Old 17th June 2018, 17:19   #1  |  Link
mr.muscade
Need help to encode difficult video to compress
Hello, I encode with x264 since many years, I know well its parameters. Recently, I get some videos difficult to encode, because there are many artifacts, crispy image, and when I try to encode these videos, these artifacts are still present and the result is ugly. Bellow a sample uncompressed with the artifacts at the top of the image.
Please, could you help me to set the x264 parameters in order to smooth these area of artifacts? I wish result in almost HD@1Mbps. Thanks in advance!
Original video : LINK
Compressed video : LINK
The sample @1Mbps is encoded with the following x264 parameters:
cabac=1 / ref=9 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1,00:0,00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1000 / ratetol=1,0 / qcomp=0,60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20,0 / qblur=0,5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / filler=0 / ip_ratio=1,40 / aq=1:1,00
mr.muscade is offline   Reply With Quote
Old 17th June 2018, 17:22   #2  |  Link
videoh
Useful n00b
If the artifacts are in the source, how can you expect to remove them with encoder settings?
Old 17th June 2018, 17:26   #3  |  Link
mr.muscade
Yes, the artifacts are in the source at the top of the image (crispy area). In order to remove them, I though play with x264 settings to smooth this area, but I failed.
Old 17th June 2018, 17:39   #4  |  Link
videoh
Useful n00b
I see. Better to do it in an Avisynth/Vapoursynth script, I think.
Old 17th June 2018, 19:00   #5  |  Link
Sharc
Originally Posted by mr.muscade View Post
..... I wish result in almost HD@1Mbps.....
Well, that's a challenge. You have to throw bombs at your video....
Old 17th June 2018, 19:23   #6  |  Link
ChaosKing
Here's a filtered version https://www89.zippyshare.com/v/Ju3xwPph/file.html
clip = haf.SMDegrain(clip, tr=3, pel=2, contrasharp=False, thSAD = 500, thSADC = 400, prefilter=1).rgvs.RemoveGrain(mode=1)
x264 --preset veryslow --crf 33
x265 has also good quality @ low bitrates, maybe you could switch to hevc?
Old 18th June 2018, 06:59   #7  |  Link
mr.muscade
Good job! I will study this. I can't use x265 because our equipment doesn't read HEVC.
x264
