Go Back   Doom9's Forum > Capturing and Editing Video > NLE - Non Linear Editing
Old 30th September 2006, 18:12   #61  |  Link
nibbles
nibbles's Avatar
In post #54 above, Keys provided links to Huffyuv 2.2.0.
http://forum.doom9.org/showthread.ph...088#post780088
But the links contain different versions of Huffyuv unfortunately.
1st link: huffyuv.dll 2.1.1 CCESP 0.2.2 12/8/2001 (38912 B)
2nd link: huffyuv.dll 2.2.0 12/20/2003 (45568 B)
Good luck,
nibs
nibbles is offline   Reply With Quote
Old 20th July 2015, 16:01   #62  |  Link
ChiDragon
ChiDragon's Avatar
Can an admin please add a note to the first post saying that this version is known to be broken for RGB input? It only works correctly when "Reduced Resolution" or "<-- Convert to YUY2" is selected, and the size of the garbled file is much smaller than it should be. Everyone agrees on this.
This thread is the third Google result for me when I search for "Huffyuv v2.2.0", and it's linked from the Wikipedia page for Huffyuv. I suspect most users don't make it down to the end of page 1 where the issue is explained, or page 2 where sh0dan (the OP) says to stick to 2.1.1 (his last post in this thread).
ChiDragon is offline   Reply With Quote
Old 28th July 2015, 06:55   #63  |  Link
Audionut
Report the first post and add your message there. Don't expect the mods to read every post.
http://www.7-zip.org/
Old 28th July 2015, 16:31   #64  |  Link
ChiDragon
ChiDragon's Avatar
I would have, if not for "Note: This is ONLY to be used to report spam, advertising messages, and problematic (harassment, fighting, or rude) posts."
I've done it now.
Old 28th July 2015, 23:15   #65  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Done.
Old 29th July 2015, 21:39   #66  |  Link
ChiDragon
ChiDragon's Avatar
Haha, you included my "Everyone agrees on this" in the quote. I'm such a
Old 9th November 2016, 18:29   #67  |  Link
Mick
Mick's Avatar
Say, does anybody know if the Huffyuv CCESP Patch 0.2.5 stores the Interlaced Setting in the AVI-File like Version 2.2.0 or still in the INI-File ?
-> May U live 2 C the Dawn <-
Mick is offline   Reply With Quote
Old 17th January 2017, 22:24   #68  |  Link
Why not try it out yourself, cant take too long can it.
Here, link to multiple versions of HuffYUV (2.1.1, does not include broken 2.2.0):- http://www.mediafire.com/file/i56981...ffYUV+2-1-1.7z
Includes dll versions, 32bit, 64bit, CCESP Patch 0.25, MultiThreading, and source.
EDIT: The MultiThreading version is no faster than single threading on my duel core Core Duo XP32.
Old 18th January 2017, 17:41   #69  |  Link
Mick
Mick's Avatar
"StainlessS", thanks for the Link and your reply I'll try it out and post the result here
Cheers
Mick
Old 12th February 2017, 19:11   #70  |  Link
Mick
Mick's Avatar
Update:
I tried different captures with Huffyuv (CCESP 0.2.5 single/multi) and seems like the Interlaced Setting is stored in the Video and no longer in the Ini-File once it has been set. I used for PAL/SECAM 288, Resolutions 704/720/1024x576 and for NTSC 240, Resolutions 704/720/852x480. Still, can anyone confirm this ? Thanks in advance
@StainlesS
The Multi-Threaded Version does make a big difference with Cinegy eXpress/eXtreme and MoviePlus for example. The single threaded Version uses more CPU for decoding and is a bit slower than the Multi-Threaded Version
Cheers
Mick
Old 19th March 2017, 18:18   #71  |  Link
Mick
Mick's Avatar
Another Update:
This older Thread seems to confirm what Interlaced concerns using the Huffyuv 0.2.5 Patch:
http://forum.doom9.org/showthread.ph...973#post496973
Cheers
Mick
