last version BassAudio2423.7z
Also some info about NicAudio with confuse names:
NicAudio_25_dll_20060314.zip Version 1.5  (Dimzon)    2006-03-14
NicAudio_alpha3.zip          Version 1.8? (Nic)       2006-09-01
NicAudio17.zip               Version 1.82 (Nic)       2007-08-13
NicAudio_20070821.zip        Version 1.83 (IanB)      2007-08-21
NicAudio_r201.7z             Version 2.01 (Tebasuna)  2008-04-09
NicAudio_r202.7z             Version 2.02 (Tebasuna)  2008-09-24
Edit: And RaWav.dll included in NicAudio since 2.00
Old 14th March 2009, 10:32   #26  |  Link
buzzqw
HDConvertToX author
thanks, added last pack and added version to file name
BHH
Old 24th March 2012, 11:12   #27  |  Link
tin3tin
tin3tin's Avatar
It seems that the audio related bugs has been solved in Avisynth 2.6, so I've been playing around with Wilbert's minmaxaudio plugin. It works quite well, however once in a while the resulting value drops out of the 0 to -100 DB range and gives a value like -791 and that causes problems because I need values between 0 and 1. I've been using AudioRMS function. Is this a bug?
DVD slideshow GUI(Freeware).
tin3tin is offline   Reply With Quote
Old 24th March 2012, 14:50   #28  |  Link
Wilbert
Sounds a bug to me. You got a sample clip and script for me?
Old 24th March 2012, 15:35   #29  |  Link
tin3tin
tin3tin's Avatar
Here's my code:
loadplugin("C:\Users\tin2tin\Desktop\Avisynth\FFmpegSource\FFMS2.dll")
import("C:\Users\tin2tin\Desktop\Avisynth\FFmpegSource\FFMS2.avs")
ffmpegsource2("C:\Users\tin2tin\.DVDslideshowGUI\PartyNow.mp4",atrack=-1).BilinearResize(320,240)
LoadPlugin("MinMaxAudio.dll")
ScriptClip("Subtitle(String(Audiorms(0)))")
Go to the last frame of this clip to see the low value.
Old 6th April 2012, 16:19   #30  |  Link
Wilbert
The last frame seems to have no audio (at least AviSynth doesn't get audio from FFmpegSource for the last frame). So the audio samples are zero and -791 is returned (which is 20*log10(FLT_MIN/tot) but that's not important).
Old 25th January 2013, 16:51   #31  |  Link
zenny
Is MinMaxAudio is something for this scenario?
Hi:
Even after more than 100 views when I didn't get any reply to the thread at http://forum.doom9.org/showthread.php?t=167011 in which I explained what I wanted to achieve in compositing with two sources of video with a common audio source, alternating the video source either durationwise and/or on detection of the audio pause.
New to avisynth, so could MinMaxAudio help to achieve what I am indending to? I read a bit here, but seems either it is only for animations or is going above my head! And if the latter, all fault is mine. ;-)
Appreciate it if somebody can guide me. Thanks!
Best regards
zenny
zenny is offline   Reply With Quote
Old 25th January 2013, 19:59   #32  |  Link
I answered in your other thread. You did not mention duration-wise over there. Can you clarify it over there?
