31st August 2010, 02:36 | #381 | Link |
Well, i thought that too but that doesn't seem to be the case. I can reproduce the error in Snow Leopard, the file contains all 4 architectures, no broken dependencies but it does not work. I recompiled the latest release under Snow but it didn't change anything.
My current development build does work however, so far i can tell the biggest difference is that it doesn't use OpenSSL anymore. I know i had some problems to get it work with OpenSSL, notably because the OpenSSL version shipped with MacOS missed the ECDSA functions. Using OpenSSL from MacPorts fixed that however. You haven't mentioned but i assume you are using Snow Leopard, i have made the latest release with it's predecessor and i can't remember that i got this error because of another reason than a missing architecture in the file. If you have the ability you can try to get OpenSSL from MacPorts and recompile aacskeys with it, currently i don't have the time (and mood ) to do this myself. |
1st September 2010, 02:06 | #382 | Link |
Incorrect internal format: aacskeys-0.4.0c/lib/macosx/libaacskeys.dylib
I downloaded aacskeys-0.4.0c a few minutes ago. The internal format of the libaacskeys.dylib in the lib/macosx directory is not correct. Here's the output of the file command:
libaacskeys.dylib: Mach-O universal binary with 4 architectures libaacskeys.dylib (for architecture i386): Mach-O executable i386 libaacskeys.dylib (for architecture x86_64): Mach-O 64-bit executable x86_64 libaacskeys.dylib (for architecture ppc7400): Mach-O executable ppc libaacskeys.dylib (for architecture ppc64): Mach-O 64-bit executable ppc64 The correct format is dynamically linked shared library. |
1st September 2010, 10:04 | #383 | Link |
How to correctly rebuild libaacskeys.dylib (for Mac OS X only)
Here are some hints to correctly rebuild libaacskeys.dylib:
1. Carefully read README.txt and be sure you have openssl version 0.9.8 or later and premake version 3.7. 2. Verify your OPENSSL_INCLUDE = and OPENSSL_LIB = settings in premake.lua. 3. Uncomment (remove the --) from these three lines in premake.lua: --if (macosx) then -- table.insert(package.buildflags, "dylib") --end 4. Enter this command: premake --file premake.lua --target gnu --os macosx 5. Remove -flat_namespace -dynamiclib, anywhere you find it in libaacskeys.make. It is caused by a problem with premake. 6. Enter this command: make clean 7. Determine the architectures you need libaacskeys.dylib to support. If you are only using it with DumpHD then you probably only need x86_64 however my Macs are older and I use a modified version of DumpHD that runs under the older Java 1.5 which is the latest Java that Apple has provided for those older Macs. 8. Enter a command like this for the architecture(s) you need: TARGET_ARCH="-arch ppc -arch ppc64 -arch i386 -arch x86_64" make libaacskeys 9. Verify that your result is a dynamically linked shared library using this command: file lib/macosx/libaacskeys.dylib Last edited by blu4fun1; 1st September 2010 at 10:31. Reason: Add step 5. |
2nd September 2010, 01:35 | #384 | Link |
Hi, thanks for taking the time to look into this, i totally have missed that file says executable.
I looked at your solution and was quite confused because i thought i'm doing just the same thing, and then i found the error, its a stupid typo! So the fix is actually even more simple.
30th November 2010, 06:39 | #386 | Link | |
13th March 2011, 22:34 | #387 | Link |
Running Linux and dumphd-0.61 was only able to decrypt 2 BD discs out of 6. Is there a way to decrypt the newer discs on Linux?
These have MKBv: 16 lotr1.log: DiscID : 49E3C2EB3DF6697BF6613F84775EE419A817C06C lotr2.log: DiscID : F4E162490E6971EC261CFC10653BD0CB52317F6C lotr3.log: DiscID : A2FA3882887FD436F2E7399F3254771DFE2ED664 One disc had BD+ encryption but removing it also failed: iceage3.log: DiscID : B6B6CF9AE847975220C62F82F41786DEA881B238 ---8<---8<--- Loading /media/cdrom0/BDSVM/00000.svm ... Volume ID set to: B6 B6 CF 9A E8 47 97 52 20 C6 2F 82 F4 17 86 DE A8 81 B2 38 [I] TRAP_LoadContentCode: Loading BDSVM/00001.svm (block 1) [I] TRAP_MediaSHAFileHash: Hashing BDSVM/00000.svm [I] TRAP_MediaSHAFileHash: Hashing AACS/MKB_RO.inf [I] TRAP_MediaSHAFileHash: Hashing BDMV/STREAM/00389.m2ts [I] TRAP_LoadContentCode: Loading BDSVM/00001.svm (block 2) [W] TRAP_DeviceAccess not implemented! [Event #00000000] EVENT_PlaybackFile( 00000000, 0000FFFF ) [Event #00000001] EVENT_0210( 00000000, 00000001 ) [W] TRAP_DeviceAccess not implemented! [W] TRAP_DeviceAccess not implemented! [Event #00000002] EVENT_PlaybackFile( 00000000, 00000001 ) [I] TRAP_LoadContentCode: Loading BDSVM/00002.svm (block 0) [I] TRAP_GetConversionTable: Received new subtables: 1,59,118,java.lang.ArrayIndexOutOfBoundsException: 290 at bdvm.vm.conv_tab_main.setConversionTable(conv_tab_main.java:43) at bdvm.vm.decoder.getConversionTable(decoder.java:55) at bdvm.vm.bdsvm_player_interface.TRAP_handler(bdsvm_player_interface.ja va:658) at bdvm.vm.BDVM.step(BDVM.java:391) at bdvm.debugger.Debugger.step(Debugger.java:801) ... ---8<---8<--- Why was the array out of bounds? Could that be easily fixed just by having a bigger array or has something else went wrong? |
14th March 2011, 10:13 | #388 | Link |
I don't know specifically how to solve your problem but an ArrayIndexOutOfBoundsException is not thrown because the array is too small (this shouldn't really ever be happening in Java), but because the program is requesting an element at an index that does not exist (for example the array has 100 elements while the program requests element number 178)
27th April 2011, 18:53 | #389 | Link |
Are we (the user of your program)responsible for providing our own ProcessingDeviceKeysSimple.txt, HostKeyCertificate.txt contents?
