29th June 2007, 19:04 | #261 | Link | |
30th June 2007, 08:53 | #264 | Link |
@madshi
LPCM 24Bit to wave works now! nice... But the flac Problem still exits for me 24Bit LPCM to 24Bit flac results in a flac which has the same Size as the raw! Strange... On the Sample both 24Bit Files are 90MB On a 6.7GB LPCM the FLAc from eac3to is 6.7GB too I tried all combinations again on the same sample So i use Audacity 1.3.3 to encode to flac 24bit 2 Questions: 1. Are you using Besiled 0.3 at the end of the dts chain to fix dts output? I think so... Maybe you can remember, we talked about via PN eact3to dts encode works with all 16 and 24bit Sources 2. Whne i convert a lpcm.raw to wave with -Bluray, the Message "remapping channes" will not longer appear ? Output wave has correct channelmapping Last edited by ACrowley; 30th June 2007 at 10:25. |
30th June 2007, 13:04 | #266 | Link | ||
I had to replace sox to make that work. SurCode didn't like the 24bit WAV files produced by sox. So now eac3to doesn't use sox for WAV file creation, anymore, but does that work itself. The WAV files created by eac3to should be similar to what wavwizard outputs. They seem to be more compatible then what sox creates. The message doesn't appear, anymore, because I'm now doing that step together with some other steps like creating mono wavs etc. In the older eac3to build the channel remapping was a separate step. In the new build eac3to is sometimes doing multiple steps at once to save time. You may have noticed (or maybe not) that the LPCM -> mono WAV conversion is rather quick. It should be 2x-3x as fast as before. |
30th June 2007, 13:06 | #267 | Link |
Older versions of SurCode (the latest version 1.0.29 doesn't have this problem) by default added some zero bytes after each DTS frame. A normal DTS frame for 1536kbit/s is 2013 bytes long. SurCode by default writes 2013 real bytes and then 35 zero bytes for every frame. Don't ask me why they're doing that, I've no idea. delaycut, besplit and most other software doesn't like this very much. Fortunately, I've found a way to convince SurCode to stop adding those 35 zero bytes after each DTS frame and added that to eac3to.
30th June 2007, 19:14 | #268 | Link | |
Madshi is right
With a Surcode encoded dts you will get these Errors in the Header and mostly wrong Runtime/Filesize and this Error in mkvmerge : audio/video go out of sync, but this stream is damaged. Warning: dts_packetizer: skipping 35 bytes (no valid DTS header found). This might make audio/video go out of sync, but this stream is damaged. To fix the dts you can also use Besliced.exe (0.3) Besliced 0.3 exe included in : http://dspguru.notrace.dk/BeSplitv0.9b6.zip Simply open Besliced.exe and move your dts into the window and select fix. You will get a lot of Errors in the Log like this : [00:00:00:000] +------- BeSplit ----- [00:00:00:000] | Input : G:\test.dts [00:00:00:000] | Source Sample-Rate: 48.0KHz [00:00:00:000] | Channels Count: 5.1, Bitrate: 1536kbps [00:00:00:000] | Output : G:\test_Fixed.dts [00:00:00:000] +--------------------- [00:00:00:021] Stream error : Sync found after 35 bytes [00:00:00:032] Stream error : Sync found after 35 bytes [00:00:00:042] Stream error : Sync found after 35 bytes [00:00:00:053] Stream error : Sync found after 35 bytes [00:00:00:063] Stream error : Sync found after 35 bytes [00:00:00:074] Stream error : Sync found after 35 bytes [00:00:00:085] Stream error : Sync found after 35 bytes [00:00:00:096] Stream error : Sync found after 35 bytes [00:00:00:106] Stream error : Sync found after 35 bytes [00:00:00:117] Stream error : Sync found after 35 bytes [00:00:00:128] Stream error : Sync found after 35 bytes [00:00:00:138] Stream error : Sync found after 35 bytes [00:00:00:149] Stream error : Sync found after 35 bytes [00:00:00:159] Stream error : Sync found after 35 bytes [00:00:00:170] Stream error : Sync found after 35 bytes [00:00:00:181] Stream error : Sync found after 35 bytes .... After fixing the dts is clean ,with correct Runtime/Filesize and no more Problems and you have a proper nice dts ############################################### @Madshi 1 .The Surcode Registry Key "PAD ZEROS"). it should be set to 0 ,right ? 2. When i use -down16 on the sample, the flac output still has the loud noise .wav output is ok (in 16 and 24bit) And -flac in 24bit ,has the Filesize Problem i told you above 3.Flake encoder would be nice. Its faster und higher -12 compression But : At the Moment you get only 16bit flac from flake encoder : Signed 24-bit 48000 Hz 6-channel WARNING! converting to 16-bit (not lossless) http://forum.doom9.org/showthread.php?t=120871 Quote:
