10th June 2012, 17:39 | #1381 | Link |
egur
I know that here it will be offtopic, but can you answer my question regarding QS transcoding. What conditions should be met in order to make QS encoder work? I am asking because no matter what I try I can't make it work in MediaCoder, it always returns error 14. Have you ever tried to QS transcoding in MediaCoder on a hybrid setup with fake vga display? |
10th June 2012, 18:34 | #1382 | Link | |
QuickSync Decoder author
QS transcoding (HW decoder + encoder) needs an i3 class CPU at a minimum. Fake VGA trick should work. Which part returns -14, my code? Which function? BTW, -14 from my code means a bad setup for the decoder or VPP (MFX_ERR_INCOMPATIBLE_VIDEO_PARAM), probably my bug, please specify your setup so I can reproduce.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. Last edited by egur; 10th June 2012 at 18:37. |
10th June 2012, 19:12 | #1383 | Link | |
egur
10th June 2012, 20:58 | #1385 | Link |
MediaCoder works fine when the iGPU is connected to main screen but fails otherwise.
This is a bug in the encoder initialization code. A bug that's very easy to fix BTW. If someone knows the author I can help fix this in 5 minutes.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. Last edited by egur; 10th June 2012 at 21:01. |
10th June 2012, 21:30 | #1386 | Link |
Maybe he can be contacted at the MediaCoder forums?
http://forum.mediacoderhq.com/ |
10th June 2012, 21:39 | #1387 | Link |
It would be great if you could help with a fix for this bug. I don't know mediacoder' s developer in person, either I don't know his email, but I found some info about him, his name is Stanley Huang, his twitter account, mediacoder bug report forum.
11th June 2012, 08:29 | #1388 | Link |
Does anyone have an account in MediaCodec's forum? I already monitor too many forums as it is...
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
11th June 2012, 11:19 | #1389 | Link | |
(he does have an account here on doom9 as well, but hasn't logged in since Jan 2011) (( wonder if http://forum.mediacoderhq.com/viewto...t=11994#p35686 had been reading this thread or not )) |
11th June 2012, 12:41 | #1392 | Link | |
Change: Code:
sts = m_mfxSession.Init(MFX_IMPL_HARDWARE_ANY, &version); Code:
sts = m_mfxSession.Init(MFX_IMPL_AUTO_ANY, &version); if (sts == MFX_ERR_NONE) // success { m_mfxSession.QueryIMPL(&m_mfxImpl); // any value other than MFX_IMPL_SOFTWARE means HW accleration m_mfxSession.QueryVersion(&m_ApiVersion); m_bHwAcceleration = m_mfxImpl != MFX_IMPL_SOFTWARE; // can check if SW is acceptable or not sts = (MFX_IMPL_SOFTWARE != m_mfxImpl) ? MFX_ERR_NONE : MFX_ERR_UNSUPPORTED; } return sts; This is assuming that MediaCodec used the sample encoder as is. Edit If the MediaCodec author or another user wants to continue this discussion, please open a new thread and send me the link.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. Last edited by egur; 11th June 2012 at 12:43. |
11th June 2012, 18:27 | #1393 | Link |
egur
I posted a bug report on MediaCoder forum. MediaCoder QS implementation discussion Please check for MediaCoder's developer reply. Last edited by RBG; 11th June 2012 at 20:34. |
12th June 2012, 07:28 | #1394 | Link |
I have two samples which makes problem during playback: http://netload.in/dateiRtEF2R4qzi/In...amples.zip.htm. Framerate indicator shows 2x bigger framerate then real framerate and there's horrible stuttering during playback. I have to disable deinterlacing on QuickSync and use software deinterlacing from FFDShow, then movies play perfectly.
13th June 2012, 09:08 | #1395 | Link | |
13th June 2012, 09:35 | #1397 | Link | |
I'd change the name but I don't think that's possible...
13th June 2012, 09:47 | #1398 | Link | |
13th June 2012, 10:20 | #1399 | Link | |
13th June 2012, 11:02 | #1400 | Link | |
ffdshow, h264, intel, mpeg2, quicksync, vc1, zoom player |
