Old 30th May 2016, 06:08   #241  |  Link
No idea, but try eg
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins+\MP_Pipeline.dll")
ffdshow_source() # NOT INSIDE MP_PipeLine script
MP_Pipeline("""
### platform: win32
SetMemoryMax(512)
sss = 1.5
newWidth = round(sss*width(last)/8)*8
newHeight = round(sss*height(last)/8)*8
LanczosResize(newWidth,newHeight)
Old 30th May 2016, 08:03   #242  |  Link
vinnytx
Ok, now I have another error message
MP_Pipeline: Unable to create slave process. Message: Script error: Script error: Invalid arguments to function 'width' (ffdshow_filter_avisynth_script, line 11)
vinnytx is offline   Reply With Quote
Old 30th May 2016, 08:44   #243  |  Link
Groucho2004
Groucho2004's Avatar
The source filter statement has to be within the "MP_Pipeline" construct. This combination may not work at all since ffdshow_source() is not a conventional source filter. My knowledge of Avisynth scripts in ffdshow is very limited though...
Old 31st May 2016, 09:35   #244  |  Link
DJATOM
DJATOM's Avatar
No idea, but try eg
MP_Pipeline("""
### platform: win32
SetMemoryMax(512)
sss = 1.5
As I know, MP_Pipeline can't pass clips that way. So it will not work.
DJATOM is offline   Reply With Quote
Old 31st May 2016, 11:41   #245  |  Link
vinnytx
Any advice?
Old 31st May 2016, 16:55   #246  |  Link
Stereodude
I know jack about ffdshow_source. Is it a built in function of AVIsynth/AVIsynth+ otherwise don't you need to load a plugin? Is it auto-loading for 64-bit, but not 32-bit?
Stereodude is offline   Reply With Quote
Old 31st May 2016, 17:03   #247  |  Link
Never used it (ffdshow_source), but see here:- http://ffdshow-tryout.sourceforge.ne...video:avisynth
Is installed by ffdshow-tryout.
EDIT: you have to select tick box on install, see below
EDIT: I dont currently have ffdshow installed, but I think it may install the dll into it's own directory,
perhaps a copy into autoload plugins dir would work for general usage.
Old 31st May 2016, 20:45   #248  |  Link
vinnytx
ffavisynth.avsi
ffavisynth.dll
They are already in the Avisynth+ plugins+ directory
Old 14th August 2016, 15:46   #249  |  Link
Chyrka
Hello.
Is it possible to use MP_Pipeline and ScriptClip inside it?
They both started from """ tripple quote marks. ScriptClip does not want to work with a single quotation mark as it is stated in the documentation.
Chyrka is offline   Reply With Quote
Old 16th August 2016, 01:32   #250  |  Link
real.finder
Originally Posted by Chyrka View Post
Hello.
made a simple function like this
function ScriptClip_lines(clip c) {
c
*ScriptClip here*
and put it in .avs and import that .avs inside MP_Pipeline
then put the "ScriptClip_lines()" line in the place you want
My Avisynth Stuff
Old 16th August 2016, 10:50   #251  |  Link
Chyrka
real.finder, that hack must work. Thanks.
Old 17th November 2016, 08:48   #252  |  Link
bxyhxyh
Hello, I wanted to speed up xsharpen with this. With MT version, xsharpen goes at nice 2x-4x speed. But sometimes it gives me corrupted frame.
Can I call it like this to prevent from denoising being inside of it?
mp_pipeline("""
Import("C:\Users\BallGNM\Desktop\denoised.avs")
s16=dither_resize16(6840,4860)
s16.ditherpost(mode=-1).xsharpen(strength=255,threshold=255).Dither_convert_8_to_16()
s16.Dither_limit_dif16 (last, thr=0.7, elast=2.0)
dither_resize16(1120,840).gradfun3(smode=2,lsb_in=true,lsb=false,mode=6,thr=0.5)
### branch 2
dehalo_alpha_mt()
bxyhxyh is offline   Reply With Quote
Old 8th February 2017, 09:05   #253  |  Link
tuanden0
Can someone help me? I'm using avs+.