30th June 2007, 22:14 | #269 | Link | ||
1st July 2007, 00:56 | #270 | Link |
New version (v1.15) of EAC3toGUI available here:
http://www.sendspace.com/file/ltxl6s Changelog Version 1.15: - Added DTS rate options - Added Down convert option "-down16" - Added "wavs" and "dts" filemasks - Changed PCM and TrueHD options scheme to allow selection of common options (16bit, 24bit, 96Khz, 8ch) Please report bugs, suggestions and overall usage experience. Regards, The_Keymaker Last edited by The_Keymaker; 1st July 2007 at 01:01. |
1st July 2007, 02:16 | #271 | Link | |
Posts: n/a
1st July 2007, 08:17 | #272 | Link |
@The_Keymaker
BluRay channelmapping Switch is removed cause eac3to will do it autom. now ,right ? Little Suggestions 1. I know in your opinion (youre right) its enough to type in the dest. File extension to set Output Format. But ,imho, a small scrolldown Outputformat Window would be nice 2. The Downconvert Option would be more obvious with "Downconvert to 16Bit" 3. Maybe a little Error ? When you select "Browse" to set the Output, the Windows Name is "Select the Source File" , shouldnt it be "Save as" ? And Filetyp is (ac3,raw,wav), Theres no flac ( ac3,raw,wav,flac) 4. And the Input Extension .raw would be nice Ofcourse its all marginal, your Gui works great! THX greets Last edited by ACrowley; 1st July 2007 at 08:49. |
3rd July 2007, 03:47 | #273 | Link |
EAC3toGUI Version 1.18 Released
New version (version 1.18) of EAC3toGUI released. Download link:
http://www.sendspace.com/file/ruv4ub Changelog: 1. Added *.raw source file extension mask 2. Added *.flac destination extension mask 3. Relabeled down convert option for clarification 4. Relabeled destination file browse dialog Thanks to ACrowley for feedback and suggestions. As usual, please provide feedback, bug reports and usage experience. Regards, The_Keymaker |
3rd July 2007, 09:48 | #274 | Link |
THX..great work!
But to 1: .raw apppears in the mask ,When i load a .raw i get a ErrorMessage about a not valid Extension. And is it possible to add a Proggress Bar (%) or something like that ? Last edited by ACrowley; 3rd July 2007 at 12:40. |
3rd July 2007, 17:29 | #275 | Link |
don't know what I am doing wrong, says
Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. D:\BREAKUP\HVDVD_TS>"C:\Documents and Settings\Ivan\Desktop\New Folder (3)\eac3t o.exe" "D:\BREAKUP\HVDVD_TS\EXTENDED.EVO" "D:\BREAKUP\HVDVD_TS\EXTENDED.ac3" - 448 -24 Muxing evo's first audio track to raw. Please wait... Converting the raw file to wav. Please wait... Converting the wav file to ac3. Please wait... Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format: Signed 24-bit 48000 Hz 5.1-channel output format: 48000 Hz 3/2 + LFE "aften" reported error code "3221225477". A valid *.wav file was created sucessf ully, though. D:\BREAKUP\HVDVD_TS> When I got to the wav file everything is sped up. the audio sounds like its beeing fastfoward? Last edited by Prophecy650; 3rd July 2007 at 17:45. |
3rd July 2007, 17:59 | #276 | Link |
@Prophecy650,
as far as I can see from the "The Break-Up" HD DVD specs, this HD DVD doesn't have a TrueHD track, but only some E-AC3 tracks. So you may want to try demuxing the E-AC3 track by using EvoDemux and then feed that into eac3to. Maybe that works better? |
3rd July 2007, 18:12 | #278 | Link |
i went to evodemux changed it to eac3 not Im getting this
Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\Ivan\Desktop\New Folder>"C:\Documents and Settings\Iva n\Desktop\New Folder (3)\eac3to.exe" "C:\Documents and Settings\Ivan\Desktop\New Folder\FEATURE_1_FEATURE_2.DD>stream.00.eac3" "C:\Documents and Settings\Ivan\ Desktop\New Folder\FEATURE_1_FEATURE_2.DD>stream.00.ac3" Source file "C:\Documents and Settings\Ivan\Desktop\New Folder\FEATURE_1_FEATURE _2.DD>stream.00.eac3" not found. |
3rd July 2007, 19:32 | #280 | Link |
(C) Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\Ivan\Desktop\New Folder>"C:\Documents and Settings\Iva n\Desktop\New Folder (3)\eac3to.exe" "C:\Documents and Settings\Ivan\Desktop\New Folder\FEATURE.eac3" "C:\Documents and Settings\Ivan\Desktop\New Folder\FEATUR E.ac3" -448 -nero E-AC3, 5.1 channels, 1:46:31, 1536kbit/s, 48khz Muxing eac3 file to raw. Please wait... Audio Decoder output was 24 bit this time. Converting the raw file to wav. Please wait... Converting the wav file to ac3. Please wait... Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format: Signed 24-bit 48000 Hz 5.1-channel output format: 48000 Hz 3/2 + LFE "aften" reported error code "3221225477". A valid *.wav file was created sucessf ully, though. how do I get it to ac3 now? thanks alot madshi, I can hear the audio atleast now |
eac3to |