I ask because I believe that the keys and hostCertificate provided was expired by the time I got to it. I get the following error. Code:
Could not find a Processing Key or Device Key resulting in the Media Key. |
29th April 2011, 03:32 | #391 | Link |
The latest version of makeMKV is 1.6.8. I've used it, it's nice, I just don't to have to pay (again) to watch a movie I've already bought. I've payed my dues when I bought the disk(movie), I shouldn't have to pay again for software to watch it.
I found lxBDplayer, I'm not sure about the other file as most of the links I found for it were questionable, and the only one that looked remotely safe was in French, I don't speak French. Is their a link you can provide to the lxbdaacs? Are you saying I need to replace files in dumpHD with the ones you suggested? Edit, I found the thread for lxBDplayer, and the required lxBDaacs. I was hoping to use DumpHD, seeing as I don't have to pay for that. I suppose if the only I'll be able to get around the stupid silly "We don't support your OS" limitations of other programs, I'll have to use makeMKV. Paying for yet another program to do what I've already paid for (play a movie) rubs me the wrong way. Last edited by Rinse&Repeeat; 29th April 2011 at 15:40. |
30th April 2011, 19:45 | #393 | Link |
@Rinse&Repeeat
lxbdplayer is for playing bluray lxbdaacs is plugin for lxbdplayer to have AACS lxbdaacs dump the memory of makemkv to have the key of the bluray but lxbdaacs work only with makemkv 1.5.5 (with the free beta serial) you don't have to pay for use it |
26th August 2013, 15:07 | #395 | Link |
Can you blush ?
I know this is not exactly an answer to your question but given the age of the last posting and the last update at the first posting I doubt that there is much active development here. In case you are watching for something to decrypt BDs under Linux, you might consider trying MakeMKV.
HTH, D$ Edit: A more helpful answer might be which Java Runtime you are using and if this corresponds with the supported JRE of DumpHD. Java apps often behave strange when you use a different Java (older or newer version, OpenJRE versus Sun's JRE, and so on). Last edited by Darksoul71; 26th August 2013 at 15:34. |
27th August 2013, 10:15 | #397 | Link |
Can you blush ?
Re-Hi,
glad I could help ! I have been using MakeMKV for quite a while under Xubuntu 12.04 with an external LG BD and it worked like a charm. Plus it has a nice option to directly watch BDs via local streaming server. Works also great from the shell via makemkvcon if you are more the text addicted type of user |
12th April 2020, 05:25 | #398 | Link | ||
Holy Outdated Software, Batman!
Hi, friends.
I am endeavoring to archive my HD DVD's. (It seemed like an appropriate project to work on at the moment.) For the most part, MakeMKV takes care of the job without any real customization. However, there are some titles that are still looking for their VUK. @candela brought the DumpHD app to my attention when I was looking for keys for these relics of HD lore. I have pieced together the ProcessingDeviceKeysSimple.txt and HostKeyCertificate.txt as appropriate (based upon the sets listed here), and those seem to check out. The last piece I'm stuck on is the libaacs library. I'm currently working this solution on a Mac, and I've found the libaacskeys.dylib within the aacskeys-0.4.0f archive. I've placed this in the same directory as the DumpHD JAR file, and I get the following: Quote:
I will try this with my Windows 10 machine as well to see if the DLL works better than the DYLIB on the Mac. Thanks in advance! Last edited by metaldave2003; 12th April 2020 at 06:59. |
12th April 2020, 06:28 | #399 | Link | |
file <path to dylib> |
12th April 2020, 07:03 | #400 | Link |
maetel99,
Thank you for the thought. I checked it, and it looks like we're good x86_64: Code:
% file libaacskeys.dylib libaacskeys.dylib: Mach-O universal binary with 4 architectures: [i386:Mach-O executable i386] [x86_64:Mach-O 64-bit executable x86_64] [ppc_7400] [ppc64] libaacskeys.dylib (for architecture i386): Mach-O executable i386 libaacskeys.dylib (for architecture x86_64): Mach-O 64-bit executable x86_64 libaacskeys.dylib (for architecture ppc7400): Mach-O executable ppc_7400 libaacskeys.dylib (for architecture ppc64): Mach-O executable ppc64 |