MP_Pipeline's great, my speed increase 30 ~ 45% and encode time decrease 30% with my script:
MP_Pipeline("""
### platform: win64
LWLibavVideoSource("E:\Test Zone\test.mkv")
AssumeFPS(24000, 1001)
FFT3DFilter(sigma=1.7, bt=1, ncpu=4)
flash3kyuu_deband()
Prefetch(4)
### platform: win32
Toon(0.25)
TextSub("E:\Test Zone\test.ass", 1)
Then, I tried this script and my encode time decrease 2/3 with my speed increase 50 ~ 60%. But, sometime it's crashed :
MP_Pipeline("""
### platform: win64
flash3kyuu_deband()
Prefetch(4)
### platform: win32
Toon(0.25)
Prefetch(4)
I tried to put Prefetch(4) outside MP_Pipeline but they slower than my 1st script
tuanden0 is offline   Reply With Quote
Old 9th February 2017, 08:35   #254  |  Link
pinterf
This is a known issue in avs+ since r206x, workaround in progress.
pinterf is online now   Reply With Quote
Old 9th February 2017, 09:52   #255  |  Link
tuanden0
@pinterf: for the information
Old 21st December 2017, 21:59   #256  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
I'd like to split my script into multiple process in order to avoid the 2 GB limit, 'cause it crashes.
I'm trying to split my script like this:
MP_Pipeline("""
FFVideoSource("op.mxf", fpsnum=24000, fpsden=1001)
Spline64ResizeMT(1920, 1080, threads=4, logicalCores=true, MaxPhysCore=true, SetAffinity=true)
#AmplifyDB(-12.0)
opening=last
### platform: win32
### export clip: opening
FFVideoSource("ep.mxf", fpsnum=24000, fpsden=1001)
tdeint(mode=2, order=-1, field=-1, mthreshL=6, mthreshC=6, map=0, type=2, debug=false, mtnmode=1, sharp=true, cthresh=6, blockx=16, blocky=16, chroma=true, MI=64, tryWeave=true, link=1, denoise=true, slow=2, opt=4)
Converttoyv12(interlaced=false, chromaresample="Spline64", matrix="Rec709")
opening++trim(2157, 30327)
episode=last
### platform: win32
### export clip: episode
FFVideoSource("ed.mxf", fpsnum=24000, fpsden=1001)
#AmplifyDB(-14.0)
episode++trim(0,0)
final=last
### platform: win32
### export clip: final
#Normalize(0.89, show=false)
#ResampleAudio(48000)
tweak(sat=1.53 , dither=true)
### platform: win32
dfttest(sigma=64, tbsize=1, lsb_in=false, lsb=false, Y=true, U=true, V=true, opt=3, dither=0)
### platform: win32
Spline64ResizeMT(3840, 2160, threads=4, logicalCores=true, MaxPhysCore=true, SetAffinity=true)
### platform: win32
aWarpSharp2(thresh=180, blur=3, type=0, depth=35, depthC=10, chroma=4)
### platform: win32
f3kdb(range=15, Y=45, Cb=30, Cr=30, grainY=0, grainC=0, sample_mode=2, blur_first=true, dynamic_grain=false,  opt=3, mt=true, keep_tv_range=true, input_depth=8, output_depth=8)
### platform: win32
TextSubmod("sub.ass")
### platform: win32
I'll let you know if the encode finishes successfully or not.
If it works, MPP it's gonna be really useful to my daily tasks!
Old 22nd December 2017, 19:09   #257  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
It works, but I don't know how to handle audio now, 'cause MPP doesn't support it.
Old 22nd December 2017, 23:43   #258  |  Link
real.finder
maybe this can help you, or you must wait someone can added audio to mpp, or made another script just for audio
My Avisynth Stuff
Old 23rd December 2017, 02:08   #259  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
@real.finder... uh... I see... I just replied on github as well. As a "workaround", I'm using audio created in a separate avisynth script, created to make a low-res version that was sent out to our subtitling team. Anyway, audio support would be a really useful feature. Unfortunately, I'm a .NET guy and my lazy ass made me forget almost everything about C++ I studied at university and embrace C# time ago. Perhaps, JPSDR / StainlessS / Groucho2004 could take a look at the code and, if interested, add audio support.
Old 23rd December 2017, 11:05   #260  |  Link
ChaosKing
Or you could use avisynth 64 bit to avoid the 2gb limit... as far as I can see all your filters are also available for x64.
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
avisynth, multi-process, pipeline
